Calculating bhp using MAF reading
Hurdy
Excellent! Would love to see the back-end of your figures. I don't know what your current settings are at, but whatever the best results are, post them up with a mod list and let the numbers do the talking. :afro:
Not trying to have a go here at all, but I think that's the thing I miss the most about your particular setup: clarity. Data is the backbone of this aftermarket. Do you really not have a dyno progression from stock to stage 2+ to your current setup on the same rollers?
I have dyno runs from Statller from start to finish, although their dyno has been re-calibrated twice since I started tuning my R, so aren't fully comparable. :afro:
Engine/power modifications
GIAC stage 3 Extreme map - switchable through the GIAC switchloader which includes
1. Pump map - usable everyday with WMI running or not
2. Race map -  usable everyday, but MUST have WMI running and octane booster - alternatively 100octane or higher fuel with or without WMI running.
3. Valet mode - restricts power during visits to dealers
4. Kill switch - immobiliser.
GIAC Stage 3 DSG software - this is a custom software and can be programmed as you like it and based on stage 2. Link below.
http://www.giacusa.com/news.php?newsid=147
Loba Motorsports upgrade turbo L0400
RS4 Injectors
Custom intake with Forge Motorsport 3" MAF housing and Evoms front end intake and dry filter.
RS4 136bar fuel pressure return valve
Evoms DV
Custom stainless steel and titanium exhaust with 3.5" downpipe and full 3" rear section.
Loba High pressure fuel-pump.    http://www.loba-motorsport.com/en/home/news/new-product---loba-20-tfsi-hpfp-upgrade
RS3 in-tank low pressure fuel-pump
BSH throttle pipe
BSH Vacuum tap - for water methanol injection.
E-Boost 2 boost controller
Revo PCV fix.
Eurojet FMIC
NGK Iridium sparkplugs
Devil's own water methanol injection - http://www.methanol-injection.co.uk/pro ... ucts_id=28
  • 3 weeks later...
  • Replies 19
I thought so too but if you read tjus thread : http://www.mk5golfgti.co.uk/forum/index ... 668.5;wap2
It seems to be not bad compared to others? The car feels quick enough etc so not sure why it's so low. Mind you if have nothing to compare it with power wise.
Can u pm me your email graham so I can send my logs? Maybe I am reading them wrong as the numbers are all over the place as I am opening the file up in word and not excel
  • 11 months later...
