Activate rear view camera (OBDeleven coding)
slider09
I recently completed a MIB1 to MIB2 conversion in my 2015 MK7 GTI but the reverse camera isn't working. The camera is the factory lowline that came originally with the car. The screen comes up with the settings but the screen is black. I believe that I need to change the settings in 76 parking assistance module but when I try to bring up in OBD11 it shows a black circle around the number in the corner and won't load. Is there a way to enable those settings?
@casgka: Hi.
At this early stage in understanding this problem - I suspect that it's not a matter of "enabling those settings"
I'm not sure if you are aware of the "Gateway Installation List" (GIL) - it's the thing that the CAN network in a car uses to understand which modules have been installed in the car and therefore which modules are authorized to communicate on the CAN buses! Without a GIL, the CAN network would need to poll every possible module address and ask if the module is present - which is extremely inefficient and unnecessary!
The OBD11 software tells the user about the status of a module in respect of the GIL via the color of "the number in the corner" (the actual number is the module address in hexadecimal system of counting - look it up)
The status indicator at top right corner is decoded in the following way:
  • *GREEN = Control unit is in working condition and without any trouble codes.
  • *RED = Control unit is in working condition but it has some trouble codes.
  • *YELLOW = Control unit is in working condition but it is not installed in Gateway installation list.
  • *BLACK = Control unit is installed into Gateway but it is not reachable.
  • *WHITE = Control unit is currently offline.
So - in your case, the Black indicator means that for some reason, the hex76 module is not talking to the main CAN spine.  Please post-up a copy of the SCAN report for the car
Thanks so much for your help on this matter. I'm new to this and learning so any info is greatly appreciated. Below is the full scan report from the OBD11.
OBDeleven data log
Date: 2023-12-13 09:21
VIN: 3VW4T7AU0FM039466
Car: Volkswagen Golf GTI
Year: 2015
Body type: 5-dr hatchback
Engine: CXCA
Mileage: 292636 KM
01 Engine
System description: 2.0l R4 TFSI
Software number: 5G0906259A
Software version: 0004
Hardware number: 06K907425B
Hardware version: H13
ODX name: EV_ECM20TFS0205G0906259A
ODX version: 001006
Long coding: 091D00124424002F1000
Trouble codes:
P003000 - O2 Sensor Heater Contr. Circ.(Bank1(1)Sensor 1)
static
Date: 2023-12-11 13:35:48
Mileage: 292442 km
Priority: 2
Malfunction frequency counter: 1
Unlearning counter: 255
Engine speed: 697.75 1/min
Normed load value: 9.0 %
Vehicle speed: 0 km/h
Coolant temperature: 105 °C
Intake air temperature: 63 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.277 V
Dynamic environmental data: 209628110E0216E00211AB000011DC000210BF800010BD2A2910C004CD
P164D00 - Reduced oil pressure switch Malfunction
Intermittent
Date: 2023-12-12 06:31:58
Mileage: 292489 km
Priority: 2
Malfunction frequency counter: 8
Engine speed: 792.75 1/min
Normed load value: 9.8 %
Coolant temperature: 97 °C
Intake air temperature: 12 °C
Voltage terminal 30: 14.335 V
Dynamic environmental data: 209628110E0211EC0811DC050911ED2310A6019911EE2011DB01BD
P030100 - Cyl.1 Misfire Detected
Intermittent
Date: 2023-12-11 13:36:01
Mileage: 292442 km
Priority: 2
Engine speed: 691.50 1/min
Coolant temperature: 106 °C
Voltage terminal 30: 14.355 V
Dynamic environmental data: 209623110E0211EC0811DC000F202F0ECF10C00400141C000011DB018E
P201400 - Intake Manifold Runner Position Sensor/Switch Circuit
Intermittent
Date: 2023-12-11 13:35:44
Mileage: 292442 km
Priority: 2
Malfunction frequency counter: 35
Engine speed: 702.25 1/min
Normed load value: 7.8 %
Coolant temperature: 103 °C
Intake air temperature: 26 °C
Voltage terminal 30: 14.003 V
Dynamic environmental data: 209628110E0211EC0811DC063211ED1D10A6019911EE1F11DB0141
02 Transmission
System description: DQ250-6F MQB
Software number: 0D9300041T
Software version: 4511
Hardware number: 02E927770AQ
Hardware version: H53
Serial number: TFK01407221108
ODX name: EV_TCMDQ250021
ODX version: 001001
Long coding: 0014
Trouble codes:
No trouble codes found
03 Brakes
System description: ESC
Software number: 5Q0907379K
Software version: 0371
Hardware number: 5Q0907379F
Hardware version: H31
Serial number: 52384000000051
ODX name: EV_Brake1UDSContiMK100ESP
ODX version: 033001
Long coding: 01FA6BA134230975007B020681C92980D62C9000408194B400430050C009
Trouble codes:
08 Air Conditioning
System description: AC Manuell
Software number: 5G0907426R
Software version: 0907
Hardware number: 5G0907426R
Hardware version: H02
ODX name: EV_ACManueBHBVW37X
ODX version: 003019
Long coding: 00020004200100000000000000000000
Trouble codes:
09 Central Electrics
System description: BCM PQ37BOSCH
Software number: 5Q0937087N
Software version: 0106
Hardware number: 5Q0937087N
Hardware version: 028
Serial number: 86581709141389
ODX name: EV_BodyContrModul1UDSBosc
ODX version: 013004
Long coding: 001118464041826969E44000001407201800000000000000000000000000
Subsystems:
System description: WWS 140824
Software version: 0581
Hardware version: 043
Serial number: 141013032021
Long coding: 0E4DDD
System description: RLS
Software version: 0059
Hardware version: 037
Serial number: S4Y14M09D09H00M23S14
Long coding: 00A8DD
System description: J245 PS73.014
Software version: 0007
Serial number: WOO31229876
Long coding: 181801
Trouble codes:
B12BA15 - Left front side marker lamp bulb Open circuit/short circuit to B+
static
Mileage: 292442 km
Priority: 2
Unlearning counter: 201
Terminal 15 status: On
Terminal 50 status: Off
Voltage: 14.3 V
Outside air temperature: 14.5 °C
Status Bremslichtschalter (HW): Off
Status Bremslichtschalter (CAN): Off
Off: not activated
Parking light: not activated
Automatic high beam assist: operated
Low beam: not activated
Parking light left: not activated
Parking light right: not activated
Letzte Weckursache/ Werte [00;2E]: keine Störschutzursache
CAN-Bus_aktiv: On
B12BB15 - Right front side marker lamp bulb Open circuit/short circuit to B+
static
Mileage: 292442 km
Priority: 2
Voltage: 14.2 V
Off: not activated
CAN-Bus_aktiv: On
B1806F0 - Heated seat passenger's side Safety shutdon due to occupant detection
Intermittent
Date: 2023-12-11 17:15:38
Mileage: 292481 km
Priority: 6
Malfunction frequency counter: 6
Unlearning counter: 247
Terminal 15 status: Off
Voltage: 12.4 V
Outside air temperature: 5.5 °C
Off: not activated
CAN-Bus_aktiv: On
15 Airbag
System description: AirbagVW20
Software number: 5Q0959655T
Software version: 0825
Hardware number: 5Q0959655T
Hardware version: 009
Serial number: 003MHM012V5H
ODX name: EV_AirbaVW20SMEVW37X
ODX version: 002138
Long coding: 8CCCFC00000000005000001AC24800000065
Subsystems:
System description: BF-Gewichtss.
Software version: 0016
Hardware version: H05
Serial number: IBH0000J140001ESUK0Y
Long coding: 303331
System description: SideSensor_Df
Software version: 0887
Hardware version: 001
Serial number: 357000000008857DE01S
Long coding: 2D2D2D
System description: SideSensor_Pf
Serial number: 3580000000074D4C801M
Long coding: 2D2D2D
System description: SideSensor_Dr
Software version: 6149
Serial number: 3510002A116DB804519.
Long coding: 2D2D2D
System description: SideSensor_Pr
Serial number: 3520002C116FC221706Y
Long coding: 2D2D2D
System description: FrontSensor_D
Serial number: 3550002B916FC22592FI
Long coding: 2D2D2D
System description: FrontSensor_P
Serial number: 3560002B916FC224124%
Long coding: 2D2D2D
Trouble codes:
16 Steering Column
System description: Lenks.Modul
Software number: 5Q0953521AT
Software version: 0175
Hardware number: 5Q0953569A
Hardware version: 075
Serial number: 20140905400292
ODX name: EV_SMLSVALEOMQB
ODX version: 001015
Long coding: 0410
Trouble codes:
17 Dashboard
System description: KOMBI
Software number: 5G1920856
Software version: 4270
Hardware number: 5G1920856
Hardware version: 342
ODX name: EV_DashBoardVDDMQBAB
ODX version: 009037
Long coding: 0BAD091A2180CF0502086A001000000000000000
Trouble codes:
19 Gateway
System description: GW MQB Mid
Software number: 5Q0907530S
Software version: 2186
Hardware number: 5Q0907530L
Hardware version: 211
Serial number: 16081410000698
ODX name: EV_GatewConti
ODX version: 011017
Long coding: 0101000820085900EF0000281C0F00000001050000000000000000000000
Subsystems:
System description: E221__MFL-DC1
Software version: 0101
Hardware version: H10
Serial number: 27140002344440054385
Long coding: 29FFFF
Trouble codes:
U104E00 - Parallel parking assistance control module No communication
static
Date: 2023-12-11 19:04:27
Mileage: 292487 km
Priority: 2
Malfunction frequency counter: 23
Unlearning counter: 207
Supply voltage, terminal 30: 14.3 V
Terminal 15: On
U104C00 - Rearview camera system control module No communication
Intermittent
Date: 2023-12-11 19:19:08
Mileage: 292487 km
Priority: 2
Malfunction frequency counter: 7
Unlearning counter: 245
Supply voltage, terminal 30: 14.4 V
Terminal 15: On
U106A00 - Digital sound system control module No Communication
Intermittent
Mileage: 292442 km
Priority: 2
Unlearning counter: 241
Terminal 15: On
U112600 - Undefined control module No communication
Intermittent
Date: 2023-12-11 18:44:27
Mileage: 292487 km
Priority: 2
Malfunction frequency counter: 9
Unlearning counter: 244
Terminal 15: On
U110100 - Component protection active
static
Mileage: 292442 km
Priority: 4
Unlearning counter: 206
Terminal 15: On
2B Steering Column Lock
System description: ELV-MQBA
Software number: 5Q0905861A
Software version: 0120
Hardware number: 5Q0905861A
Hardware version: H01
Serial number: 14000216544001
ODX name: EV_ELVMarquMQB
ODX version: 004111
Long coding: 5D00000000000000
Trouble codes:
42 Driver Door
System description: TSG FS
Software number: 5Q0959593B
Software version: 0025
Hardware number: 5Q0959593B
Hardware version: 020
Serial number: 240914060504RL
ODX name: EV_DCUDriveSideEWMAXKLO
ODX version: 006003
Long coding: 003E13200000040000000000
Subsystems:
System description: FOND_FHSG_DRV
Software version: 0005
Hardware version: 005
Serial number: 00000000000003561474
Long coding: 011000
Trouble codes:
44 Steering Assistance
System description: EPS_MQB_ZFLS
Software number: 3Q0909144F
Software version: 5043
Hardware number: 3Q0909144F
Hardware version: 503
ODX name: EV_SteerAssisMQB
ODX version: 010031
Long coding: 8102
Trouble codes:
52 Passenger Door
System description: TSG BFS
Software number: 5Q0959592B
Hardware number: 5Q0959592B
Serial number: 04101406050BAJ
ODX name: EV_DCUPasseSideEWMAXKLO
ODX version: 006003
Subsystems:
System description: FOND_FHSG_PSG
Serial number: 00000000000003464302
Long coding: 191000
Trouble codes:
5F Multimedia
System description: MU-S-N-CN
Software number: 3GD035866A
Software version: 0976
Hardware number: 3GD035866A
Hardware version: 872
ODX name: EV_MUStd4CDELP
ODX version: 001001
Long coding: 02140605FF00000041150002001028001F0300F401200500C6
Subsystems:
System description: ABT_High-2
Software version: 9304
Hardware version: 180
Serial number: VWZ6ZWA2125281
Trouble codes:
B200500 - Data record invalid
static
Date: 2023-12-12 14:37:10
Mileage: 292528 km
Priority: 2
Unlearning counter: 205
Dynamic environmental data: 02868B
B201A00 - Checking software version management
static
Mileage: 292528 km
Priority: 6
Dynamic environmental data: 02868B100243302F312D3E312C4D302F312D3E3200
static
Mileage: 292528 km
Priority: 4
U111100 - Function limitation due to missing message
static
Date: 2023-12-12 14:37:13
Mileage: 292528 km
Priority: 6
Dynamic environmental data: 02868B184402
static
Mileage: 292528 km
Priority: 6
static
Date: 2023-12-12 14:43:48
Mileage: 292528 km
Priority: 6
static
Mileage: 292528 km
Priority: 6
75 Telematics
System description: OCULowMQBUS
Software number: 5QE035285
Software version: 0528
Hardware number: 5QE035285
Hardware version: 006
ODX name: EV_OCULowMQB
ODX version: 001003
Long coding: 02730002C2823A017F1E06000000
Trouble codes:
B1788F0 - Control module Immobilizer deactivated
static
Date: 2023-12-13 09:17:21
Mileage: 292636 km
Priority: 8
76 Parking Assistance
Trouble codes:
A9 Structure Borne Sound
System description: SAS-GEN 2
Software number: 5G0907159
Software version: 0014
Hardware number: 4H0907159A
Hardware version: H06
Serial number: 140521203000
ODX name: EV_SoundActuaGen2AU64X
ODX version: 003010
Trouble codes:
B7 Start System Interface
System description: VWKESSYMQB
Software number: 5Q0959435A
Software version: 0604
Hardware number: 5Q0959435
Hardware version: 021
Serial number: 0343306289
ODX name: EV_KessyHellaMQBAB
ODX version: 002011
Long coding: 030C0C
Trouble codes:
hmm.......... strange!!!
Look at the entry for the 76 Parking Assistance module on your SCAN.  Your report has recognized that the module is installed in this car and the module appears to be correctly registered on the GIL  - but the SCAN has failed to return the module detail!! I suspect that this is the reason for the black colored marking mentioned in your first post.
So, a mk7/mk7.5 Golf operates 6 x separate CAN buses that are aligned mostly on a functional basis - meaning that the various modules are loosely allocated to a particular CAN bus depending on what a module controls. Individual modules have the ability to talk to the other CAN buses if their operations so require  - they do this by requesting permission to speak across CAN buses from the Gateway module (you can think of the Gateway module like the Fat-Controller of Tomas-The-Tank-Engine fame 😉)
For example, the new MIB that you installed is allocated to the Infotainment CAN bus. However, the Parking Assistance module is allocated to the Running gear CAN bus - so it's a tad odd that the 76 module would be impacted by the MIB upgrade exercise!
Not sure what's happened to this car.  Stuff that comes to mind below:
  1. Do you have a SCAN from this car from an earlier time that shows the 76 module fully cooperating with a diagnostic test? Maybe this problem pre-existed the MIB upgraded - I'm guessing. of course?
  2. What happens if you try to access the 76 module directly from the Control Units screen (i.e. by clicking on the module with the black colored marking)?
  3. Maybe try clearing ALL errors and provide a fresh SCAN for the car
  4. Was the new MIB hacked for Component Protection - or did you manage the CP error in the 5F module via a dealer?
  5. The long-code string on the new MIB is telling (from the software switch values for the SATNAV region - the unit appears to have come from China). Have you made any changes to the long-code settings?
Below is answers to your questions. Thanks again for helping me on this. I cleared everything and ran a new scan. Hope this helps a bit.
U104E00 - Parallel parking assistance control module No communication - Cleared by changing adaptation to not coded
  1. Do you have a SCAN from this car from an earlier time that shows the 76 module fully cooperating with a diagnostic test? Maybe this problem pre-existed the MIB upgraded - I'm guessing. of course? Unfortunately, I didn't take a scan beforehand.
  2. What happens if you try to access the 76 module directly from the Control Units screen (i.e. by clicking on the module with the black colored marking)? When I try to click on the module it says it can't be contacted and try again. I also added to the list manually so not sure if that makes a difference.
  3. Maybe try clearing ALL errors and provide a fresh SCAN for the car I cleared and ran a fresh scan.
  4. Was the new MIB hacked for Component Protection - or did you manage the CP error in the 5F module via a dealer? I believe it was pre-hacked for Component Protection.
  5. The long-code string on the new MIB is telling (from the software switch values for the SATNAV region - the unit appears to have come from China). Have you made any changes to the long-code settings? It did come from China and I changed some of the long coding to get the sound to work as it wasn't working when I first installed the unit.
Date: 2023-12-14 08:21
Year: 2015
Engine: CXCA
Mileage: 292739 KM
01 Engine
ODX version: 001006
Trouble codes:
static
02 Transmission
ODX version: 001001
Long coding: 0014
Trouble codes:
03 Brakes
ODX version: 033001
Trouble codes:
08 Air Conditioning
ODX version: 003019
Trouble codes:
ODX version: 013004
Subsystems:
Long coding: 0E4DDD
Long coding: 00A8DD
Long coding: 181801
Trouble codes:
15 Airbag
ODX version: 002138
Subsystems:
Long coding: 303331
Long coding: 2D2D2D
Long coding: 2D2D2D
Long coding: 2D2D2D
Long coding: 2D2D2D
Long coding: 2D2D2D
Long coding: 2D2D2D
Trouble codes:
16 Steering Column
ODX version: 001015
Long coding: 0410
Trouble codes:
17 Dashboard
ODX version: 009037
Trouble codes:
19 Gateway
ODX version: 011017
Subsystems:
Long coding: 29FFFF
Trouble codes:
static
ODX version: 004111
Trouble codes:
42 Driver Door
ODX version: 006003
Subsystems:
Long coding: 011000
Trouble codes:
ODX version: 010031
Long coding: 8102
Trouble codes:
52 Passenger Door
ODX version: 006003
Subsystems:
Long coding: 191000
Trouble codes:
5F Multimedia
ODX version: 001001
Subsystems:
Trouble codes:
static
Date: 2023-12-14 08:20:22
Mileage: 292739 km
Priority: 2
Unlearning counter: 210
Dynamic environmental data: 028676
static
Date: 2023-12-14 08:20:21
Mileage: 292739 km
Priority: 6
Dynamic environmental data: 028676100243302F312D3E312C4D302F312D3E3200
static
Mileage: 292739 km
Priority: 4
static
Date: 2023-12-14 08:20:24
Mileage: 292739 km
Priority: 6
Dynamic environmental data: 028676184402
static
Mileage: 292739 km
Priority: 6
static
Mileage: 292739 km
Priority: 6
75 Telematics
ODX version: 001003
Trouble codes:
static
Mileage: 292739 km
Priority: 8
ODX version: 003010
Trouble codes:
ODX version: 002011
Long coding: 030C0C
Trouble codes:
"U104E00 - Parallel parking assistance control module No communication - Cleared by changing adaptation to not coded" ?????????????????????????????????????????
What does this mean - which "adaptation to not coded" exactly?
There is now no 76 Parking Assistance module reported in the SCAN!! Does this car have a 76 module? Are you using Android, or iOS?
What country s thus?
Sorry I was out of town for a few days.
The adaptation was in 19 Gateway. I'll have to look to see exactly where the adaptation was located in there. I'll send once I have my car later today.
I have to add module 76 so I'm not sure if that means it's there for sure.
I'm using Android.
I'm located in the US.
