HELP
ARi
  • Replies 11
Yes I'm in the uk
I have been told its a cd installation
If you look at the Kufatec website, you will see the VIM module advertised.
If you crash your car and an Assessor checks your car (highly unlikely I know) your Insurance will be deemed invalid. :afro:
Do you know about the cd unlock trick ?
Nope - a few tried a re-flash of the RNS510 head unit when it came out in the Mk5 R32 but it did not work IIRC.
The Kufatec module works well though - if you need VIM, get onto Kufatec and buy the Module, it's so easy to install. :afro:
Right guys, sorry for the delay! The way i did it was free and pretty easy for any novice like me, although it does of course require burning a CD as i'm sure you're all aware.
Before i explain...
DISCLAIMER: I won't take any resposibility if you break your head unit, do so at your own risk!
Anyway, firstly, i went here:
http://www.robpol86.com/index.php/Fi...IM_Berto89.zip and downloaded the file.
There are two files in the zip. so open this up after you've downloaded them.
VIM_berto.iso is the video in motion file, RECODE_berto.iso is the file to revert back to original settings so i would advise keeping both to your computer for future reference incase you need them at any point.
I then downloaded a programme to burn the files to disk. You can try this: http://download.cnet.com/PowerISO/3000-2646_4-10439118.html although i found it wouldn't work with mac so you'll need a PC. There's bound to be a mac version or something similar somewhere but i just did it on my other halves laptop to saving searching for ever and a day.
Next, open the programme and burn a copy of the VIM file to a CD-R. For some reason i had to burn it a second time as the first time the disk was unrecognised but second time round it was fine so don't be disappointed if at first it doesn't work. Try, try again ;)
Once you've burned the disk, go to the car and do the following:
1) Put the key in, turn the ignition on and then turn it back off. The head unit should stay on.
2) Turn the head unit off
3) Turn the ignition back on but don't fire the car up. LEAVE THE IGNITION ON FOR ALL OF THE PROCESS
4) Press and hold the eject button, the star button (for voice command) and setup button at the same time. It's hit and miss how long you have to hold them for as again when i did the first couple of times it didn't do anything. I just repeated stages 1-4 until something happened. You will see the screen go blank and then it will start to reboot. The reboot screen will have two red bands across the top and bottom and will say to insert a cd to load software.
5) Put your CD in then just wait whilst it loads. It will say a few things and may go off and come back on again but don't panic, just leave it until it comes up with a white screen saying "Software Loading Version (010101). Click OK.
Again, just sit and wait whilst it does its thing.
6) The white screen will reappear with a green box saying "SWL SUCCESS". Again, just wait whilst this screen clears and the CD should eject before it reboots again (it may actually reboot before the CD ejects, i can't remember but you don't need to do anything).
7) That's it, sit back and enjoy. REMEMBER, TRY NOT TO CRASH!
From what i understand, this isn't reprogramming the head unit as such, just adding an extra code to change the speed in which the video stop playback so it shouldn't alter any of the major settings for anything else. As long as you don't go over 150ish mph you should be just fine [WINKING FACE]
I hope this helps you guys but feel free to ask me any questions and i'll do my best to help.
