Calculating bhp using MAF reading
Hurdy
Ok guys,
Using Group 2 - field 3 in the measuring blocks in VCDS (Mass Air Flow Sensor (G70))in g/s
Not to get too technical, but our cars give a MAF reading in grams per second of air flowing through the intake and as a rule of thumb you can calculate bhp from this reading using either of the following calculations.....
bhp = MAF x 1.25
or
bhp = MAF / 0.8
For example if your standard Golf R has a maximum MAF reading of 215 g/s then the power output is calculated as....
215 / 0.8 = 268.75 bhp or 215 x 1.25 = 268.75 bhp
now there are several variables that can alter the calculation very slightly (atmospheric pressure, timing pull, running richer or leaner etc), but the calculation shouldn't alter by much more than 2% either way.
Why does this calculation work?......because for every gram of fuel used against 1.25 grams of air used per second creates 1 bhp.
:afro:
  • Replies 19
If it's accurate, which I suspect at the higher powers it isn't, then APR's new stage 2+ is running just over 381bhp on my R with VPower fuel.
I peaked 305g/s.
RAW:
RPM MAF g/s BHP calc
1600 24.19 30.2375
1640 27.64 34.55
1680 29.78 37.225
1720 30.19 37.7375
1760 30 37.5
1840 32.08 40.1
1880 33.97 42.4625
1920 38.92 48.65
1960 46.92 58.65
2040 52.28 65.35
2120 55.56 69.45
2240 63.42 79.275
2320 72.06 90.075
2400 80.17 100.2125
2520 91.31 114.1375
2640 99.42 124.275
2760 106.53 133.1625
2880 118.19 147.7375
3000 126.89 158.6125
3120 137.08 171.35
3280 144.17 180.2125
3400 151.53 189.4125
3520 164.11 205.1375
3680 171.81 214.7625
3800 196.03 245.0375
3960 218.89 273.6125
4120 229.64 287.05
4320 243.47 304.3375
4480 254.25 317.8125
4600 264.28 330.35
4760 271.97 339.9625
4920 280.06 350.075
5080 290.31 362.8875
5240 288.94 361.175
5360 295.14 368.925
5520 300.03 375.0375
5640 298.17 372.7125
5760 300.25 375.3125
5880 301.06 376.325
6000 305 381.25
6080 302.75 378.4375
6240 298.86 373.575
6320 297.22 371.525
6440 297.61 372.0125
6520 294.42 368.025
6600 298.64 373.3
6720 294.78 368.475
6800 299.44 374.3
6880 296.78 370.975
6960 217.69 272.1125
Good peak g/s. :cool:
Yes, and similar to peak mine before the move to the L0400.
Your peak is around 6000 rpm and then starts to drop. Mine was just after 7000 rpm and is still 303 g/s at 7400 rpm, which shows quite well how the L0400 holds on to the power a little longer. :nerd:
  • 4 weeks later...
  • 3 weeks later...
  • 5 weeks later...
Hurdy, do you mind posting your MAF logs?
Excellent! Would love to see the back-end of your figures. I don't know what your current settings are at, but whatever the best results are, post them up with a mod list and let the numbers do the talking. :afro:
Not trying to have a go here at all, but I think that's the thing I miss the most about your particular setup: clarity. Data is the backbone of this aftermarket. Do you really not have a dyno progression from stock to stage 2+ to your current setup on the same rollers?
