Olifran Posted February 19, 2018 Report Share Posted February 19, 2018 Got this on a scan of mk7.5R. No warning lights or faults with headlights? Quote Link to comment Share on other sites More sharing options...
dv52 Posted February 22, 2018 Report Share Posted February 22, 2018 ^^^^^^ It's not clear in the picture, but what version VCDS software and what type of VCDS cable are you using? Don Quote Link to comment Share on other sites More sharing options...
Olifran Posted February 25, 2018 Author Report Share Posted February 25, 2018 On 22/02/2018 at 00:20, dv52 said: ^^^^^^ It's not clear in the picture, but what version VCDS software and what type of VCDS cable are you using? Don Quote Link to comment Share on other sites More sharing options...
Olifran Posted February 25, 2018 Author Report Share Posted February 25, 2018 What’s this error too? Quote Link to comment Share on other sites More sharing options...
dv52 Posted February 25, 2018 Report Share Posted February 25, 2018 Olifran: Thanks for the screen shots. hmm.... OK. You are using the latest Ross-Tech software and a HEX+CAN cable. Software is good, but you need to remember that the design of the HEX+CAN device is now over 20 years old. Ross Tech have faithfully supported these older cables through the intervening years, but CAN standards on newer release cars have now progressed beyond the capabilities of the HEX+CAN cables. For example, one of the protocols that the HEX+CAN cable can't read is newest Extended Address Mode that is enshrined in the latest CAN 2.0 B standard (this protocol uses 29 x Bit addressing). Your first screen suggests that this inability to communicate with "Extended address" is causing the fault message to be truncated. Your last screen suggests that this same problem is causing the auto-scan to be not fully completed because at least one of the modules in your car has OBD 2.0 B protocol (I suspect one of the LCM modules). Bottom line- if you want to keep abreast of the modules in the newer VAG vehicles that use current OBD standards, then you will need to upgrade your VCDS cable (HEX-NET, or HEX V2). Ross Tech has a kind-of "loyalty" offer for those that are in your situation - you can "trade-in" your old cable for a newer HEX series product at a discounted price ( see https://store.ross-tech.com/shop/RetCAN ) Don PS: although it may seem that I am "sprooking" sales for VCDS - I have absolutely no affiliation with Ross-Tech. I simply happen to believe (as a user) that they have an excellent range of diagnostic cables!! 8YARWY 1 Quote Link to comment Share on other sites More sharing options...
Olifran Posted February 25, 2018 Author Report Share Posted February 25, 2018 27 minutes ago, dv52 said: Olifran: Thanks for the screen shots. hmm.... OK. You are using the latest Ross-Tech software and a HEX+CAN cable. Software is good, but you need to remember that the design of the HEX+CAN device is now over 20 years old. Ross Tech have faithfully supported these older cables through the intervening years, but CAN standards on newer release cars have now progressed beyond the capabilities of the HEX+CAN cables. For example, one of the protocols that the HEX+CAN cable can't read is newest Extended Address Mode that is enshrined in the latest CAN 2.0 B standard (this protocol uses 29 x Bit addressing). Your first screen suggests that this inability to communicate with "Extended address" is causing the fault message to be truncated. Your last screen suggests that this same problem is causing the auto-scan to be not fully completed because at least one of the modules in your car has OBD 2.0 B protocol (I suspect one of the LCM modules). Bottom line- if you want to keep abreast of the modules in the newer VAG vehicles that use current OBD standards, then you will need to upgrade your VCDS cable (HEX-NET, or HEX V2). Ross Tech has a kind-of "loyalty" offer for those that are in your situation - you can "trade-in" your old cable for a newer HEX series product at a discounted price ( see https://store.ross-tech.com/shop/RetCAN ) Don PS: although it may seem that I am "sprooking" sales for VCDS - I have absolutely no affiliation with Ross-Tech. I simply happen to believe (as a user) that they have an excellent range of diagnostic cables!! Thank you for the info. Will the new lead be able to read the headlight modules for the mk7.5? Quote Link to comment Share on other sites More sharing options...
dv52 Posted February 26, 2018 Report Share Posted February 26, 2018 ^^^ the headlight modules for the mk7.5 are LCM (light Control Modules) that I referenced in my reply - Answer = Yes . Have a look at the modules @ 29, 39, D6 and D7 in the auto-scan on the link below (not a mk7, but the new Tiggy uses very similar modules) http://162.208.84.227/showthread.php?13213-2018-Tiguan-AD1-2-0-BiTDI-CUAA Don PS:The newer HEX series cables certainly can read LCMs, but don't expect that you will be able to change any parameters in these modules - they have no code-sting and virtually no adaptation channels. Basically, hard wired units -alas! 8YARWY 1 Quote Link to comment Share on other sites More sharing options...
Olifran Posted March 5, 2018 Author Report Share Posted March 5, 2018 Well I found out that I needed to go into can gateway on 19 and tick all the installations in my car from my original scan when I bought it. I think when I used OBDELEVEN, I must have enabled and disabled some gateways. You live and learn! Quote Link to comment Share on other sites More sharing options...
