Wilma Posted January 29, 2018 Report Share Posted January 29, 2018 Hi all, I've got two codes up for the exhaust flaps, I unplugged them a while ago to see if I liked it, but I plugged them back in again, they both work but I've still got the error codes up and can't seem to get rid of them with carista. Am I missing something? Thanks Quote Link to comment Share on other sites More sharing options...
Rob2k68 Posted February 1, 2018 Report Share Posted February 1, 2018 Codes should clear once the valves are plugged back in. Can you try VCDS at all ? Quote Link to comment Share on other sites More sharing options...
Wilma Posted February 7, 2018 Author Report Share Posted February 7, 2018 On 01/02/2018 at 22:51, Rob2k68 said: Codes should clear once the valves are plugged back in. Can you try VCDS at all ? Thanks for reply, yes agreed, but they are not! The valves are functional and work, but I've still got the codes! I haven't checked since I had that battery off at the weekend, so I'll look again. Quote Link to comment Share on other sites More sharing options...
ToRnado Posted February 7, 2018 Report Share Posted February 7, 2018 The fault codes can definitely be cleared with VCDS. If you are still throwing codes (is the number of instances is increasing) then check the flaps have been properly reconnected. Anyone running a non-standard exhaust system will have these fault codes (unless it has been disabled in VCDS). Quote Link to comment Share on other sites More sharing options...
Wilma Posted February 10, 2018 Author Report Share Posted February 10, 2018 Thanks, they are definitely plugged in, i made sure of that, they also definitely work. I have cleared the faults with OBD11 now, so i will see what happens from now on. Quote Link to comment Share on other sites More sharing options...
