Indicators on with DRL's
Evan7R
Hey guys/girls.
I've seen a few R's floating about with the Indicators on (at a low setting) alongside the DRL's almost running as a second set of DRL's (or third?)
Was wondering if any of you have seen this before or know the coding for it?
I've seen it a few times but can't get a hold of the owners to ask them how they done it (the won't reply to messages )
Hey guys/girls.
Don't think he'll reply any time soon as he's just picked his a45 up today!
Hey guys/girls.
Evan:  Here you go - try this:
Before you make the changes- a few points to emphasise in the tables below:
IF YOUR CAR HAS  INCANDESCENT LAMPS -  DON'T EXCEED DIMMWERT AB SETTING 50
I've included instructions for both LED and Incandescent front turn-lights even though the fittings shown in your picture are clearly LED. Just make sure that you don't use a Dimmwert EF setting of 127 on incandescent lamps (which should have a value of 100). Simply take note of the existing value for Dimmwert AB on your car and apply it to the new value for Dimmwert EF (as shown in both tables)
I've had to add the DRL function into Bank1 to ensure the correct priority when a conflict occurs whenever both the DRL and the turn signals are operated together. This has necessitated the movement of the original turn signal function (Blinken Hellphase) to a higher-order Bank and it has also necessitated the inclusion of the Blinken Dunkelphase command to suitably "insulate" the DRL function when the lamp blinks.
I've suggested an illumination level of 35 for the new DRL function, (for Dimmwert AB -new Setting), but this is just a suggestion. You can pick any value that you want - WITH ONE PROVISO . If you have incandescent lamps make sure that you don't exceed 50. The reason for this is that the power rating for the lamp base is set for a duty cycle of 50% because the blinker flashes on/off for about the same time. If you exceed 50, it's likely that the lamp base may start to discolor and it may even melt from increased heat.
Finally, I suggest that you acquaint yourself with your local rules regarding vehicle lighting. Make sure that this tweak is actually legal in your area. Whilst probably not many traffic cops will understand whether it's legal to run the turn-signals in this manner, this is the last thing that you will want to argue in a court if you are in an accident and the other party claims that your car did not comply with the local laws
AqIksrq.png?1
EDIT: Added warning about incandescent lamps
I've suggested an illumination level of 35 for the new DRL function, (for Dimmwert AB -new Setting), but this is just a suggestion. You can pick any value that you want - again, make sure that you don't exceed 100 for incandescent lamps and no more than 127 for LEDs
AqIksrq.png?1
Thanks mate! I'll give this a shot!!
Gave this a shot, unfortunately it doesn't work (or more likely, I'm not doing something correctly)
Thanks anyway!
(Ps, the "Tagfahrlight" option isn't visible, I've tried both Daytime running light options as this is the English translation with no luck)
(Pps, ignore the idiot here, got it working in the end up. The dimmwert function has to be above 80, as below this it stutters and flashes on and off rapidly. That's why it didn't work at 35)
Thanks anyway!
Evan:: huh? what device are you using? The instruction are written for OBD11
Managed to get it working in the end up. It will turn the indicators on as day time running lights, when your main beams come on, the indicators will go off and work as normal indicators.
Using a Ross tech cable and software off their website.
Evan: Yep - that's what I designed the tweak to do !  well done
Awesome. Gona bookmark this to try later :afro:
Is it safe to run these on all the time with the LED Indicators? Has anyone run with these on for a decent amount of time?
I'm still fiddling with them, not sure if they're safe but I've had no issues yet. Don't see much of a problem seeing as the DRL's are LED too. Though they're quite possibly different grade/quality of LED's (if there is such a thing)
Had them set to 80 then they lit up my dash after a short drive.
Then stuck them to 100, lit it up after about 20 minutes.
Might try them at 127 now, see how that fares tomorrow, if it keeps throwing up lights I'm going to change it back.
Looks amazing though!
Ah damn! Made me feel like a boss there for a while! Ah well Good man! Lol
Don, quick question.
I've come across a problem with the rear lights and was wondering if you could help?
When I was coding the inner back lights as brake lights he inner normal lights agent off and only worked as brake lights. When I sorted that out and checked it, the inner lights were working as they should, but the Red lights on the rear indicator bar that light up when the indicator isn't on, were dark, leaving a black space where there should be a red light (if that makes sense)
The red light turns on along with the amber one when you turn the indicators on. (But it on its own, the opposite of how it should work)
Would you possibly know what coding to change to stop this? So the indicators light up as only amber and when they're off the bar isn't blank and has the usual red LED's blending in with the rest of the rear lights?
I can send photos if needs be.
(Ps, I know this isn't the same as the topic, but I don't want to start a new one for one question)
^^^ what instructions did you use for the coding?
I used one I got online, it didn't work and I can't find the coding now, basically left the inner tail lights as brake lights only, going out and leaving only the lights on the rear quarter panel as tail lights.
Then I used this one to correct it.
minus the bottom two settings as I didn't want the light to go out between blinks.
