PeteNeedham Posted August 3, 2016 Report Share Posted August 3, 2016 Had my old Bluefin reset and was going to put stage 1 on,connected to car and it would not read my ecu,contacted superchips and sent them the data it did download and they say the car has probably got a re map from somebody else,they recommend having the ecu put back to normal from VW then the bluefin will work.Does this sound right ? Also how do i tell if ive got a re map and will every tuner have this problem with locked ecu. Thanks samswoofer 1 Quote Link to comment Share on other sites More sharing options...
boraboy Posted August 3, 2016 Report Share Posted August 3, 2016 I had a similar problem, took me a few attempts to find someone with the knowledge and software to read it. I asked vw to re-flash the whole thing and they refused It was a guy that had a full original MMPS (not ebay special) and knew how to change the parameters in MMPS to enable him to read it. Where about are you? Quote Link to comment Share on other sites More sharing options...
PeteNeedham Posted August 3, 2016 Author Report Share Posted August 3, 2016 Im in chesterfield,Derbyshire Thing is it might be a good map,cant compare as ive not been in any other golf r (even if it is mapped) Quote Link to comment Share on other sites More sharing options...
PeteNeedham Posted August 3, 2016 Author Report Share Posted August 3, 2016 I was going bluefin route because my st was bluefin stage 3 and was very good,and i kept the handset so just had it reset for the easyest. Yep ive thought about going to stattler are they revo,were abouts in worksop are you,is that near dobbies Quote Link to comment Share on other sites More sharing options...
GrayMK7R Posted August 4, 2016 Report Share Posted August 4, 2016 Bluefin on K04 turbo' cars is terrible. Asks for 110% duty cycle of the turbo - to a non-technical person, basically just turns everything up to max. . What that means is it asks for a LOT from your hardware, unnecessarily. A decent remap (GIAC from Statllers, Or APR, or R-Tech) will get better figures, smoother graphs and exert less strain on your components AwesomeHassan 1 Quote Link to comment Share on other sites More sharing options...
PeteNeedham Posted August 4, 2016 Author Report Share Posted August 4, 2016 Bluefin on K04 turbo' cars is terrible. Asks for 110% duty cycle of the turbo - to a non-technical person, basically just turns everything up to max. . What that means is it asks for a LOT from your hardware, unnecessarily. A decent remap (GIAC from Statllers, Or APR, or R-Tech) will get better figures, smoother graphs and exert less strain on your components Glad it did not work then ,if i went to statllers would they be able to tell what map ive got if its GIAC or REVO,would they charge just for reading.I just presume its got a map on going by the bluefin could not read. Thanks Quote Link to comment Share on other sites More sharing options...
neg Posted August 4, 2016 Report Share Posted August 4, 2016 If its GIAC or Revo I am sure they will be able to tell. If Revo you can check with an SPS and a laptop I think... Quote Link to comment Share on other sites More sharing options...
PeteNeedham Posted August 5, 2016 Author Report Share Posted August 5, 2016 So if i got one of those SPS and tried on my car would it work or are they locked to each car. Quote Link to comment Share on other sites More sharing options...
