PetarAudi Posted June 26, 2022 Report Share Posted June 26, 2022 Hi, my VAG was working fine, but one day a lady came with her car. I connected to her dashboard, changed language and then i tried to connect to engine, but suddenly it wasn't able to connect. I tried it then on my car and still the same problem. I select any module, it shows a loading circle on mouse, but nothing happens. Few days ago a check engine light showed up, so i tried to scan it but it showed nothing. The cable test is ok, the interface is ok but it does nothing. Can anyone help? Thank you Quote Link to comment Share on other sites More sharing options...
dv52 Posted June 27, 2022 Report Share Posted June 27, 2022 look at the pins on the OBD port connector - Are any bent, or pushed-in too far? What type of VCDS product is this (XEX+CAN, HEX-NET, VCDS-lite)? Don Quote Link to comment Share on other sites More sharing options...
PetarAudi Posted June 28, 2022 Author Report Share Posted June 28, 2022 18 hours ago, dv52 said: look at the pins on the OBD port connector - Are any bent, or pushed-in too far? What type of VCDS product is this (XEX+CAN, HEX-NET, VCDS-lite)? Don Hi, thanks for your reply. The connectors aren't bent. They're pretty straight accordnig to this gay month...XD Jokes aside. It's HEX V2 Dual-K & CAN. I noticed, that 2 pins are a bit longer. But looks it shoud be like that Quote Link to comment Share on other sites More sharing options...
dv52 Posted June 29, 2022 Report Share Posted June 29, 2022 hmm......... OK. Don't be offended, but I have to ask, did you have the ignition turned-on? If so, navigate to this screen: Select Gateway Installation List, do you get a table of installed modules showing? If so, try accessing the modules again Don Quote Link to comment Share on other sites More sharing options...
