Max90 Posted February 10, 2016 Report Share Posted February 10, 2016 Does anyone have an issue where the car changes gear straight after launching? I've done it in the wet and dry in both sport and manual. It spins a bit then decides to change gear and bogs down before picking up again.  Car has a JB1 fitted on the lowest setting (Map 1)  Cheers  Quote Link to comment Share on other sites More sharing options...
Wayne@APRUK Posted February 10, 2016 Report Share Posted February 10, 2016 Traction control fully off? Quote Link to comment Share on other sites More sharing options...
Max90 Posted February 10, 2016 Author Report Share Posted February 10, 2016 Traction control fully off? Yeah I've tried it on both settings! How much is your DSG remap? Quote Link to comment Share on other sites More sharing options...
Shorty Posted February 10, 2016 Report Share Posted February 10, 2016 What month/year is your car? Quote Link to comment Share on other sites More sharing options...
Wayne@APRUK Posted February 10, 2016 Report Share Posted February 10, 2016 Yeah I've tried it on both settings! How much is your DSG remap?  Â£549+ vat, and its BRILLIANT... BUT  I dont think its necessarily going to fix the problem you are having; if its a problem. You do get 30 day money back guarantee though if you dont like it.   Quote Link to comment Share on other sites More sharing options...
H17YD_L Posted February 10, 2016 Report Share Posted February 10, 2016 Does anyone have an issue where the car changes gear straight after launching? I've done it in the wet and dry in both sport and manual. It spins a bit then decides to change gear and bogs down before picking up again. Â Car has a JB1 fitted on the lowest setting (Map 1) Â Cheers Are you sure it changes gear? Run the JB1 in map 0 and try again. Â Also if you sit ready to launch holding the revs does it fluctuate a lot? Quote Link to comment Share on other sites More sharing options...
guy1 Posted February 10, 2016 Report Share Posted February 10, 2016 Does anyone have an issue where the car changes gear straight after launching? I've done it in the wet and dry in both sport and manual. It spins a bit then decides to change gear and bogs down before picking up again.  Car has a JB1 fitted on the lowest setting (Map 1)  Cheers  Mine is fine no issues. Run the JB1 in map 0 and then try.And then try the JB1 in map 1 boost 4.74 or boost 4.8. And then see how it preforms. Map 0 turns JB1 off Quote Link to comment Share on other sites More sharing options...
H17YD_L Posted February 11, 2016 Report Share Posted February 11, 2016 Mine is fine no issues. Run the JB1 in map 0 and then try.And then try the JB1 in map 1 boost 4.74 or boost 4.8. And then see how it preforms. Map 0 turns JB1 off How old is you car? Quote Link to comment Share on other sites More sharing options...
guy1 Posted February 11, 2016 Report Share Posted February 11, 2016 May 2015 Quote Link to comment Share on other sites More sharing options...
H17YD_L Posted February 11, 2016 Report Share Posted February 11, 2016 I had a theory it has something to do with the newer ones, as in the ones that can't be mapped, they must run different firmware/ software. Wonder if yours would be classed as the older one? Quote Link to comment Share on other sites More sharing options...
guy1 Posted February 11, 2016 Report Share Posted February 11, 2016 Have you tried on map 0 to see Quote Link to comment Share on other sites More sharing options...
H17YD_L Posted February 11, 2016 Report Share Posted February 11, 2016 Yes, I have, not sure about the OP Quote Link to comment Share on other sites More sharing options...
Danb7889 Posted February 12, 2016 Report Share Posted February 12, 2016 Its shifting up to combat the wheel spin and then drops back into first gear once it has grip. Â I've seen videos of revo and JB1 cars doing it. Â Your best off plugging the Jb1 in and tweaking the map on map 6. Less boost at 4000 rpm should stop that issue but won't be as quick when driving. Quote Link to comment Share on other sites More sharing options...
H17YD_L Posted February 13, 2016 Report Share Posted February 13, 2016 I used these setting to see how it compares:   And it took off a million times better managed a 0-60 in 3.8 on the vbox  But it was rubbish wen driving normally, no boost until higher up obviously.  Going to start setting up a custom map 6 myself and see if I can get the best of both worlds Quote Link to comment Share on other sites More sharing options...
