Showing results for tags 'ttrs mk7R'.
  1. So finally got the ttrs calipers and borrowed some rs3 discs (no they dint fit ,read next ) golf 7R are the same as the mk6 do thats a plus Upgrading the mk7R brakes to TTRS are simple plug and play important notice : discs need to be ttrs NOT rs3 calipers are no problem because ttrs and rs3 use the same calipers and carriers the brake hose lines need to be from the new leon cupra performance pack oem part number for the brake hoses : 5F0 073 912 here are some pics (they show the rs3 discs ,but only for testing so you can see that all fits perfect with the ttrs discs the wheels used for testing clearence are oem pretorias the spacers req to clear the ttrs calipers are 5+ mm ,you can go wider as you like ,but the base minimum is 5mm these is the picture without spacers to see there is little or no space in this setup we used a 10mm spacer to line the RS3. discs in the way that TTRS will sit on the hub direct
