VCDS CODE HELP
chrisvwg7r
Hi All,
Apologies if this has been asked before,
I am trying to find the original factory settings for for the following codes for a UK spec golf 7R within the central electronics under the adaption section.
8 leuchte23sl HLC10-Lichtfunktion C23
9 leuchte23 sl hlc10 - Lichtfunction D 23
10 leuchte23sl hcl10 - dimmwert CD 23
11 leuchte23sl hcl10 - Dimming Direction CD
8 leuchte24sl HLC10-Lichtfunktion C24
9 leuchte24 sl hlc10 - Lichtfunction D 24
10 leuchte24sl hcl10 - dimmwert CD 24
11 leuchte24sl hcl10 - Dimming Direction CD
Is it possible for someone with VCDS to check these on their UK golf 7r and let me know what the standard settings should be.
Any help will be much appreciated.
Cheers Chris
8  - standard allgemein (schlussslicht positionlight
9 parklicht links (beidseitiges parklicht aktiviert li re)
10    - 10
11-  maximize
8 --- i have after 24 sl HRA        not HLC ?????? But after that here is what ive got
8 standlicht allgemein (schlusslicht positionlicht)
9 24 sl HRA 65 d24  parking light right
10--10
11-- maximize
Hope this helps , just keep a note of what they are before changing and then easy to go back to that if necessary
Dazza
Hi All,
Cheers Chris
see above  :afro:
10    - 10
11-  maximize
10--10
11-- maximize
Dazza
Many thanks Dazza very much appreciated
Cheers Chris
