7.5R Posted April 18, 2021 Report Share Posted April 18, 2021 Hello guys i have a 2017 golf r with the dynamic tail lights as standard, i was messing around on the obd 11 and turned on DAP and then turned it back off, now i have noticed that the outer tail lights are working as they should however the inner tail lights the indicator strip is constantly on, when indicating the outer ones sweep but not the inner ones they are just turned on, i did not create a back up, does anyone know how to get it back to stock. thanks Quote Link to comment Share on other sites More sharing options...
Chris7.5R Posted April 18, 2021 Report Share Posted April 18, 2021 For anyone who's not au fait with TLAs, please answer the following: 1. What is DAP? 2. Why and how did you turn it on? 3. Why and how did you then turn it off? 4, Why on earth didn't you create a backup? Quote Link to comment Share on other sites More sharing options...
7.5R Posted April 22, 2021 Author Report Share Posted April 22, 2021 Hello i got the picture of the setting that i suspect caused this. Quote Link to comment Share on other sites More sharing options...
Chris7.5R Posted April 22, 2021 Report Share Posted April 22, 2021 Is your car a North American Mk7.5 and have you installed the Mk7.5 Euro Fluid Dynamic Tail Lights and harness? If not then you clearly didn't read the warnings given with this App. Without a backup you have a big problem in trying to restore your original setup. Using these damned Apps is a great way to dig a big hole for yourself. Using the Pro version of OBDeleven with Adaptions and Long Coding gives you a huge safety margin. As with VCDS, it's possible to inspect the changes and revert them to your original backup state. AFAIK Apps don't even make appropriate entries in the History log. You are relying on somebody else to fully understand your particular car and produce a totally reliable App, plus a foolproof way to undo the coding. There is an Australian gentleman, possibly not present on this forum but easily spotted as "DV52" on other VW forums, who has terrific insight into the coding of lights, and who may be able to assist. Quote Link to comment Share on other sites More sharing options...
7.5R Posted April 22, 2021 Author Report Share Posted April 22, 2021 I live in the UK and the tail lights came stock, i also have the pro version of OBDeleven. This is how my lights look currently. Quote Link to comment Share on other sites More sharing options...
dv52 Posted April 22, 2021 Report Share Posted April 22, 2021 7.5R: Hi. First my thanks to @Chris7.5R for his kind words - whilst he has grossly overstated my expertise, I agree 101% with his views about NOT (meaning - never) use OBD11 Apps; they are fraught with problems then stuff goes pear-shape - they leave little, if any records of the changes that were made and they rob the user of valuable opportunities to learn how the vehicle is programmed!! Their ONLY advantage is that they are easy to implement - but the cost of this advantage can be very high indeed!!! But, enough of the sermonizing - let's focus on the problem!! Truth is that the OBD11 App could have made any number of changes that would result in the behavior that you have described. I understand from your posts that the outer turn-signal lamps operate correctly and that the problem is with the inner turn-signal lamps (both sides). If my understanding is correct, then perhaps a way-forward is to compare the programming instructions on your car for operating the inner/outer turn-signal lamps, maybe? My apology, but I have to start talking technical stuff to explain what I need to make this comparison. On a Golf mk7.5, each of the 35 x exterior lamps is managed by what I call a "Leuchte-set" - which is a group of 19 x values (these are called "adaptation channels") that are associated by a name that commences with the word Leuchte (which is German for "lamp"). Here's a couple of pertinent examples: Leuchte18BLK HLA60 = Leuchte-set for the outer turn-signal lamp on the left-side of the car Leuchte23SL HLC10 =Leuchte-set for the inner turn-signal lamp on the left-side of car To make the comparison, I need to see the FULL set of values for the 2 x Leuchte-sets above. I don't need to see both right-side and left-side Leuchte-sets; I can deduce the other side by viewing just one-side. So do this, please: Go to the central electrics module (it has "09" in a colored-circle -see below) Select Adaptation In the search box, enter "Leuchte" navigate down the list to Leuchte18BLK HLA60 and select Take screenshot(s) containing ALL 19 x values Repeat for Leuchte23SL HLC10 Paste copies of screenshots in a new post here Don PS:.....and, please make Back-up files for each of the modules in your car - they will be invaluable when (not "if") the damp loose stools collide with the fan blades!!! XAV2JZ 1 Quote Link to comment Share on other sites More sharing options...
Chris7.5R Posted April 23, 2021 Report Share Posted April 23, 2021 9 hours ago, dv52 said: 7.5R: Hi. First my thanks to @Chris7.5R for his kind words - whilst he has grossly overstated my expertise, I agree 101% with his views about NOT (meaning - never) use OBD11 Apps; they are fraught with problems then stuff goes pear-shape - they leave little, if any records of the changes that were made and they rob the user of valuable opportunities to learn how the vehicle is programmed!! Their ONLY advantage is that they are easy to implement - but the cost of this advantage can be very high indeed!!! PS:.....and, please make Back-up files for each of the modules in your car - they will be invaluable when (not "if") the damp loose stools collide with the fan blades!!! Thanks Don, reliable as ever! Quote Link to comment Share on other sites More sharing options...
7.5R Posted April 23, 2021 Author Report Share Posted April 23, 2021 Hello these are the pictures requested, thank you both for your help. Quote Link to comment Share on other sites More sharing options...
dv52 Posted April 24, 2021 Report Share Posted April 24, 2021 @7.5R: Arrhhhhhh.................... there's your problem!!! Do this: Go to the central electrics module Select Adaptation Enter "HLC10" into the search box and select Leuchte23SL HLC10 Navigate to Lichtfunktion A 23 and change setting to Blinken links Hellphase Activate the SLIDE TO WRITE function to implement change When asked for a security code, enter 31347 Go back to step 3 screen above, Enter "HRA65" into search box and select Leuchte24SL HRA65 Navigate to Lichtfunktion A 24 and change setting to Blinken rechts Hellphase Activate the SLIDE TO WRITE function to implement change (note the difference "links" and "rechts" above) Don Quote Link to comment Share on other sites More sharing options...
Chris7.5R Posted April 24, 2021 Report Share Posted April 24, 2021 12 hours ago, dv52 said: @7.5R: Arrhhhhhh.................... there's your problem!!! Do this: Go to the central electrics module Select Adaptation Enter "HLC10" into the search box and select Leuchte23SL HLC10 Navigate to Lichtfunktion A 23 and change setting to Blinken links Hellphase Activate the SLIDE TO WRITE function to implement change When asked for a security code, enter 31347 Go back to step 3 screen above, Enter "HRA65" into search box and select Leuchte24SL HRA65 Navigate to Lichtfunktion A 24 and change setting to Blinken rechts Hellphase Activate the SLIDE TO WRITE function to implement change (note the difference "links" and "rechts" above) Don Don, not sure this is correct for the OP's car. If his 2017 7.5 is the same as my 2019 7.5 (full LED and dynamic rear indicators) then his setup should probably look like mine. Here is my complete rear setup ex-factory (sorry about the size, I couldn't work out how to make it more compact): 16BLK SLB35BLK SL KC9 Indicator rear inside left A 16 Blinken links Hellphase B 16 nicht aktiv AB 16 127 / always C 16 / D 16 / E 16 / F 16 / G 16 / H 16 nicht aktiv CD 16 / EF 16 / GH 16 0 / maximise 17TFL R BLK SRB3TFL R BLK SR KC3 Indicator rear inside right A 17 Blinken rechts Hellphase B 17 nicht aktiv AB 17 127 / always C 17 / D 17 / E 17 / F 17 / G 17 / H 17 nicht aktiv CD 17 / EF 17 / GH 17 0 / maximise 18BLK HLA60 Indicator rear outside left A 18 Blinken links Hellphase B 18 nicht aktiv AB 18 127 / always C 18 / D 18 / E 18 / F 18 / G 18 / H 18 nicht aktiv CD 18 / EF 18 / GH 18 0 / maximise 19BLK HRC31 Indicator rear outside right A 19 Blinken rechts Hellphase B 19 nicht aktiv AB 19 127 / always C 19 / D 19 / E 19 / F 19 / G 19 / H 19 nicht aktiv CD 19 / EF 19 / GH 19 0 / maximise 20BR LA71 Brake light left A 20 Bremslicht B 20 nicht aktiv AB 20 127 / always C 20 / D 20 / E 20 / F 20 / G 20 / H 20 nicht aktiv CD 20 / EF 20 / GH 20 0 / maximise 21BR RC8 Brake light right A 21 Bremslicht B 21 nicht aktiv AB 21 127 / always C 21 / D 21 / E 21 / F 21 / G 21 / H 21 nicht aktiv CD 21 / EF 21 / GH 21 0 / maximise 22BR MA57 Third (centre) brake light A 22 Bremslicht B 22 nicht aktiv AB 22 100 / always C 22 / D 22 / E 22 / F 22 / G 22 / H 22 nicht aktiv CD 22 / EF 22 / GH 22 0 / maximise 23SL HLC10 Parking light rear inside left A 23 Standlich allgemein (Schlusslicht, Positionslicht, Begrenzungslicht) B 23 Parklicht links (beidseitiges Parklicht aktiviert li & re) AB 23 127 / always C 23 / D 23 / E 23 / F 23 / G 23 / H 23 nicht aktiv CD 23 / EF 23 / GH 23 0 / maximise 24SL HRA65 Parking light rear inside right A 24 Standlich allgemein (Schlusslicht, Positionslicht, Begrenzungslicht) B24 Parklicht rechts AB 24 127 / always C 24 / D 24 / E 24 / F 24 / G 24 / H 24 nicht aktiv CD 24 / EF 24 / GH 24 0 / maximise 25KZL HA59 Number plate light A 25 Standlich allgemein (Schlusslicht, Positionslicht, Begrenzungslicht) B 25 nicht aktiv AB 25 127 / always C 25 / D 25 / E 25 / F 25 / G 25 / H 25 nicht aktiv CD 25 / EF 25 / GH 25 0 / maximise 26NSL LA72 Fog light rear right inside, with no trailer, LH traffic A 26 Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr B 26 nicht aktiv AB 26 127 / only_if_closed C 26 / D 26 / E 26 / F 26 / G 26 / H 26 nicht aktiv CD 26 / EF 26 / GH 26 0 / maximise 27NSL RC6 Active flashing function has an assigned bit set to 1 in pa_dynamic_blinking A 27 Aktive Blinkfunktion hat ein auf 1 gesetztes zugeordnetes Bit in pa_dynamisch_blinken B26 nicht aktiv AB 27 127 / always C 27 / D 27 / E 27 / F 27 / G 27 / H 27 nicht aktiv CD 27 / EF 27 / GH 27 0 / maximise 28RFL LC11 Reversing light left A 28 Rueckfahrlicht B 28 nicht aktiv AB 28 127 / only_if_closed C 28 / D 28 / E 28 / F 28 / G 28 / H 28 nicht aktiv CD 28 / EF 28 / GH 28 0 / maximise 29RFL RA64 Reversing light right / Fog light with no trailer, LH traffic A 29 Rueckfahrlicht B 29 nicht aktiv AB 29 127 / only_if_closed C 29 Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr D 29 nicht aktiv CD 29 0 / minimise E 29 / F 29 / G 29 / H 29 nicht aktiv EF 29 / GH 29 0 / maximise Quote Link to comment Share on other sites More sharing options...
dv52 Posted April 24, 2021 Report Share Posted April 24, 2021 @Chris7.5R: hmm.......... yes, I have cars in my database dedicated to the inside turn-signal lamps with both my assumed Leuchte-sets and those on your list. I can't say with certainty which are correct because the arrangement is highly variable in the country of sale and for the build year. But it isn't a big issue because all that will happen is that the wrong tail light lamp will blink and the setting will need to be reverted back to original - not difficult. I'm always willing to rely on local knowledge if at all possible -so if your car is UK sold, then I suggest that OP follow your list for 16BLK SLB35BLK SL KC9 and 17TFL R BLK SRB3TFL R BLK SR KC3 as a first try. If the tweak lights-up incorrect lamps, revert the settings and try my Leuchte-sets Don Quote Link to comment Share on other sites More sharing options...
Chris7.5R Posted April 25, 2021 Report Share Posted April 25, 2021 7 hours ago, dv52 said: @Chris7.5R: hmm.......... yes, I have cars in my database dedicated to the inside turn-signal lamps with both my assumed Leuchte-sets and those on your list. I can't say with certainty which are correct because the arrangement is highly variable in the country of sale and for the build year. But it isn't a big issue because all that will happen is that the wrong tail light lamp will blink and the setting will need to be reverted back to original - not difficult. I'm always willing to rely on local knowledge if at all possible -so if your car is UK sold, then I suggest that OP follow your list for 16BLK SLB35BLK SL KC9 and 17TFL R BLK SRB3TFL R BLK SR KC3 as a first try. If the tweak lights-up incorrect lamps, revert the settings and try my Leuchte-sets Don At least he already has the Pro version to try to sort it out. I'd suggest checking for any differences between the current settings and my set, make a careful note, and revert everything to 'factory'. Once it's working any other changes can be carefully reapplied and tested. NO F###### APPS! Quote Link to comment Share on other sites More sharing options...
XAV2JZ Posted July 27, 2022 Report Share Posted July 27, 2022 Hey Guys, i am having problem with my North American mk7.5 2018 Golf R... Bought OEM mk7.5 Dynamic Tail lamps, USP Motorsport mk7.5 wiring harness for dynamic tails... Tried to go with the easy route with OBDEleven Shop DAP Dynamic tail light adaptations.... Dynamic flasher were just lighting on n off like regular lights... So i went and modified the adaptations manually to get the dynamic flasher sequence following the USP Motorsport installation guide... Now my passenger flasher is not working and the left flasher trigger left and right flashers with the dynamic sequence at the same time. Hazard lights works as they should. @dv52 @Chris7.5R you guys seem to be pretty knowledgeable on how those lamps works and on the adapatations required. If some one i willing to help i could upload screen shots of the adaptations ! Thank you Quote Link to comment Share on other sites More sharing options...
dv52 Posted July 27, 2022 Report Share Posted July 27, 2022 Xavier: Depends on lots of variables - fundamentally, how the car's rear lights was factory fitted - which determines how many wires are in the wiring loom from the hex09 module to the connectors for the tail-light lamps. The other important aspect of your project is the choice of harness -which re-arranges the factory assignments of the Leuchte-sets to different lamps on your new rear fittings. There are lots of different ways to make these reassignments, so it's important that the coding changes are correct for the particular harness that is used. So -need to understand the fundamentals first : what type of lamps (LED, or incandescent) were built into the car from the factory? What were the coding changes made and have you double-checked that the changes made are correct? What do you mean by "OEM mk7.5 Dynamic Tail lamps" - did you buy these from VW, or did you rely on third-party manufacturer claims that their fitting were OEM? Provide details of the fittings (URL address) Why did you choose USP Motorsport mk7.5 wiring harness? Provide details of exact product (URL address) Don Quote Link to comment Share on other sites More sharing options...
XAV2JZ Posted July 28, 2022 Report Share Posted July 28, 2022 Hey Don ! Thanks for your answer an your time ! - The type of taillights that were on the car originally are the LED from North-America on the mk7.5 golf r -The tail lamp installed the mk7.5 dynamic led bought from a dealler in germany shipped trought someone i know in Belgium I bought the usp motorsport because it is the only one i found at the time link from wiring harness and tail lamp since you cant buy the harness alone now ( bought mine last year ): https://www.uspmotorsports.com/MK7.5-Facelifted-LED-Tail-Lights-2018.html link for install and coding : https://www.uspmotorsports.com/get_doc.php?file=4465a802bda9c8a51e43212e460be3f6 -The change made are the following: step 1. 1. Under Channel (16B) Select ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20 2. Set “New Value” to 127 3. Select “Do it!” To finalize the change. step 2. 1. Under Channel (16B) Select ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20 2. Set “New Value” to 34 – LED Bremsleuspchten 3. Select “Do it!” To finalize the change. step 3 1. Under Channel (16B) Select ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20 2. Set “New Value” to not active step 4 1. Under Channel (16B) Select ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20 2. Set “New Value” to not active step 5 1. Under Channel (16B) Select ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion E 20 2. Set “New Value” to not active step6 1. Under Channel (16B) Select ENG116956-ENG116256-Leuchte21BR RC8- Dimmwert AB 21 2. Set “New Value” to 127 step 7. 1. Under Channel (16B) Select ENG116956-ENG116259-Leuchte21BR RC8-Lasttyp 21 2. Set “New Value” to 34 - LED Bremsleuspchten Step 8. 1. Under Channel (16B) Select ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21 2. Set “New Value” to not active Step9 8. 1. Under Channel (16B) Select ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21 2. Set “New Value” to not active 3. Select “Do it!” To finalize the change. FACELIFTED DYNAMIC LED TAIL 15 LIGHTS WITH HARNESS FOR MK7 INSTALLATION INSTRUCTIONS 9. 1. Under Channel (16B) Select ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21 2. Set “New Value” to not active 3. Select “Do it!” To finalize the change. 10. 1. Under Channel (16B) Select ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion E 21 2. Set “New Value” to not active 3. Select “Do it!” To finalize the change. 11. 1. Under Channel (16B) Select ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23 2. Set “New Value” to 127 3. Select “Do it!” To finalize the change. 12. 1. Under Channel (16B) Select ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp23 2. Set “New Value” to 38 - LED Blinkleuchten 3. Select “Do it!” To finalize the change. 13. 1. Under Channel (16B) Select ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23 2. Set “New Value” to not active 3. Select “Do it!” To finalize the change. 14. 1. Under Channel (16B) Select ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23 2. Set “New Value” to Blinken links Hellphase 3. Select “Do it!” To finalize the change. 15. 1. Under Channel (16B) Select ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24 2. Set “New Value” to 127 3. Select “Do it!” To finalize the change. 16. 1. Under Channel (16B) Select ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24 2. Set “New Value” to 38 - LED Blinkleuchten 3. Select “Do it!” To finalize the change. 17. 1. Under Channel (16B) Select ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24 2. Set “New Value” to not active 3. Select “Do it!” To finalize the change. 18. 1. Under Channel (16B) Select ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24 2. Set “New Value” to Blinken rechts Hellphase 3. Select “Do it!” To finalize the change. 19. 1. Under Channel (16B) Select ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27 2. Set “New Value” to 127 3. Select “Do it!” To finalize the change. 20. 1. Under Channel (16B) Select ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27 2. Set “New Value” to 32 - allgemeine LED bis 12W 3. Select “Do it!” To finalize the change. 21. 1. Under Channel (16B) Select ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefekbitposition 28 2. Set “New Value” to 00 (You must input a double zero) 3. Select “Do it!” To finalize the change. Quote Link to comment Share on other sites More sharing options...
