Sundown Posted February 6, 2017 Report Share Posted February 6, 2017 Hi Guys, First off, I'm new to the R, and new to mods too, so apologies if this is an especially stoopid question... I've been looking into getting OBD11, or something similar, and I'm slowly building up a list of things to change. One thing that's winding me up and would like to change is the power gauge in the MIBII displaying in kW only. Is this something that could be done with something like OBD or would it need an SD card with a firmware update? (If it's an SD update is there a community for MIB mods?) Thanks in advance Quote Link to comment Share on other sites More sharing options...
Fire_2 Posted February 6, 2017 Report Share Posted February 6, 2017 Anyone else's gauges seem to default back to boost g force and kw (power) I keep trying to make them stay to oil temp boost and water temp but it seems total random if it saves on the next start or defaults back Quote Link to comment Share on other sites More sharing options...
Sundown Posted February 7, 2017 Author Report Share Posted February 7, 2017 mine stay as I left them config wise, although I have to cycle through the different car pages every start as it reverts to the eco blue mode. Just wondering if you could change kW to hp at all. Quote Link to comment Share on other sites More sharing options...
dv52 Posted February 7, 2017 Report Share Posted February 7, 2017 Hi Guys, First off, I'm new to the R, and new to mods too, so apologies if this is an especially stoopid question... I've been looking into getting OBD11, or something similar, and I'm slowly building up a list of things to change. One thing that's winding me up and would like to change is the power gauge in the MIBII displaying in kW only. Is this something that could be done with something like OBD or would it need an SD card with a firmware update? (If it's an SD update is there a community for MIB mods?) Thanks in advance You could always try it's look-alike : Off-Road Display (which has different gauges) Off Road Display - Instructions: WARNING: VCDS users that have a HEX+CAN, or Micro CAN Cable please note that this tweak (and any tweaks) on MIBII units (address Hex5F) should only be implemented with Ross Tech software version 15.7.3 (or later). REQUIREMENT: This tweak will only work on MIBII units that have SATNAV installed (don't bother trying if a SATNAV is not present). Step 1. On Select Control Module screen click "Select" Step 2. Select 5F-information Elect Step 3. Go to step 4 - Note: I've had reports from some forum colleagues that a security code was needed. If the adaptation channel settings in Step 5 are locked: Step 3A. Go back to the Open Controller screen and select Security Access-16Step 3B. Enter the magic number 31347 (if this doesn't work- exit RT software, wait a while with the ignition-on and try 20103) Step 4. Select Adaptation-10 Step 5. Change the following adaptation channels: (81)-Car_Function_Adaptations_Gen2-menu_display_compass - set to active (default not active) (83)-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high - set to active (default not active) (41)-Car_Function_List_BAP_Gen2-compass_0x15 - set to active (default not active) Exit the Ross Tech software Step 6. Reset the MIB unit - press and hold the ON/OFF button on the infotainment unit for greater than 10 seconds. Don Quote Link to comment Share on other sites More sharing options...
Sundown Posted February 8, 2017 Author Report Share Posted February 8, 2017 I had no idea that information was stored for user gauges, looks like wheel position and altitude in there. I'm guessing there's no known way of changing units of specific dials. Thanks for the info anyway! Quote Link to comment Share on other sites More sharing options...
RoundSquare Posted February 8, 2017 Report Share Posted February 8, 2017 My gauges used to sweep when I first went on to that screen the way the rev and speedo do when you put the ignition on. For some reason they stopped doing this. Quote Link to comment Share on other sites More sharing options...
Sundown Posted February 8, 2017 Author Report Share Posted February 8, 2017 Hmm not sure, I've seen mine do it occasionally but I'm not sure what triggers it. - I don't think it's every time I set the screen. Does it sweep if you set the dials screen and then start the car? I haven't had mine long enough to work out when this kind of stuff happens. Quote Link to comment Share on other sites More sharing options...
RoundSquare Posted February 8, 2017 Report Share Posted February 8, 2017 When I first got it if I kept pressing the car button to toggle through the screen, every time it came to the gauges it would definitely sweep. Maybe its related to what driving profile you are in. Quote Link to comment Share on other sites More sharing options...
