c4ypt1k Posted May 20, 2020 Report Share Posted May 20, 2020 Does any know where to the coding is to change this Climate Control Screen from RHD or LHD Quote Link to comment Share on other sites More sharing options...
dv52 Posted May 21, 2020 Report Share Posted May 21, 2020 ^^^^^^c4ypt1k: Hi. I don't know the answer to your question with absolute certainty, but the software switch that tells the Air Conditioning module @ address hex08 which side of the car the steering wheel is installed is on Byte 1 , Bits4-7 in the long-code string - see below: My hunch (guess really) is that the MIB uses this setting value to display the correct version of the Climate Control screen for LHD/RHD cars - I think! Not sure how familiar you are with hex/Binary code - but in essence, my picture above says that it's all done with Bit #4 ; Bit #4 set to "1" means RHD, or Bit #4 set to "0" means LHD Again, I'm not absolutely certain - but it's a relatively easy try - so worth investigating IMO. Don c4ypt1k 1 Quote Link to comment Share on other sites More sharing options...
c4ypt1k Posted May 27, 2020 Author Report Share Posted May 27, 2020 Thanks dv52 I will check the current the coding on my car. Quote Link to comment Share on other sites More sharing options...
