dv52 Posted February 23, 2025 Report Share Posted February 23, 2025 @jargo:Hi. Alas, your post has a economy of words - meaning that there ain't much information provided! For example, this thread is about VCDS generally - so we don't even know what car this is! Just as a friendly suggestion that might be useful in prompting an informed reply - maybe consider augmenting the question in your post with more words about the following: what Brand? what model? what build year? what country? Don Quote Link to comment Share on other sites More sharing options...
abubakarameer55 Posted May 20, 2025 Report Share Posted May 20, 2025 Good day everyone Please will someone assist me with the access security code for volkswagen jetta 2019 09S transmission code Vin: 3VWE57BU6KM102853 02: auto transmission I tried this code but worng 10505 10815 11966 Quote Link to comment Share on other sites More sharing options...
dv52 Posted May 20, 2025 Report Share Posted May 20, 2025 @abubakarameer55: what are you trying to do? Don Quote Link to comment Share on other sites More sharing options...
abubakarameer55 Posted May 21, 2025 Report Share Posted May 21, 2025 Am trying to perform basic settings and adaptation to the TCM Quote Link to comment Share on other sites More sharing options...
dv52 Posted May 21, 2025 Report Share Posted May 21, 2025 @abubakarameer55: Hmm......... OK, the security codes in your first post apply to the ABS module - they don't apply to the TCM. AFAIK, the mechatronics module does NOT have a 5 x digit security code on MQB platform cars and if it does - I don't believe that it's needed for the Basic setting procedure. Below is my understanding of the Basic setting procedure (which I thieved from the Ross-Tech forum - the procedure was authored by Dana@RT) Note: the Basic setting won't successfully complete unless the mechatronic module is error-free Don Prerequisites: Transmission fluid temperature between 30°C - 100°C confirmed using Advanced Measuring Values: ** IDE00102 Control Module temperature ** IDE00024 Transmission fluid temperature Selector lever in Park Engine idle speed, do not press accelerator pedal Parking brake and foot brake applied during the entire procedure. This can be confirmed using Advanced Measuring Values: * IDE02713 Brake Light Switch * IDE02714 Brake test switch 0D9 - DQ250 MQB - Basic Settings Procedure: [Select] [02- Auto Trans] [Basic Settings-04] Select [Basic settings of transmission] [Show Measuring Data] and select: * IDE00021 Engine speed * IDE00322 Status of basic setting * IDE00024 Transmission fluid temperature [Go!] - During the basic setting procedure, there may be some loud gear shifting noises from the transmission, this is normal. Basic settings may not complete successfully if: - The fluid temperature gets too hot. - Brake is released - Engine RPM is increased Once complete, there should be an indication of this in the [Status of Basic Settings] Advanced Measuring Value group and Basic Settings should report Finished Correctly.. [Done, Go Back] and Check for fault codes. Quote Link to comment Share on other sites More sharing options...
abubakarameer55 Posted May 22, 2025 Report Share Posted May 22, 2025 Thanks soo much bro Quote Link to comment Share on other sites More sharing options...
