golf7.5r Posted January 3, 2020 Report Share Posted January 3, 2020 Before I take my hatch trim off, does anyone know for sure if the mk7.5 models come pre-fitted with the reverse camera cabling? VAG often pre-wire cars even though the equipment isn't standard fit as it's usually cheaper from a manufacturing point of view. Quote Link to comment Share on other sites More sharing options...
slider09 Posted January 3, 2020 Report Share Posted January 3, 2020 I retrofitted the reversing camera to my mk7, the kit includes all wiring which needs running to the head unit / fuse box. Can’t see the 7.5 being any different?Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
mark118 Posted January 6, 2020 Report Share Posted January 6, 2020 take one bit of trim off on the right side of the boot lid( or the middle piece, thats where my reverse camera cable bundle was. had camera factory fitted so can only suggest a quick look to see if you have the bundle in place. They are all bundled together with black sticky fabric tape so will not look as clear as my pic if you have it, the black is the coax video feed, and the blue and red are power. If you have to pull the cable through be very careful with the boot seals that go between the car and boot lid they break very easily and will let water into your headlining if the clip is broke. (5G6971829B incase you need a new one ) Quote Link to comment Share on other sites More sharing options...
golf7.5r Posted January 7, 2020 Author Report Share Posted January 7, 2020 17 hours ago, mark118 said: take one bit of trim off on the right side of the boot lid( or the middle piece, thats where my reverse camera cable bundle was. had camera factory fitted so can only suggest a quick look to see if you have the bundle in place. They are all bundled together with black sticky fabric tape so will not look as clear as my pic if you have it, the black is the coax video feed, and the blue and red are power. If you have to pull the cable through be very careful with the boot seals that go between the car and boot lid they break very easily and will let water into your headlining if the clip is broke. (5G6971829B incase you need a new one ) Thanks, I'll take a look later this week. Quote Link to comment Share on other sites More sharing options...
