bigp2 Posted August 25, 2017 Report Share Posted August 25, 2017 I tried messing about with Car-Net on my FL R yesterday. I was able to make my iPhone be a personal hotspot and connect via it. Seemed to work ok apart from being unable to find any petrol stations (maybe that's an NI thing). I was hoping when I had my iPhone connected via the lightning cable that it could still tether but Car-Net still seems to want a WLAN connection and that didn't seem to work when the CarPlay was conected. Am I doing something wrong? Can you not have the phone plugged in and still use Car-Net? Quote Link to comment Share on other sites More sharing options...
RichC Posted August 25, 2017 Report Share Posted August 25, 2017 I'm not sure on the answer to this to be honest, but if nobody replies before I grab my lunch I will see if mine does it or not. Quote Link to comment Share on other sites More sharing options...
Delta Posted August 25, 2017 Report Share Posted August 25, 2017 I have had trouble when connected to carplay then trying to connecting to carnet, I did read if you switch off your blutooth it works I did yet this and it did work a fue times but now it dose not auto connect to carnet. Quote Link to comment Share on other sites More sharing options...
Ben23 Posted August 25, 2017 Report Share Posted August 25, 2017 I've always found on mine that the car does need to be connected to the personal hotspot via Wifi for carnet to work and will not use wired tethering via carplay for internet access. The process I go through with mine is... - Phone automatically connects to car via bluetooth as soon as I get in and start up - Open personal hotspot in iphone settings and wait for car to connect which normally takes about 30s (for some reason I have this issue with my iphone that nothing can connect to the personal hotspot unless you have that page open in the settings, after it connects, it is fine to close the settings) - Then connect via USB cable for carplay Seems to work good for me so far with traffic updates, POIs etc. Quote Link to comment Share on other sites More sharing options...
bigp2 Posted August 25, 2017 Author Report Share Posted August 25, 2017 Ok, I'll try it in that order and see if it works. Seems a shame that it can't tether over the USB the way you can on a computer. Quote Link to comment Share on other sites More sharing options...
Growmac Posted August 25, 2017 Report Share Posted August 25, 2017 It's a security feature. Unless it's an Apple device on the same Apple ID, you need the hotspot page open to connect. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Privatedoc Posted August 26, 2017 Report Share Posted August 26, 2017 It's a security feature. Unless it's an Apple device on the same Apple ID, you need the hotspot page open to connect. Sent from my iPhone using TapatalkAnd still the same with iOS 11. Folks, Bit awkward but there is no way to ‘trust’ a personal hotspot that isn’t apple made Quote Link to comment Share on other sites More sharing options...
bigp2 Posted August 26, 2017 Author Report Share Posted August 26, 2017 Waiting for the hotspot to connect and then connecting the lead seemed to work ok. Quote Link to comment Share on other sites More sharing options...
