Johnf Posted August 3, 2017 Report Share Posted August 3, 2017 Wondering if anyone has converted from rear halogen to facelift leds. I'm having issues with inner leds and fog. Audi a4 o8 plate. Anyone know how to fix this as garages in going to don't seem to know what to do Quote Link to comment Share on other sites More sharing options...
8YARWY Posted August 3, 2017 Report Share Posted August 3, 2017 5 hours ago, Johnf said: Wondering if anyone has converted from rear halogen to facelift leds. I'm having issues with inner leds and fog. Audi a4 o8 plate. Anyone know how to fix this as garages in going to don't seem to know what to do I'm sure you'll need harness adaptors and then i think they need a coding change. https://www.bks-tuning.com/audi/a4-s4-rs4/a4-b8/wiring.html http://www.ebay.co.uk/itm/Audi-A4-S4-B8-8K-Sedan-Saloon-LED-rear-lights-tail-lights-adapter-harness/171411889879?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D1%26asc%3D20140107083358%26meid%3D3c37a027dce645fcab4b7e84fcedf266%26pid%3D100011%26rk%3D1%26rkt%3D12%26mehot%3Dpp%26sd%3D110968270007 Quote Link to comment Share on other sites More sharing options...
dv52 Posted August 4, 2017 Report Share Posted August 4, 2017 17 hours ago, Johnf said: Wondering if anyone has converted from rear halogen to facelift leds. I'm having issues with inner leds and fog. Audi a4 o8 plate. Anyone know how to fix this as garages in going to don't seem to know what to do John: veneeringman is correct, but the type of cross wiring harness is different depending on the type of vehicle that has halogen tails and the type of facelift LEDs. I help develop a coss-wiring diagram for a mk7R Wolfsburg wagon and a facelift tail with dynamic flash (see below), but I have no idea if this suits your arrangement. The other aspect of this retrofit that you need to be aware-of is that modifications will be needed to the Leuchte-sets for the individual lamps in the new assemblies. For example, the outer tails in the new fittings will only act a brake lights - so you will need to remove the other functions (like Parking lights and Single sided Parking lights). But I was not close to this aspect of the retrofit So, not completely plug-and-play (alas) Don 8YARWY 1 Quote Link to comment Share on other sites More sharing options...
8YARWY Posted August 4, 2017 Report Share Posted August 4, 2017 Some great info [mention=20064]dv52[/mention] I've seen changes in the Facelift Leuchte sets on my R too. Comparing Adaptation maps can give good info. Quote Link to comment Share on other sites More sharing options...
dv52 Posted August 4, 2017 Report Share Posted August 4, 2017 veneeringman: Thanks. Don Quote Link to comment Share on other sites More sharing options...
