Drl Brightness CH/LH
HamidS92
Hey guys,
Quick question for those in the know.
When I had VCDS I changed my ch/lh function to only light up the drl's rather drl's and main beam. I then maxed the brightness of the drl's but want to lower them now.
I don't have vcds anymore but have obd11 so was wondering if anyone knew the coding to lower the drl's as they are pretty bright.
  • Replies 6
Try this:
DRLs brightness:
1. Central Electronics
2. Security and enter 31347
3. Go to Adaptation
4. Search for Leuchte2SL VLB10 and select
5. Select Dimming/Dimmwert CD 2 and change to required setting                       (default 26)
6. Press the green tick to confirm
7. Go back and search for and select Leuchte3SL VRB21
8. Select Dimming/Dimmwert CD 3 and change to required setting                      (default 26)
9. Press the green tick to confirm
Try this:
DRLs brightness:
3. Go to Adaptation
Just tried this now to no avail. Any help?
Sent from my SM-T580 using Tapatalk
The coding you provided changes the brightness of my drl only when main beams are on mate. I'm looking to decrease the brightness of my coming home leaving home drl.
I changed it so that only my drl's light up for coming home leaving home rather than with main beam and remember setting it to 127 but I can't remember which channel it was as I want to lower it. Does that make sense bud?
I've just looked at the settings for the CH/LH with drl and there is no setting for adjusting the brightness. Here's the coding I used for the CH/LH drl:
Coming Home Leaving Home with DRLs:
The basic factory setting for coming/leaving home is through Comfort illumination-Coming Home Leuchten, where the value Low beam is selected. Then what normally happens is that the DRLs are enabled for CH/LH via the Leuchte command Coming Home oder Leaving Home aktiv.
1. Central electrics
2. Security Access 31347
3. Adaptions
4. Search Leuchte6ABL LC5 (left side low beam)
5. Select Lichtfunktion C 6
6. Change setting to Coming Home oder Leaving Home aktiv
7. Select Dimmwert CD 6
8. Change setting to 0
9. Select Dimming Directing CD 6
10. Change setting to minimize
11. Search for Leuchte7ABL RB1 (right side low beam)
12. Select Lichtfunktion C 6
13. Change setting to Coming Home oder Leaving Home aktiv
14. Select Dimmwert CD 6
15. Change setting to 0
16. Select Dimming Directing CD 6
17. Change setting to minimise.
Hope this helps.
