Fault Code keeps appearing
Chriss5471
Afternoon all!
I am using OBDEleven to scan my car and I keep getting a fault code appear.  It is in the Transmission Control Module and it states -> Starter release from the selector level sensor system.  Fault Code P173400 (10763) Status: Intermittent.
I get no other symptoms and just get this come up.  Any ideas if I should be worried?
  • 2 weeks later...
  • 3 months later...
Afternoon all!
Have you tried to clear the code and do the scan with only the ignition on? (Car not running) I don't have OBDEleven but with VCDS when you access the transmission module with the car running you can get some errors pop up. Take a look at this thread also http://www.vwroc.com/forums/topic/17518-error-code-on-new-car/
