MIB2 issues
alexx
To get the DAB logos i had to add stations as favourites (hold down the numbered square boxes). Once they were favourited the logos appeared. No faffing about with sd cards.
Yeah, I think this is what my dealer did to get them.  He said he'd set up all the main stations he thought I'd need/want and they were all there with the logos.
That worked. I feel a bit stupid now!
Still having issues with the previous track button (both on the steering wheel and the display) selecting the next track on Spotify when using USB. Works fine on BT Audio.
It's in the dealer today to look at the sticky clutch, as well as a few other bits (including the aforementioned 'no audio' issues). I mentioned the odd lack of MirrorLink or App Connect on the menu (so I don't even see the 'this feature requires activation' screen), and sure enough it's there as an option with the activation screen on the little Polo they've lent me. Previous track works fine too, so I don't think it's the iPhone or the cable.
I did ask if they could throw in Apple Carplay activation for free whilst they were at it. Not sure they got the hint but we'll see  :grin:
So, back from Ridgeway. They couldn't find anything wrong with the clutch, and the software on the MIB II unit is apparently the latest version. Is there a way I can double check this? Still waiting for the writeup so not 100% sure.
I borrowed their master technician for a test drive, who was quite certain you couldn't add Mirrorlink/App Connect/etc post factory - at least not yet. He did say that the hardware was in there, just not activated - then explained the flow of info from the mothership down through VW UK and then to the dealers. Showed him the odd previous track issue, he's quite certain it's an iPhone thing.
There you go. No news for now...
To access your system info and find out which hardware and software you have:
On MIB2 unit Press Menu button, scroll right to Setup, scroll down to System Information and it will display your versions like this:
This is from my car which I've had 4 weeks.
Thanks, I've not got nav (just standard MIB II unit), not sure how to upload a photo either but:
Device part number: 3Q0035820A
Hardware: 523
Software: 0617
In the meantime I've had a quick chat with and a long email from the dealer, a few interesting things have come out of it:
1. The vehicle isn't fitted with the 'Carnet' function, they're going to check next time whether this can be activated. There is some info from VW but it's very limited.
2. The previous track issue with the iPhone 6 when connected via USB is being suggested as a iOS issue, as opposed to a VW software issue.
3. Software 0617 is the latest available, but there's a hint from VW that there's a newer version in the works that fixes some of the issues I've been having.
I guess we just sit and wait now. If only VW handled software updates more like Apple etc...
  • 2 months later...
Just to update this thread, I got a software update at my dealer about a week and a half ago. Not seen the problems with black screens or no audio on startup, but DAB reception is still a little hit and miss on startup. "Previous track" works fine on Spotify now when connected via USB, although cover art is still a little hit and miss. Also, now playing info doesn't always refresh properly after track change, and "&" in an artist title on Spotify seems to truncate the artist to everything before the &.
Not had a change to get the full version info for comparison, will try and do that tomorrow. Still no sign of App Connect in the menu, but more on my experienced with that here: http://www.vwroc.com/forums/topic/11933-app-connect-can-now-be-retrofitted-by-vw-on-2016my-golfs/
  • 2 months later...
Hi Alexx,
Just done a search and it pointed me to your thread -
I collected my R yesterday and I am blown away with it so far, even without giving it too much throttle as running it in a little.
On my way back this afternoon though I could not get any sound from DAB or FM radio - this was solved by switching off and then back on.
Is this a known issue?
Can I ask what software version your car is now running ?
Many thanks.
Hi Alexx,
Many thanks.
I'll try and remember to check the software version in the morning, but it's the latest available as far as I'm aware. Having similar problems to you with no audio on DAB, FM, Bluetooth or USB, been meaning to check with the dealer but been a bit busy with work stuff. Needs to go in as got a problem with one of the wheels and possibly a suspension issue, so I'll add that to the list.. :)
