Enabling headlight washer delay
Penguin
I thought I'd post this here as I have drawn a blank over the last few days when trying to follow the prescribed VCDS method for this and couldn't find anything on the various forums.
So normally the headlight washers will activate on the initial windscreen wash and then every tenth (I think) windscreen wash.  This can be a pain when you've just spent ages cleaning your car and/or you start going through a lot of washer fluid, especially in Winter.  You can disable the washer all together or just set a delay so that it will only activate on a long pull of the stalk. I believe the max value is 2.5 seconds but IIRC some people have reported that '2500ms' isn't always accepted; I set it to '2000ms' (2 seconds) and the change was accepted
  • Central Electrics - 09
  • Adaptations
  • Search 'scheinwerferreinigung' (headlight cleaning)
  • Security access code '31347'
  • Select 'SRA Verzoegerungszeit' and set value to '2000' (don't worry that the range is '0-250' on the input field)
  • Commit the change
Now with the engine running and dipped beam selected, the headlight washer should only activate after a 2 second pull on the washer stalk.
On 12/12/2020 at 19:20, MKMike said:
anzahl betaetigungun frontwaschalanlage SRA activeerung (10)
I believe that is the counter in which the headlight washers are triggered, e.g; every 10th operation of the windscreen wipers
SRA waschzeit (400 ms)?
The washing time of the headlight washers, e.g; spray jet for 0.4 secs
SRA einweichpauseenzeit (2000 ms)
Not too sure on this one. As a wild guess I would say that is the delay/pause between the 1st and 2nd headlight washers jets being sprayed, e.g; spray headlights > pause for 2 secs > spray headlights again
