Link Posted July 7, 2017 Report Share Posted July 7, 2017 The clocks don't illuminate when the headlight switch is set to side lights. Seems a odd feature. Is there a way to code the interior illumination the same for the side light position as it is for headlights ? I.e on Quote Link to comment Share on other sites More sharing options...
ashleyman Posted July 7, 2017 Report Share Posted July 7, 2017 You can code the instrument lights to be on at all times of day in Auto, DRL Only or On switch position. If you have the switch to Off, then they'll revert to stock settings. Quote Link to comment Share on other sites More sharing options...
Link Posted July 7, 2017 Author Report Share Posted July 7, 2017 Only thanks. By DRL only do you mean side lights ? (Not true DRL only, when in off position) Quote Link to comment Share on other sites More sharing options...
dv52 Posted July 8, 2017 Report Share Posted July 8, 2017 19 hours ago, Link said: The clocks don't illuminate when the headlight switch is set to side lights. Seems a odd feature. Is there a way to code the interior illumination the same for the side light position as it is for headlights ? I.e on Link - Hi. Try this: Open controller [17-Instruments] [Security Access-16] > Enter 25327 [Adaptation-10] > Select ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm Change from parking_light to lds (lds is what VW call the rotary light switch) Don Link 1 Quote Link to comment Share on other sites More sharing options...
Link Posted July 8, 2017 Author Report Share Posted July 8, 2017 Thanks Don, will give it a try😀 Quote Link to comment Share on other sites More sharing options...
