R with MIB 2
Royg
Hi
i want to get some vcds mods done on my car but heard about problems with mib 2 deleting menus. Does the latest Ross Tech cable sort this?
thanks roy
Roy: Hi. Yes, you are correct - there were some early compatibility problems with the (then) new MIBII and VCDS cable . The problems were only for the HEX+CAN and MICRO HEX cables - there were no problems with the HEX NET cables. My understanding was that the  problems related to the slower speed of the older cables and their ability to correctly interface with the newer 24 bit structure of the MIBII units.
But the problem was solved with software version 15.7.3. So you MUST use this SW version or a higher number  (it's good practice to ALWAYS use the current release software - which is version 15.7.4)
PS: If you are intending to modify  the MIBII unit, you might be interested in the "Off-road" tweak below
http://www.vwwatercooled.com.au/forums/f197/vcds-vag-com-codes-programmable-options-golf-mk7-84619-post1171042.html#post1171042
Edited by dv52
