HamidS92 Posted June 30, 2016 Report Share Posted June 30, 2016 Does anyone know how to disable the the led dot in the middle of the inner U? Not sure if that's the parking light mod for bi-xenon cars such as ours. Thanks Sent from my SM-G935F using Tapatalk Sent from my SM-G935F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Rich_D Posted June 30, 2016 Report Share Posted June 30, 2016 I leave mine on auto and I don't think the dot comes on, only seems to come on if you turn them on manually? Quote Link to comment Share on other sites More sharing options...
neg Posted June 30, 2016 Report Share Posted June 30, 2016 I think they come on with the headlights only. Quote Link to comment Share on other sites More sharing options...
HamidS92 Posted June 30, 2016 Author Report Share Posted June 30, 2016 If I switch to sidelights the double u light up and the dot is on. I don't really like it tbh and was hoping to find a way to turn it off. I can see that near the top of the photo. Is that the best option? Sent from my SM-G935F using Tapatalk Quote Link to comment Share on other sites More sharing options...
neg Posted June 30, 2016 Report Share Posted June 30, 2016 Worth try - sounds like its on the right track. Assuming that the amber and inner LED are linked together on non-uk cars. Quote Link to comment Share on other sites More sharing options...
Rich_D Posted June 30, 2016 Report Share Posted June 30, 2016 Why do you use sidelights? DRL's and auto lights mean you never need to use the switch Stobsie 1 Quote Link to comment Share on other sites More sharing options...
HamidS92 Posted June 30, 2016 Author Report Share Posted June 30, 2016 The auto lights come on early at times so leave it in sidelights until I need main beams Sent from my SM-G935F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Rich_D Posted July 1, 2016 Report Share Posted July 1, 2016 DRL's are on all the time though Quote Link to comment Share on other sites More sharing options...
HamidS92 Posted July 1, 2016 Author Report Share Posted July 1, 2016 But if it's slightly dark my headlights will come on in auto...but it's too early for headlights so I switch to headlights to have drl only but see the little dot and if prefer not to have it on Sent from my SM-G935F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Rich_D Posted July 1, 2016 Report Share Posted July 1, 2016 Turn the switch to the off position and the DRL's will be on without the dot You can also change the auto headlight sensitivity to 'later' so they're less sensitive. Quote Link to comment Share on other sites More sharing options...
HamidS92 Posted July 1, 2016 Author Report Share Posted July 1, 2016 Turn the switch to the off position and the DRL's will be on without the dot You can also change the auto headlight sensitivity to 'later' so they're less sensitive. You know I've never tried the off position...i assume all would be off including drl. Thanks for that mate will also try the headlight sensitivity too Sent from my SM-G935F using Tapatalk Rich_D 1 Quote Link to comment Share on other sites More sharing options...
Rich_D Posted July 1, 2016 Report Share Posted July 1, 2016 You know I've never tried the off position...i assume all would be off including drl. Thanks for that mate will also try the headlight sensitivity too Yeah, the 'off' position gives the DRL's only, you need to add coding to be able to disable them. Even in the least sensitive setting, the lights still probably come on too early for you, might be possible to change that with VCDS as well. Quote Link to comment Share on other sites More sharing options...
HamidS92 Posted July 1, 2016 Author Report Share Posted July 1, 2016 You learn something new everyday thanks for that. Wonder why I never tried it for myself. I have just found the coding to change the sensitivity so will change on the weekend Sent from my SM-G935F using Tapatalk Quote Link to comment Share on other sites More sharing options...
