R with problems
DutchR
Hey,
Last year sparkplugs and coils were renewd sparkplugs 2 times, coils 1 time.
Now I do have an engine light burning and fuel consumption is very high.
Got it read out and I have a lean mixture on bank 1. This does also have the consequence of high fuel consumption.
Will go to the dealer but any off you have had engine problems and maybe similar as mine ? :(
  • Replies 7
  • Created
  • Last Reply
Top Posters In This Topic
try awesome gti in manchester. then bill the dealer.
Yup - I'm confused on this too - Dealer would pass on any 'loss' to VW as manufacturer, under their 3 year VW warranty. Why take a car to Awesome, unless of course, the engine has modifications that invalidate the VW warranty - on which basis, own fault and it's up to the owner to take up the issue with the engine Modification supplier ??  : :-[
  • 2 weeks later...
ok been to the workshop 4 times and finally the lambda sensor is replaced.
Have the old R back.  :> :> :>
Glad you've got your car sorted DutchR but I am surprised it's taken your dealer so long and four visits to sort it out. The dash light/lambda sensor problem is so basic that you'd have thought it would have been traced on the first visit if the delaer was any good. TBH I think that the expertise of the VW technicians is questionable - I hope I don't have to find out the hard way with my local dealer!
Hi,
It is just "Simple" error was permanent to lean fuel mixture. but the it was a sporadic error.
So it is a few options they have to look at. But as it is s sporadic error so they first will reset a few times.
Then when the error exists they will sent it to VW which as first thing say replace the Lambda sensor.
It's a bit strange but these days the mechanics can only look at the computer and replace parts causing you have to go there a few times.
Same as with variable intervals, car says I need service within 1000 km and dealer tells you you still can drive 9000 km  :-X
