Showing results for tags 'spring mod'.
  1. Evening all, so I removed my clutch assist spring and fitted the clutch stop today. I have already uprated the clutch to Sachs sintered and have the ECS bleed block fitted. The car felt lovely to drive today, gear changes felt great, no delay in the pedal feel. I took just one washer off the clutch stop and the resting point is perfect. I only have to lift the clutch pedal a short amount and it engages smoothly. The spring removal seems to of improved the feel again. Next week i'm having the APR quick shift and 42 draft designs solid bushings fitted which I expect will finish the manual set-up off nicely 🙂 Looking forward to changing gears again tomorrow 👍
