Help
acdoctor
Anyone with vcds in leicester help with dynaudio
installed dynaudio system to my R
rang my dealer , refused to code the car , telling me vw won't allow them to do it
I understand I may need component protection switching off which can only be done by vw , so I'm stuffed pretty much
any help appreciated
There are workarounds for the component protection but it can't be removed from the car. If the Dynaudio components (most likely the amp) are subject to component protection then they need to be hacked to bypass it. The car's CANBUS system will still show a component protection fault but it won;t have any impact to you other than showing up on a diagnostic scan. I have the same thing with my Discover Pro retrofit.
The guy I saw on Sunday said that he can sort out component protection so I've dropped him a text to see if he knows anyone in your area that can help (they all seem to support each other on a forum some where) and I've dropped @alexretro a whatsapp message as well.
  • 3 months later...
