Jon R306 Posted September 22, 2017 Report Share Posted September 22, 2017 1 minute ago, Yas_Man said: Yeah, I didn't want to believe it so I called Ohlins myself, they confirmed the don't have a kit and not enough interest to develop one. That said there are peeps on here with the GTI kit and love it. Gutted ...you and I both...😒 Quote Link to comment Share on other sites More sharing options...
JamieRb Posted September 23, 2017 Report Share Posted September 23, 2017 Hi mate I’ve got the Vwr street sport plus suspension. I’ve had my car corner weighted it’s sat about 30mm rear and 20mm front lower than stock and the ride and handling is epic !Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Jon R306 Posted September 23, 2017 Report Share Posted September 23, 2017 Hi mate I’ve got the Vwr street sport plus suspension. I’ve had my car corner weighted it’s sat about 30mm rear and 20mm front lower than stock and the ride and handling is epic ! Sent from my iPhone using Tapatalk Great stuff..... Please more info... Are you DCC .? What size wheels and tyre's? is the ride over awful roads teeth chattering ? Any pics? Etc etc please Thanks mate Much appreciated Quote Link to comment Share on other sites More sharing options...
Msportman Posted September 23, 2017 Report Share Posted September 23, 2017 Hi mate I’ve got the Vwr street sport plus suspension. I’ve had my car corner weighted it’s sat about 30mm rear and 20mm front lower than stock and the ride and handling is epic ! Sent from my iPhone using Tapatalk Aren't the VWR kits made by AST or AP? Ive heard they are pretty good on the 7R. Quote Link to comment Share on other sites More sharing options...
Msportman Posted September 23, 2017 Report Share Posted September 23, 2017 I've had the same issues on every car with springs with the exception of my M4 Comp Pack, it's just on AC Schnitzer springs but they are perfect, a little lower, not quite as stiff as the OEM ones so the car tracks much better but that's the only time springs have improved handling and that't on 20" wheels and 35mm rubber. The combo of ARBs and coils are perfect, they are still stiff but not harsh which is a massive difference, plus if I ever want to track it, I can just stiffen them up. All the adjustment is under the car so unlike the KWs you don't have to pull them out to change the settings. My KW Clubsports adjusted under the cars with a rotary dial up to 20 settings. This adjusted compression. All coilover sets I've found adjust rebound whilst the units are off the car. The latest KW Clubsports adjust at the top the only problem being is there's no room to get into the turrets. You'd have to cut a fair amount of structure to get good access. Likewise camber adjustments can be a workshop only pain in the proverbial if your constantly changing camber for trackdays. I found the B16 and KWV3's very closely matched the KW's were slightly softer damped on their lowest setting compared to the B16's. Both very good kits. The Clubsports are stiffer still by approx 15%. re Spring rates. Id choose either V3's or B16's and ditch DCC Jon R306 1 Quote Link to comment Share on other sites More sharing options...
Yas_Man Posted September 23, 2017 Author Report Share Posted September 23, 2017 That's good feedback and I'd agree that the KWs are softer on their softest setting but then they are too soft. I used to run my KWs on 5 where the Bilsteins are perfect on 1 - 2. Jon R306 1 Quote Link to comment Share on other sites More sharing options...
