Ferg_7R Posted March 12, 2017 Report Share Posted March 12, 2017 I'm still fiddling with them, not sure if they're safe but I've had no issues yet. Don't see much of a problem seeing as the DRL's are LED too. Though they're quite possibly different grade/quality of LED's (if there is such a thing) Had them set to 80 then they lit up my dash after a short drive. Then stuck them to 100, lit it up after about 20 minutes. Might try them at 127 now, see how that fares tomorrow, if it keeps throwing up lights I'm going to change it back. Looks amazing though! Sent from my iPhone using Tapatalk Did you sort this out? By lit up the dash do you mean it gave a bulb out error? Quote Link to comment Share on other sites More sharing options...
Evan7R Posted March 12, 2017 Author Report Share Posted March 12, 2017 Did you sort this out? By lit up the dash do you mean it gave a bulb out error? Yeah it's sorted now. Seems it needs 127 all the way! And less and it gives a warning lights. Yeah that's what I meant mate. Sent from my iPhone using Tapatalk Ferg_7R 1 Quote Link to comment Share on other sites More sharing options...
HamidS92 Posted July 11, 2017 Report Share Posted July 11, 2017 By using obd11 can we do it where the indicators are on with drl and not full beam? From the post above it seems as if they stay on only with main beams but I want it like the photo. Many thanks Sent from my SM-G935F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Evan7R Posted July 11, 2017 Author Report Share Posted July 11, 2017 By using obd11 can we do it where the indicators are on with drl and not full beam? From the post above it seems as if they stay on only with main beams but I want it like the photo. Many thanks Sent from my SM-G935F using TapatalkSorry, They are only on with drl's and turn off when the main beams come on. Sent from my iPhone using Tapatalk HamidS92 1 Quote Link to comment Share on other sites More sharing options...
HamidS92 Posted July 11, 2017 Report Share Posted July 11, 2017 Sorry, They are only on with drl's and turn off when the main beams come on. Sent from my iPhone using TapatalkPerfect! Will give it a go. Sent from my SM-G935F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Evan7R Posted July 11, 2017 Author Report Share Posted July 11, 2017 Perfect! Will give it a go. Sent from my SM-G935F using TapatalkI've had mine done since the middle of March. No issues as of yet.Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
HamidS92 Posted July 11, 2017 Report Share Posted July 11, 2017 I've had mine done since the middle of March. No issues as of yet.Sent from my iPhone using TapatalkDid you set yours too 127?Sent from my SM-G935F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Evan7R Posted July 11, 2017 Author Report Share Posted July 11, 2017 Did you set yours too 127?Sent from my SM-G935F using TapatalkYeah mate. If you set it any lower they flicker and go out. But set them to 127 and you're sorted. They're an on/off light not a progressive one Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
dv52 Posted July 13, 2017 Report Share Posted July 13, 2017 On 10/03/2017 at 06:06, Evan7R said: Ah damn! Made me feel like a boss there for a while! Ah well Good man! Lol Don, quick question. I've come across a problem with the rear lights and was wondering if you could help? When I was coding the inner back lights as brake lights he inner normal lights agent off and only worked as brake lights. When I sorted that out and checked it, the inner lights were working as they should, but the Red lights on the rear indicator bar that light up when the indicator isn't on, were dark, leaving a black space where there should be a red light (if that makes sense) The red light turns on along with the amber one when you turn the indicators on. (But it on its own, the opposite of how it should work) Would you possibly know what coding to change to stop this? So the indicators light up as only amber and when they're off the bar isn't blank and has the usual red LED's blending in with the rest of the rear lights? I can send photos if needs be. (Ps, I know this isn't the same as the topic, but I don't want to start a new one for one question) Sent from my iPhone using Tapatalk Evan: Try this Go to the Central electrics module @ address hex09 and enter the magic security number 31347. If you have a pre MY17 car, then search for Driving light and parking light. If you have a later model module, search for Aussenlicht_Heck Select Schlusslicht mit Bremslichtfunktion and change setting to active Don Quote Link to comment Share on other sites More sharing options...
Evan7R Posted July 13, 2017 Author Report Share Posted July 13, 2017 Evan: Try this Go to the Central electrics module @ address hex09 and enter the magic security number 31347. If you have a pre MY17 car, then search for Driving light and parking light. If you have a later model module, search for Aussenlicht_Heck Select Schlusslicht mit Bremslichtfunktion and change setting to active DonThanks! I'll give that a shotSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
