Blackpug Posted March 14, 2014 Author Report Share Posted March 14, 2014 My nearest Tesco has Momentum 99 at £1.329 (which I am using,Vpower is £1.369). My mk4 R32 ran better on Vpower but my mk5 ran better on Tesco??? I'm currently getting 29mpg in the mk7R on mixed roads. Quote Link to comment Share on other sites More sharing options...
neilje Posted March 19, 2014 Report Share Posted March 19, 2014 My nearest Tesco has Momentum 99 at £1.329 (which I am using,Vpower is £1.369). My mk4 R32 ran better on Vpower but my mk5 ran better on Tesco??? I'm currently getting 29mpg in the mk7R on mixed roads. £1.319 at my local Tesco. Before I filled up today I noted 28mpg since last refuel. The most I have got on my 17 mile run to work is 33mpg on mixed roads. I have found that using the ACC in Eco mode best (in terms of mpg) for A roads/motorways etc - The ACC does a brilliant job at following the car in front with the minimum fuss. I just set the speed to way more than I know I am going to get up to and let the cars in front do all the work. It seems to be able to drive more economically that me. For around town I use Normal mode but have got used to the Start/Stop now so I leave it switched on. Up to 700 miles now so soon be time for a real thrashing to see what it can really do. Quote Link to comment Share on other sites More sharing options...
Running Man Posted March 19, 2014 Report Share Posted March 19, 2014 Shell V Power for my R, where I go there are a few around so it makes sense plus I want to stay with the same brand fuel. I will never sell my 7R, maybe one day I will have a 12R but my 7 will be cherished in my garage Quote Link to comment Share on other sites More sharing options...
Chubby Posted March 19, 2014 Report Share Posted March 19, 2014 I just set the speed to way more than I know I am going to get up to and let the cars in front do all the work That sounds licence risky...... So if the road ahead clears, off she goes to what you've set it up to and if one of the notorious camera vans are in a lay by......... Quote Link to comment Share on other sites More sharing options...
neilje Posted March 19, 2014 Report Share Posted March 19, 2014 I just set the speed to way more than I know I am going to get up to and let the cars in front do all the work That sounds licence risky...... So if the road ahead clears, off she goes to what you've set it up to and if one of the notorious camera vans are in a lay by......... When I say "way more" I mean enough so that I know I won't fall behind with the prevailing flow. If the road clears I can easily readjust it. It is so effortless though. Quote Link to comment Share on other sites More sharing options...
Blackpug Posted March 19, 2014 Author Report Share Posted March 19, 2014 Just been down to York for a few days. Mainly motorway and A66. Used ACC for the first time and it's brilliant. Only problem is when someone overtakes you then pulls in sharply in front of you. ACC immediately slows you by too much. (Only doing it's job tho'). And I averaged 35mpg. But my wife hates the noise in Race mode. Quote Link to comment Share on other sites More sharing options...
Chubby Posted March 19, 2014 Report Share Posted March 19, 2014 I will never sell my 7R, maybe one day I will have a 12R but my 7 will be cherished in my garage If VW continue to release Golf R's every four years, it'll be 2034 before the 12R is in buyers hands. If you propose to run your 7R on till then, it will certainly be in the garage - having repairs done to hold it together still Quote Link to comment Share on other sites More sharing options...
harryhackenbacker Posted March 19, 2014 Report Share Posted March 19, 2014 I will never sell my 7R, maybe one day I will have a 12R but my 7 will be cherished in my garage If VW continue to release Golf R's every four years, it'll be 2034 before the 12R is in buyers hands. If you propose to run your 7R on till then, it will certainly be in the garage - having repairs done to hold it together still 2034 no problem for a 7 R ,driven by a nun ,do suspect a large number will get bent ,and bent badly ,not the car ,at all , it will be too much temptation, with to little experience or restraint Quote Link to comment Share on other sites More sharing options...
Blackpug Posted March 19, 2014 Author Report Share Posted March 19, 2014 Plenty of 20 yo Golfs still running about. Quote Link to comment Share on other sites More sharing options...
tamiyoman Posted March 24, 2014 Report Share Posted March 24, 2014 Plenty of 30 y/o golfs running about too Quote Link to comment Share on other sites More sharing options...
R.R Posted March 24, 2014 Report Share Posted March 24, 2014 Used to - Tesco 95 for streets. Tesco 99 for tracks. Now - Tesco 99 anytime. Cheaper than Shell 98/99. With Tesco Fuel Save, even cheaper. Quote Link to comment Share on other sites More sharing options...
volkswizard Posted March 24, 2014 Report Share Posted March 24, 2014 Plenty of 30 y/o golfs running about too Plenty of electronic things on modern cars will write off a car sooner mechanically. DSG boxes are already doing that to Mk1 TT 3.2s Quote Link to comment Share on other sites More sharing options...
tamiyoman Posted March 24, 2014 Report Share Posted March 24, 2014 Plenty of 30 y/o golfs running about too Plenty of electronic things on modern cars will write off a car sooner mechanically. DSG boxes are already doing that to Mk1 TT 3.2s mechanically it will not write it off as it could be repaired/replaced, economic viability is what would write the car off, no point spending £3.5K on a DSG gearbox on a £2k car Quote Link to comment Share on other sites More sharing options...
Jimmy Filth Posted March 24, 2014 Report Share Posted March 24, 2014 I do wonder if cars built currently will be around in several years. As you can see by signature I have some older cars. The Humber is currently having a complete nut and bolt restoration, but the Morris hasn't had any major work since it left the Army in the 50's, plus the fastback turns over first time. Everything works and that is 42 years old, also had no work. On both it is the electrics that will go before anything else. Quote Link to comment Share on other sites More sharing options...
Running Man Posted March 24, 2014 Report Share Posted March 24, 2014 Plenty of 30 y/o golfs running about too Yes there are well said Quote Link to comment Share on other sites More sharing options...
