Vcds help
mikie22
Im looking at buying vcds. I want to know exactly what i need to buy and also if i do buy it can it be used on multiple laptops/pc's and also multiple cars? Can altering things within vcds affect warranty? Will vw even know its been played around with?
Tia
Tia
Mikie: Hi. What very good questions- thankyou for asking them!
Let's go back a step and consider whether a VCDS cable is really right for you? Nothing wrong with buying a VCDS cable, but it is an expensive unit which really needs to be justified in the current market where there are lots of cheaper alternatives.
So the first question to ask yourself is what level of commitment are you prepared to make to the cable, once it's been purchased? If you intend to be a low level user, then perhaps a less expensive option is appropriate for you.  It also depends on the type of car, but for first time users that don't really know how much they will be using the device, I'd suggest an OBDeleven dongle which works on an Android tablet/mobile and it needs a good internet connection at the workshop for proper use. If you are from the "App generation, then OBD11 will be familiar to you. Also, if you find that you are getting-into OBD stuff, then you can progress into VCDS at a later time
But, if you want to buy a VCDS cable, then the correct cable depends on the age of the car. Older VAG models used what's called "K" lines for their communication's protocol, but newer models use CAN bus (Central Area Network).  For the newer models there are 3 options from Ross Tech,: Micro CAN, HEX -USB+CAN and NET NET (note the latter two also cater for "K" lines)
Micro CAN and HEX-USB+CAN are the older style units and these have unlimited VIN which means that you can use them on many cars without limits. These are also cable based devices which means that there is a cable between the ODBII socket on the car  and the laptop.
HEX NET is the newer style device and has WIFI capabilities  (no cable as an  option). This unit can be purchased with a limit of 10 VINs, or unlimited VINs
if you go to the link below, Ross Tech describe the differences between their cables:
http://store.ross-tech.com/mm5/merchant.mvc?Screen=RTAC&Store_Code=RS
For VCDS, the software is separately downloaded onto your laptop (after you buy the cable) and you can have multiple copies on various laptops because the "Validation" code is in the dongle. You can also update the software at no additional cost, so you only pay a one-off cost.
As for the warranty impact of using the cable, well this really depends on what went wrong with the car and the dealer's attitude to "home mechanics". There is an element of risk, but this risk needs to be tempered with a sense of reasonableness. For example, it would be outrageous for the dealer to argue that your warranty claim for a problem with the ECU was somehow affected by a VCDS change that you made to the door control module (for example). But I have known of some  dealers  to try this. On the other hand, if you have wiped-out the entire code-string on the ABS unit (for example), it will be difficult to claim the repair as a warranty fix -IMO. A certain amount of care is needed in using these cables and whilst making an error normally can be reversed by the user, there are nevertheless serious ramifications for some errors! Don't be fooled into believing that someone else is responsible for fixing the errors that you make with a diagnostic cable- there is only one person accountable for your errors - but,  owning a VCDS cable can open-up a lot of new options for the the user - it's a great product that needs to be used carefully!
