NLou Posted September 18, 2024 Report Share Posted September 18, 2024 I’m hoping to find someone else who has had this same issue. I follow every step perfectly in order to code the exhaust valves open permanently but when I get to the page under Engine01 to change Byte9/Hex4, I click on Byte/9 but my Hex says 0C instead of 4. Also bit 2 and bit 3 are ticked, instead of only bit 2 and when I try to untick either of them and save, i get a error code saying Function is not available. I am UK based and have tried on both android and ios devices. Has anyone else had this same issue? Any help would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
AHG Posted September 18, 2024 Report Share Posted September 18, 2024 Not sure how to change it as I never code bits directly, just through the menus. What I can say is the 0C in Hexadecimal means 12 in decimal (Hex is base 16, so each digit can have 1-9 or A-F as 10-16) So if in binary bit 2 is 4 (2^2) maybe bit 3 is 8 (2^3) So if both are “on” (1 instead of 0) it comes to 12 decimal or 0C in Hex If you can turn off bit 3 (so it’s 0) and leave bit 2 on you should get 4 in Hex Re coding, do you have SFD unlock on auto ? Quote Link to comment Share on other sites More sharing options...
NLou Posted September 18, 2024 Author Report Share Posted September 18, 2024 That’s interesting, I would’ve had no idea about any of that. Thanks for the information. If I managed to turn off bit 3, then left on bit 2, I would still need the values to equal 0, would I not? No idea, I haven’t touched anything to do with that, where is that setting? However I did manage to turn down the soundaktor and disabled lane assist on start up with no issues Quote Link to comment Share on other sites More sharing options...
