toosmiles Posted February 20, 2016 Report Share Posted February 20, 2016 Please help guys,ive posted on several forums for help Came to start the car tonight and the key just clicks lights go mad etc,so battery flat Now it's had a new battery on about 6 months ago firstly,the only thing I've done to the car was wire up a secondary led strip into the boot light cables tapping into the original loom,the only thing I seen quickly on the dash was esp fault?? Car was scanned a few weeks ago and nothing came up but sometimes when starting the car it chimed presuming it was a fault? Only other thing I can think of is sometimes the led reverse bulb comes up as a bulb out error on the dash but turn through ignition on/off clears it just ran another scan battery voltage at a tad over 14v on tick over Address 01: Engine (CDL) Labels: 06F-907-115-CDL.clb Part No SW: 1K8 907 115 F HW: 8P0 907 115 B Component: 2.0l R4/4V TFSI* 0040 Revision: 5BH19--- Serial number: Coding: 0403000C1C0F0160 Shop #: WSC 77878 156 427687 VCID: 3162E19FA86469B6C1-8064 3 Faults Found: 008196 - Intake Manifold Flap; Bank 1 P2004 - 002 - Stuck Open Freeze Frame: Fault Status: 01100010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 78231 km Time Indication: 0 Date: 2010.06.02 Time: 15:19:26 Freeze Frame: RPM: 751 /min Load: 16.1 % Speed: 0.0 km/h Temperature: 83.0°C Temperature: 29.0°C Absolute Pres.: 970.0 mbar Voltage: 13.843 V 008212 - Intake Manifold Flap Position Sensor (Bank 1) P2014 - 001 - Electrical Malfunction - MIL ON Freeze Frame: Fault Status: 11100001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 78231 km Time Indication: 0 Date: 2010.06.02 Time: 15:19:27 Freeze Frame: RPM: 753 /min Load: 16.1 % Speed: 0.0 km/h Temperature: 84.0°C Temperature: 29.0°C Absolute Pres.: 970.0 mbar Voltage: 13.970 V 001089 - EVAP Emission Control Sys P0441 - 002 - Incorrect Flow - MIL ON Freeze Frame: Fault Status: 11100010 Fault Priority: 2 Fault Frequency: 7 Reset counter: 255 Mileage: 78260 km Time Indication: 0 Date: 2010.06.05 Time: 14:19:55 Freeze Frame: RPM: 749 /min Load: 18.0 % Speed: 0.0 km/h Temperature: 84.0°C Temperature: 14.0°C Absolute Pres.: 1000.0 mbar Voltage: 14.097 V Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 02E-927-770.lbl Part No SW: 02E 300 012 N HW: 02E 927 770 AL Component: GSG DSG AG6 511 2118 Revision: 51112 Serial number: 00001001280968 Coding: 0000020 Shop #: WSC 01357 011 00200 VCID: 1B3E2337DAE8F3E68B-804E No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ Component: ESP MK60EC1 H30 0107 Revision: 00H30001 Coding: 163B800D092500FA681301E7901C00813D0000 Shop #: WSC 01357 011 00200 VCID: 7AF006B3F5926AEE30-802E No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb Part No SW: 5K0 907 044 BS HW: 5K0 907 044 BS Component: Climatronic H15 0709 Revision: 00003001 Coding: 0000000002 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_Climatronic A01006 ROD: EV_ClimaAutoBasis_VW36.rod VCID: 7DFA0DAFECBC5DD615-8028 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb Part No SW: 1K0 937 087 D HW: 1K0 937 087 D Component: BCM PQ35 H 103 0575 Revision: 00103 AG Coding: 44180A38E825F10084080080250008E447F50088737D8960E48040240000 Shop #: WSC 01357 011 00200 VCID: 3260EE936D6252AEB8-8066 Subsystem 1 - Part No: 1K2 955 119 F Labels: 1KX-955-119.CLB Component: Wischer 16021 21 0512 Coding: 009F95 Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB Component: RLS 170210 05 54 0403 Coding: 0730AD Subsystem 3 - Part No: 1K8 951 171 Component: DWA-Sensor 00 001 0104 Subsystem 4 - Part No: 1K8 951 605 Component: LIN BACKUP HO H09 9002 4 Faults Found: 01518 - Bulb for Back-Up Lights; Left (M16) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 2 Fault Frequency: 34 Reset counter: 155 Mileage: 78240 km Time Indication: 0 Date: 2010.06.05 Time: 11:37:07 Freeze Frame: Term 15 On Voltage: 11.00 V ON ON Term 50 Off OFF OFF 00153 - Windshield Wiper Motor; Driver Side (V216) 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 193 Mileage: 78809 km Time Indication: 0 Date: 2010.07.12 Time: 20:08:36 Freeze Frame: Term 15 On Voltage: 9.45 V ON ON Term 50 Off OFF OFF 01520 - Rain and Light Recognition Sensor (G397) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 2 Reset counter: 188 Mileage: 78607 km Time Indication: 0 Freeze Frame: Term 15 Off Voltage: 12.00 V OFF ON Term 50 Off OFF OFF 01520 - Rain and Light Recognition Sensor (G397) 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 193 Time Indication: 0 Freeze Frame: Term 15 On Voltage: 10.10 V ON ON Term 50 Off OFF OFF ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb Part No SW: 5K0 919 475 D HW: 5K0 919 475 Component: PARKHILFE 8K H07 0010 Revision: -------- Serial number: 48331000300325 Coding: 100104 Shop #: WSC 01357 011 00200 VCID: 3776DF878600B7868F-8062 No fault code found. ------------------------------------------------------------------------------- Address 14: Susp. Elect. (J250) Labels: None Part No SW: 3C0 907 376 A HW: 3C0 907 376 Component: DAEMPFUNGS-SG H07 0071 Revision: 00000000 Serial number: 18021006540001 Coding: 000180 Shop #: WSC 12705 000 1048576 VCID: 27560FC756A027061F-8072 5 Faults Found: 00142 - Left Front Dampening Adjustment Valve (N336) 011 - Open Circuit - MIL ON Freeze Frame: Fault Status: 11101011 Fault Priority: 2 Fault Frequency: 1 Reset counter: 91 Time Indication: 0 Freeze Frame: Bin. Bits: 00000000 00100000 00143 - Front Right Dampening Adjustment Valve (N337) 011 - Open Circuit - MIL ON Freeze Frame: Fault Status: 11101011 Fault Priority: 2 Fault Frequency: 1 Reset counter: 91 Time Indication: 0 Freeze Frame: Bin. Bits: 00000000 00100000 00144 - Rear Left Dampening Adjustment Valve (N338) 011 - Open Circuit - MIL ON Freeze Frame: Fault Status: 11101011 Fault Priority: 2 Fault Frequency: 1 Reset counter: 91 Time Indication: 0 Freeze Frame: Bin. Bits: 00000000 00100000 00145 - Rear Right Dampening Adjustment Valve (N339) 011 - Open Circuit - MIL ON Freeze Frame: Fault Status: 11101011 Fault Priority: 2 Fault Frequency: 1 Reset counter: 91 Time Indication: 0 Freeze Frame: Bin. Bits: 00000000 00100000 03264 - Functionalty Shut Off 000 - - - MIL ON Freeze Frame: Fault Status: 11100000 Fault Priority: 6 Fault Frequency: 144 Reset counter: 155 Mileage: 78231 km Time Indication: 0 Date: 2010.06.02 Time: 19:11:12 Freeze Frame: Error Code: 9 Bin. Bits: 00000000 ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: 5K0-959-655.clb Part No SW: 5K0 959 655 D HW: 5K0 959 655 D Component: AirbagVW10 037 0606 Serial number: 003FKRA3ZB3+ Coding: 00003135 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_AirbaVW10SMEVW360 A01011 ROD: EV_AirbaVW10SMEVW360_SE36.rod VCID: 3B7EC3B7B22893E66B-806E Crash sensor for side airbag; driver side: Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354 Component: S.Sens.Fahr.V H01 ---- Serial number: 3572MSME7C0F614FZZZA Crash sensor for side airbag; front passenger side: Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354 Component: S.Sens.Beif.V H01 ---- Serial number: 3582MSME30531150ZZZC Crash sensor for side airbag; rear; driver side: Component: S.Sens.Fahr.H --- ---- Serial number: 3512QSME3C2B4F7EZZZG Crash sensor for side airbag; rear; passenger side: Component: S.Sens.Beif.H --- ---- Serial number: 3522QSME38104E4AZZZ- No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD Component: J0527 056 0111 Coding: 0001832 Shop #: WSC 00445 210 105457 VCID: 76E81283018A0E8E54-8022 Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB Component: E221__MFL-TAS H05 0010 Coding: 00000131 Shop #: WSC 00000 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb Part No SW: 5K6 920 970 F HW: 5K6 920 970 F Component: KOMBI H03 0305 Serial number: 00000000000000 Coding: 170F00 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052 ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod VCID: 3776DF878E00B7868F-8062 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb Part No SW: 1K0 907 530 AD HW: 1K0 907 951 Component: J533 Gateway H07 0112 Revision: H07 01 Serial number: 150210F1000207 Coding: EDAB1F06500612000001 Shop #: WSC 00445 210 105436 VCID: 69D249FF4034D176C9-803C No fault code found. ------------------------------------------------------------------------------- Address 22: AWD Labels: 0AY-907-554-V1.clb Part No SW: 0BR 907 554 A HW: 0BR 907 554 A Component: Haldex 4Motion 3016 Coding: 0000005 Shop #: WSC 00000 000 00000 VCID: 438EBB5702D8EB2623-8016 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb Part No SW: 5K0 953 234 HW: 5K0 953 234 Component: IMMO H03 0305 Serial number: 00000000000000 Coding: 000000 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005 ROD: EV_Immo_UDS_VDD_RM09_SE25.rod VCID: 6AD036F38D32DA6EC0-803E No fault code found. ------------------------------------------------------------------------------- Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl Part No SW: 5N0 035 342 B HW: 5N0 035 342 B Component: SG EXT.PLAYER H13 0090 Revision: A1001003 Serial number: 7667825375 Coding: 010000 Shop #: WSC 01357 011 00200 VCID: 264802C351AA3E0E24-8072 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation (J0506) Labels: 1T0-035-680.clb Part No SW: 1T0 035 680 L HW: 1T0 035 680 B Component: RNS-MID H11 5274 Revision: AB001001 Serial number: VWZ6Z7K8021117 Coding: 04050002010000A02000 Shop #: WSC 00445 210 105436 VCID: 3776DF878600B7868F-8062 Subsystem 1 - Part No: 1T0 919 859 B Component: EU West V13 8348 1 Fault Found: 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 5 Fault Frequency: 1 Reset counter: 193 Mileage: 78809 km Time Indication: 0 Date: 2010.07.12 Time: 20:08:46 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl Part No SW: 5K0 959 701 C HW: 5K0 959 701 C Component: Tuer-SG 009 2118 Coding: 0004662 Shop #: WSC 01357 011 00200 VCID: 3260EE93AD6252AEB8-8066 1 Fault Found: 00131 - Outside Door Handle Illumination/mirror Light Driver Side 012 - Electrical Fault in Circuit - Intermittent ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb Part No: 5N0 909 144 J Component: EPS_ZFLS Kl. 251 3001 Revision: 00H17000 Shop #: WSC 01357 011 00200 VCID: 3874DCBB4B1EB8FE86-806C No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System (R12) Labels: 5K0-035-456.clb Part No SW: 5K0 035 456 HW: 5K0 035 456 Component: KonzernAmp 8K H06 0340 Revision: -------- Serial number: BP218198836093 ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003 ROD: EV_AudioVerst8KanalBNO1.rod VCID: 67D64FC79E20E706DF-8032 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl Part No SW: 5K0 959 702 C HW: 5K0 959 702 C Component: Tuer-SG 009 2118 Coding: 0004918 Shop #: WSC 01357 011 00200 VCID: 336EEB9752785BA6B3-8066 1 Fault Found: 00132 - Outside Door Handle Illumination/mirror Light Passenger Side 012 - Electrical Fault in Circuit - Intermittent ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl Part No SW: 5M0 907 357 C HW: 5M0 907 357 C Component: AFS-Steuergeraet 0142 Revision: 00H04000 Serial number: Coding: 1477980 Shop #: WSC 01357 011 00200 VCID: 346CE88B57765C9EAA-8060 Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB Component: AFS-Lst.-Modul l 0004 Coding: 00000022 Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB Component: AFS-Lst.-Modul r 0004 Coding: 00000022 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J0506) Labels: 1T0-035-680.clb Part No SW: 1T0 035 680 L HW: 1T0 035 680 B Component: RNS-MID H11 5274 Revision: AB001001 Serial number: VWZ6Z7K8021117 Coding: 04050002010000A02000 Shop #: WSC 00445 210 105436 VCID: 3776DF878600B7868F-8062 Subsystem 1 - Part No: 1T0 919 859 B Component: EU West V13 8348 1 Fault Found: 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 5 Fault Frequency: 1 Reset counter: 193 Mileage: 78809 km Time Indication: 0 Date: 2010.07.12 Time: 20:08:46 ------------------------------------------------------------------------------- Address 77: Telephone (J412) Labels: 7P6-035-730.clb Part No SW: 7P6 035 730 J HW: 7P6 035 730 J Component: TELEFON H15 3200 Revision: 1B001001 Serial number: 00007663954374 Coding: 0211000000010110 Shop #: WSC 12345 123 12345 ASAM Dataset: EV_UHVNA 002720 ROD: EV_UHVNA.rod VCID: 3972D9BFB814A1F679-806C No fault code found. End-------------------------(Elapsed Time: 03:19)-------------------------- Saturday,20,February,2016,10:27:48:19763 VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86 VCDS Version: 15.7.4.1 Data version: 20160216 www.Ross-Tech.com VIN: WVWZZZ1KZAW330833 License Plate: CV10VWA Mileage: 78830km-48982mi Repair Order: Chassis Type: 1K (1K0) Scan: 01 02 03 08 09 10 14 15 16 17 19 22 25 2E 37 42 44 46 47 52 55 56 77 VIN: WVWZZZ1KZAW330833 Mileage: 78830km-48982miles 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 14-Susp. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 22-AWD -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 2E-Media Player 3 -- Status: OK 0000 37-Navigation -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (CDL) Labels: 06F-907-115-CDL.clb Part No SW: 1K8 907 115 F HW: 8P0 907 115 B Component: 2.0l R4/4V TFSI* 0040 Revision: 5BH19--- Serial number: Coding: 0403000C1C0F0160 Shop #: WSC 77878 156 427687 VCID: 3162E19FA86469B6C1-8064 3 Faults Found: 008196 - Intake Manifold Flap; Bank 1 P2004 - 002 - Stuck Open Freeze Frame: Fault Status: 01100010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 78231 km Time Indication: 0 Date: 2010.06.02 Time: 15:19:26 Freeze Frame: RPM: 751 /min Load: 16.1 % Speed: 0.0 km/h Temperature: 83.0°C Temperature: 29.0°C Absolute Pres.: 970.0 mbar Voltage: 13.843 V 008212 - Intake Manifold Flap Position Sensor (Bank 1) P2014 - 001 - Electrical Malfunction - MIL ON Freeze Frame: Fault Status: 11100001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 78231 km Time Indication: 0 Date: 2010.06.02 Time: 15:19:27 Freeze Frame: RPM: 753 /min Load: 16.1 % Speed: 0.0 km/h Temperature: 84.0°C Temperature: 29.0°C Absolute Pres.: 970.0 mbar Voltage: 13.970 V 001089 - EVAP Emission Control Sys P0441 - 002 - Incorrect Flow - MIL ON Freeze Frame: Fault Status: 11100010 Fault Priority: 2 Fault Frequency: 7 Reset counter: 255 Mileage: 78260 km Time Indication: 0 Date: 2010.06.05 Time: 14:19:55 Freeze Frame: RPM: 749 /min Load: 18.0 % Speed: 0.0 km/h Temperature: 84.0°C Temperature: 14.0°C Absolute Pres.: 1000.0 mbar Voltage: 14.097 V Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 02E-927-770.lbl Part No SW: 02E 300 012 N HW: 02E 927 770 AL Component: GSG DSG AG6 511 2118 Revision: 51112 Serial number: 00001001280968 Coding: 0000020 Shop #: WSC 01357 011 00200 VCID: 1B3E2337DAE8F3E68B-804E No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ Component: ESP MK60EC1 H30 0107 Revision: 00H30001 Coding: 163B800D092500FA681301E7901C00813D0000 Shop #: WSC 01357 011 00200 VCID: 7AF006B3F5926AEE30-802E No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb Part No SW: 5K0 907 044 BS HW: 5K0 907 044 BS Component: Climatronic H15 0709 Revision: 00003001 Coding: 0000000002 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_Climatronic A01006 ROD: EV_ClimaAutoBasis_VW36.rod VCID: 7DFA0DAFECBC5DD615-8028 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb Part No SW: 1K0 937 087 D HW: 1K0 937 087 D Component: BCM PQ35 H 103 0575 Revision: 00103 AG Coding: 44180A38E825F10084080080250008E447F50088737D8960E48040240000 Shop #: WSC 01357 011 00200 VCID: 3260EE936D6252AEB8-8066 Subsystem 1 - Part No: 1K2 955 119 F Labels: 1KX-955-119.CLB Component: Wischer 16021 21 0512 Coding: 009F95 Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB Component: RLS 170210 05 54 0403 Coding: 0730AD Subsystem 3 - Part No: 1K8 951 171 Component: DWA-Sensor 00 001 0104 Subsystem 4 - Part No: 1K8 951 605 Component: LIN BACKUP HO H09 9002 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb Part No SW: 5K0 919 475 D HW: 5K0 919 475 Component: PARKHILFE 8K H07 0010 Revision: -------- Serial number: 48331000300325 Coding: 100104 Shop #: WSC 01357 011 00200 VCID: 3776DF878600B7868F-8062 No fault code found. ------------------------------------------------------------------------------- Address 14: Susp. Elect. (J250) Labels: None Part No SW: 3C0 907 376 A HW: 3C0 907 376 Component: DAEMPFUNGS-SG H07 0071 Revision: 00000000 Serial number: 18021006540001 Coding: 000180 Shop #: WSC 12705 000 1048576 VCID: 27560FC756A027061F-8072 5 Faults Found: 00142 - Left Front Dampening Adjustment Valve (N336) 011 - Open Circuit - MIL ON Freeze Frame: Fault Status: 11101011 Fault Priority: 2 Fault Frequency: 1 Reset counter: 155 Mileage: 78831 km Time Indication: 0 Date: 2010.07.13 Time: 10:22:54 Freeze Frame: Bin. Bits: 00000000 00100000 00143 - Front Right Dampening Adjustment Valve (N337) 011 - Open Circuit - MIL ON Freeze Frame: Fault Status: 11101011 Fault Priority: 2 Fault Frequency: 1 Reset counter: 155 Mileage: 78831 km Time Indication: 0 Date: 2010.07.13 Time: 10:22:54 Freeze Frame: Bin. Bits: 00000000 00100000 00144 - Rear Left Dampening Adjustment Valve (N338) 011 - Open Circuit - MIL ON Freeze Frame: Fault Status: 11101011 Fault Priority: 2 Fault Frequency: 1 Reset counter: 155 Mileage: 78831 km Time Indication: 0 Date: 2010.07.13 Time: 10:22:54 Freeze Frame: Bin. Bits: 00000000 00100000 00145 - Rear Right Dampening Adjustment Valve (N339) 011 - Open Circuit - MIL ON Freeze Frame: Fault Status: 11101011 Fault Priority: 2 Fault Frequency: 1 Reset counter: 155 Mileage: 78831 km Time Indication: 0 Date: 2010.07.13 Time: 10:22:54 Freeze Frame: Bin. Bits: 00000000 00100000 03264 - Functionalty Shut Off 000 - - - MIL ON Freeze Frame: Fault Status: 11100000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 155 Mileage: 78831 km Time Indication: 0 Date: 2010.07.13 Time: 10:22:54 Freeze Frame: Error Code: 9 Bin. Bits: 00000000 ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: 5K0-959-655.clb Part No SW: 5K0 959 655 D HW: 5K0 959 655 D Component: AirbagVW10 037 0606 Serial number: 003FKRA3ZB3+ Coding: 00003135 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_AirbaVW10SMEVW360 A01011 ROD: EV_AirbaVW10SMEVW360_SE36.rod VCID: 3B7EC3B7B22893E66B-806E Crash sensor for side airbag; driver side: Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354 Component: S.Sens.Fahr.V H01 ---- Serial number: 3572MSME7C0F614FZZZA Crash sensor for side airbag; front passenger side: Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354 Component: S.Sens.Beif.V H01 ---- Serial number: 3582MSME30531150ZZZC Crash sensor for side airbag; rear; driver side: Component: S.Sens.Fahr.H --- ---- Serial number: 3512QSME3C2B4F7EZZZG Crash sensor for side airbag; rear; passenger side: Component: S.Sens.Beif.H --- ---- Serial number: 3522QSME38104E4AZZZ- No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD Component: J0527 056 0111 Coding: 0001832 Shop #: WSC 00445 210 105457 VCID: 76E81283018A0E8E54-8022 Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB Component: E221__MFL-TAS H05 0010 Coding: 00000131 Shop #: WSC 00000 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb Part No SW: 5K6 920 970 F HW: 5K6 920 970 F Component: KOMBI H03 0305 Serial number: 00000000000000 Coding: 170F00 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052 ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod VCID: 3776DF878E00B7868F-8062 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb Part No SW: 5K6 920 970 F HW: 5K6 920 970 F Component: KOMBI H03 0305 Serial number: 00000000000000 Coding: 170F00 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052 ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod VCID: 3776DF878E00B7868F-8062 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb Part No SW: 1K0 907 530 AD HW: 1K0 907 951 Component: J533 Gateway H07 0112 Revision: H07 01 Serial number: 150210F1000207 Coding: EDAB1F06500612000001 Shop #: WSC 00445 210 105436 VCID: 69D249FF4034D176C9-803C No fault code found. ------------------------------------------------------------------------------- Address 22: AWD Labels: 0AY-907-554-V1.clb Part No SW: 0BR 907 554 A HW: 0BR 907 554 A Component: Haldex 4Motion 3016 Coding: 0000005 Shop #: WSC 00000 000 00000 VCID: 438EBB5702D8EB2623-8016 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb Part No SW: 5K0 953 234 HW: 5K0 953 234 Component: IMMO H03 0305 Serial number: 00000000000000 Coding: 000000 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005 ROD: EV_Immo_UDS_VDD_RM09_SE25.rod VCID: 6AD036F38D32DA6EC0-803E No fault code found. ------------------------------------------------------------------------------- Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl Part No SW: 5N0 035 342 B HW: 5N0 035 342 B Component: SG EXT.PLAYER H13 0090 Revision: A1001003 Serial number: 7667825375 Coding: 010000 Shop #: WSC 01357 011 00200 VCID: 264802C351AA3E0E24-8072 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation (J0506) Labels: 1T0-035-680.clb Part No SW: 1T0 035 680 L HW: 1T0 035 680 B Component: RNS-MID H11 5274 Revision: AB001001 Serial number: VWZ6Z7K8021117 Coding: 04050002010000A02000 Shop #: WSC 00445 210 105436 VCID: 3776DF878600B7868F-8062 Subsystem 1 - Part No: 1T0 919 859 B Component: EU West V13 8348 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl Part No SW: 5K0 959 701 C HW: 5K0 959 701 C Component: Tuer-SG 009 2118 Coding: 0004662 Shop #: WSC 01357 011 00200 VCID: 3260EE93AD6252AEB8-8066 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb Part No: 5N0 909 144 J Component: EPS_ZFLS Kl. 251 3001 Revision: 00H17000 Shop #: WSC 01357 011 00200 VCID: 3874DCBB4B1EB8FE86-806C No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System (R12) Labels: 5K0-035-456.clb Part No SW: 5K0 035 456 HW: 5K0 035 456 Component: KonzernAmp 8K H06 0340 Revision: -------- Serial number: BP218198836093 ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003 ROD: EV_AudioVerst8KanalBNO1.rod VCID: 67D64FC79E20E706DF-8032 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl Part No SW: 5K0 959 702 C HW: 5K0 959 702 C Component: Tuer-SG 009 2118 Coding: 0004918 Shop #: WSC 01357 011 00200 VCID: 336EEB9752785BA6B3-8066 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl Part No SW: 5M0 907 357 C HW: 5M0 907 357 C Component: AFS-Steuergeraet 0142 Revision: 00H04000 Serial number: Coding: 1477980 Shop #: WSC 01357 011 00200 VCID: 346CE88B57765C9EAA-8060 Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB Component: AFS-Lst.-Modul l 0004 Coding: 00000022 Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB Component: AFS-Lst.-Modul r 0004 Coding: 00000022 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J0506) Labels: 1T0-035-680.clb Part No SW: 1T0 035 680 L HW: 1T0 035 680 B Component: RNS-MID H11 5274 Revision: AB001001 Serial number: VWZ6Z7K8021117 Coding: 04050002010000A02000 Shop #: WSC 00445 210 105436 VCID: 3776DF878600B7868F-8062 Subsystem 1 - Part No: 1T0 919 859 B Component: EU West V13 8348 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone (J412) Labels: 7P6-035-730.clb Part No SW: 7P6 035 730 J HW: 7P6 035 730 J Component: TELEFON H15 3200 Revision: 1B001001 Serial number: 00007663954374 Coding: 0211000000010110 Shop #: WSC 12345 123 12345 ASAM Dataset: EV_UHVNA 002720 ROD: EV_UHVNA.rod VCID: 3972D9BFB814A1F679-806C No fault code found. End-------------------------(Elapsed Time: 03:15)-------------------------- the evap fault is because of my charcoal can delete and the suspension faults due to the dcc removed for coilovers,also rfd delete Just another thing to add my 1 touch driver window switch ain't working,reset a few different ways with no luck,if the car has been sat for a few days also the puddle lights won't come on and when getting in the car the interior lights and mfd go out straight away?? As if it needs a kick start lol cheers Quote Link to comment Share on other sites More sharing options...
toosmiles Posted February 20, 2016 Author Report Share Posted February 20, 2016 new scan and all clear apart from the rfd/dcc and evap,1 thing about the RNS,i was sat still in the car for over 3 mins and the system was still running even though it had a black screen?? RNS-mid H11 5274 EU West V13 Quote Link to comment Share on other sites More sharing options...
toosmiles Posted February 20, 2016 Author Report Share Posted February 20, 2016 Rns is ok its just the fan cooling the system ive removed the led strip from the boot and disconnected the flickering led in the glovebox,dont know what else to do now Quote Link to comment Share on other sites More sharing options...
Andrew Posted February 20, 2016 Report Share Posted February 20, 2016 Get yourself a multimeter and test for parasitic drain off the battery a few minutes after you've locked the car and everything is off. That's all I can suggest and take it from there. I had a similar issue a 6 months or so ago when my radio would occasionally not turn off after leaving the car which was odd. It was intermittent and has never returned although I updated the firmware and the problem has never reoccurred since. Quote Link to comment Share on other sites More sharing options...
toosmiles Posted February 21, 2016 Author Report Share Posted February 21, 2016 Get yourself a multimeter and test for parasitic drain off the battery a few minutes after you've locked the car and everything is off. That's all I can suggest and take it from there. I had a similar issue a 6 months or so ago when my radio would occasionally not turn off after leaving the car which was odd. It was intermittent and has never returned although I updated the firmware and the problem has never reoccurred since. thanks for the advice andrew,what voltage do you think will drop after a few mins to give me an idea Quote Link to comment Share on other sites More sharing options...
Andrew Posted February 21, 2016 Report Share Posted February 21, 2016 Less than 30 milliamps after 5 minutes I think. Quote Link to comment Share on other sites More sharing options...
Andrew Posted February 21, 2016 Report Share Posted February 21, 2016 There is a good chance that the comfort module is remaining active after you shut down the car resulting in a high current draw which will drain your battery. The comfort control module is supposed to go into a "sleep" mode after the car is shut down after a period of time thereby reducing its current draw considerably from its active state. Many times a faulty switch / wiring can keep the module active after the car is shut down. My guess iswhen you lock the doors, the comfort module is not getting an indication that all doors and trunk have indeed locked or that the indication has subsequently changed. Did the alarm go off? Sometimes the alarm will go off when the battery starts to get low as it thinks someone is interfering with the power supply and will sound, which further flattens the battery. Does your battery drain if you leave your car unlocked? Quote Link to comment Share on other sites More sharing options...
toosmiles Posted February 21, 2016 Author Report Share Posted February 21, 2016 thanks for the info andrew, the only thing that comes to mind is my window switch has lost its 1 touch feature but this still works normal,alarm hasnt gone off luckily but this esp fault popped up a fair few times i remember over the past few weeks wonder how you can test the car for its 'comfort' mode to see if it does go into sleep after all been locked up? Quote Link to comment Share on other sites More sharing options...
dv52 Posted February 21, 2016 Report Share Posted February 21, 2016 toosmiles: Hello, I can vaguely recall reading (somewhere - can't remember where now) that LED boot lights can sometimes cause a parasitic battery drain. My suggestion is that you make sure that the newly installed boot LEDs actually extinguish when the car goes to sleep. You could do this by folding back the rear seats at night, and locking the vehicle (don't sit in the front seat-else you will trigger the occupant seat switch). Look into the boot and see if the LEDs are glowing faintly. Andrew's suggestion about the Multimeter is a good one to try- but you need to measure amps, not voltage This necessitates removing one of the battery leads, so expect multiple alarms to occur when you hook-up the multi-meter (on the current setting with the leads on "current" socket) and when you restore the battery lead onto the battery terminal. A short trip in the car should clear these alarms. The final question that might be pertinent to your case is: how have you charged the battery? The reason that I ask is because it is likely that your car has a battery monitor control module attached to the negative battery cable. It's VERY important on a mk7 to ensure that the current from a battery charger is "seen" by the battery monitor. Not sure if you are aware, but the mk7 calculates a variable called "System Voltage" (which is different to battery-voltage) and this parameter (not battery-voltage) is used by all the control modules in making decisions about the health of the supply rail. The battery monitor provides the data for this calculation. So if you are charging the battery by placing the charger negative lead directly onto the battery negative lead, then you are by-passing the battery monitor and the System Voltage calculation will be wrong! It might be worth checking the SOC (state-of-charge) of the battery as seen by the control modules to verify what the car's calculated System Voltage is. Assuming that you have SOC enabled on your car, this is done by pressing and holding the 0.0 button while the ignition switch is turned-on (check your manual for the procedure) Don andy3141 1 Quote Link to comment Share on other sites More sharing options...
toosmiles Posted February 22, 2016 Author Report Share Posted February 22, 2016 toosmiles: Hello, I can vaguely recall reading (somewhere - can't remember where now) that LED boot lights can sometimes cause a parasitic battery drain. My suggestion is that you make sure that the newly installed boot LEDs actually extinguish when the car goes to sleep. You could do this by folding back the rear seats at night, and locking the vehicle (don't sit in the front seat-else you will trigger the occupant seat switch). Look into the boot and see if the LEDs are glowing faintly. Andrew's suggestion about the Multimeter is a good one to try- but you need to measure amps, not voltage This necessitates removing one of the battery leads, so expect multiple alarms to occur when you hook-up the multi-meter (on the current setting with the leads on "current" socket) and when you restore the battery lead onto the battery terminal. A short trip in the car should clear these alarms. The final question that might be pertinent to your case is: how have you charged the battery? The reason that I ask is because it is likely that your car has a battery monitor control module attached to the negative battery cable. It's VERY important on a mk7 to ensure that the current from a battery charger is "seen" by the battery monitor. Not sure if you are aware, but the mk7 calculates a variable called "System Voltage" (which is different to battery-voltage) and this parameter (not battery-voltage) is used by all the control modules in making decisions about the health of the supply rail. The battery monitor provides the data for this calculation. So if you are charging the battery by placing the charger negative lead directly onto the battery negative lead, then you are by-passing the battery monitor and the System Voltage calculation will be wrong! It might be worth checking the SOC (state-of-charge) of the battery as seen by the control modules to verify what the car's calculated System Voltage is. Assuming that you have SOC enabled on your car, this is done by pressing and holding the 0.0 button while the ignition switch is turned-on (check your manual for the procedure) Don thanks for your advice don,very helpful the car was driven yesterday about 5 clk so ill go and test it for power levels,would you suggest i stick a trickle charger on it for a while? ive got a solar panel charger 1 on it now Quote Link to comment Share on other sites More sharing options...
toosmiles Posted February 22, 2016 Author Report Share Posted February 22, 2016 boot light completely disconnected now car tested at 12.0v with car unlocked,locked car with a drop to 11.8v then sat back at 12.0v ill test again in half an hour with the meter left on Quote Link to comment Share on other sites More sharing options...
toosmiles Posted February 22, 2016 Author Report Share Posted February 22, 2016 half an hour later and still reading 12.0v,ill check later on Quote Link to comment Share on other sites More sharing options...
toosmiles Posted February 22, 2016 Author Report Share Posted February 22, 2016 Still keeping 12v all day checked all cables and plugged boot led back in,now after 10 seconds the interior lights dim and the boot led stays on dim now this does go off completely when the doors are locked but noticed when plugging the glove box led in the dim bulb goes out completely and they all stay off and keep at 12 v after 10 mins??? The only other thing that come to mind was the glove box led metal surround was touching a screw in the dash when put back into place??? Why would the bulb dim when the glove box led is disconnected? dv52 1 Quote Link to comment Share on other sites More sharing options...
dv52 Posted February 23, 2016 Report Share Posted February 23, 2016 Still keeping 12v all day checked all cables and plugged boot led back in,now after 10 seconds the interior lights dim and the boot led stays on dim now this does go off completely when the doors are locked but noticed when plugging the glove box led in the dim bulb goes out completely and they all stay off and keep at 12 v after 10 mins??? The only other thing that come to mind was the glove box led metal surround was touching a screw in the dash when put back into place??? Why would the bulb dim when the glove box led is disconnected? hm.......... not sure that I entirely understand what you are saying, but something sounds screwy! Also concerned about the 12V reading - a healthy battery should be about 13.8 volts. But this could be due to where you are placing the meter leads and the quality of the meter. So, after your latest investigations, do you have a hypothesis? Quote Link to comment Share on other sites More sharing options...
toosmiles Posted February 23, 2016 Author Report Share Posted February 23, 2016 Hey m8, I wasn't to sure what was going on myself lol I still can't understand the problem I've got a decent meter aswell which is put straight onto the battery terminals while the battery is connected Do I need to charge the battery up again first? I'll check shortly is there's been any difference over night Cheers Quote Link to comment Share on other sites More sharing options...
