Chris1h Posted November 12, 2016 Report Share Posted November 12, 2016 Whoever has this done... does your break light (top of rear window) flash when indicating and then break at same time? Quote Link to comment Share on other sites More sharing options...
wayne.gill1 Posted November 12, 2016 Report Share Posted November 12, 2016 Whoever has this done... does your break light (top of rear window) flash when indicating and then break at same time?No my top brake light doesn't flash Sent from my E6853 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Stobsie Posted November 12, 2016 Report Share Posted November 12, 2016 No mine doesn't flash, sounds like you have a problem. Quote Link to comment Share on other sites More sharing options...
Chris1h Posted November 13, 2016 Author Report Share Posted November 13, 2016 No my top brake light doesn't flash Sent from my E6853 using Tapatalk No mine doesn't flash, sounds like you have a problem. balls! is it easy enough to set it back to stock and try again? Quote Link to comment Share on other sites More sharing options...
Stobsie Posted November 13, 2016 Report Share Posted November 13, 2016 balls! is it easy enough to set it back to stock and try again? You can change anything back if you know what you've changed I do use vag com but unfortunately I'm no expert but I'm sure somewhere within it, it logs changes you've made? Think we have a member on here dv52 who knows his stuff. Quote Link to comment Share on other sites More sharing options...
wayne.gill1 Posted November 13, 2016 Report Share Posted November 13, 2016 Just set it at all the std features ill have a look after Sent from my E6853 using Tapatalk Quote Link to comment Share on other sites More sharing options...
dv52 Posted November 14, 2016 Report Share Posted November 14, 2016 hmm......... not sure what the problem is here, but the Leuchte22BR MA57 "Leuchte-set" controls the 3rd brake-light function! If your car has strange stuff occurring to the 3rd Brake-light, it might be prudent to look through the Adplog.CSV file that resides in the Ross-Tech/VCDS/Debug directory on the laptop that you used to make changes. Look specifically for any records that alter settings in the Leuchte-set above and revert to the "old value" indicated in the record Don Stobsie and Chris1h 2 Quote Link to comment Share on other sites More sharing options...
Stobsie Posted November 14, 2016 Report Share Posted November 14, 2016 ^^ see told you he knows his stuff. Quote Link to comment Share on other sites More sharing options...
Chris1h Posted November 14, 2016 Author Report Share Posted November 14, 2016 ^^ see told you he knows his stuff. cheers pal! hmm......... not sure what the problem is here, but the Leuchte22BR MA57 "Leuchte-set" controls the 3rd brake-light function! If your car has strange stuff occurring to the 3rd Brake-light, it might be prudent to look through the Adplog.CSV file that resides in the Ross-Tech/VCDS/Debug directory on the laptop that you used to make changes. Look specifically for any records that alter settings in the Leuchte-set above and revert to the "old value" indicated in the record Don sweet will look into this mate thanks for the help Quote Link to comment Share on other sites More sharing options...
