m3anmachin3 Posted December 12, 2017 Report Share Posted December 12, 2017 Hi all, My car has done 34k miles and I don't think the haldex fluid has ever been changed, not according to the service booklet anyway. I'm unable to find the service kit anywhere online, will I have to purchase from be direct, or is there a genuine retailer I can buy these from please? Thanks Quote Link to comment Share on other sites More sharing options...
LouCyffer Posted December 12, 2017 Report Share Posted December 12, 2017 Here you are m3anmachin3 1 Quote Link to comment Share on other sites More sharing options...
VRSNorthampton Posted December 12, 2017 Report Share Posted December 12, 2017 Hi @m3anmachin3, If you don't fancy braving the cold, we can offer a Haldex service for £99+VAT. We only use genuine parts and ensure that the filter is cleaned as part of the work. Quote Link to comment Share on other sites More sharing options...
m3anmachin3 Posted December 12, 2017 Author Report Share Posted December 12, 2017 2 hours ago, LouCyffer said: Here you are Thanks very much LouCyffer 1 Quote Link to comment Share on other sites More sharing options...
m3anmachin3 Posted December 12, 2017 Author Report Share Posted December 12, 2017 3 hours ago, LouCyffer said: Here you are Are you aware of any guides with a walk-through video tutorial and links for the parts, by any chance? Quote Link to comment Share on other sites More sharing options...
LouCyffer Posted December 12, 2017 Report Share Posted December 12, 2017 7 hours ago, m3anmachin3 said: Are you aware of any guides with a walk-through video tutorial and links for the parts, by any chance? That’s the extent of the tutorials as far as I know m3anmachin3 1 Quote Link to comment Share on other sites More sharing options...
slider09 Posted December 14, 2017 Report Share Posted December 14, 2017 It’s an easy DIY, I did mine a couple of months ago. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
m3anmachin3 Posted December 14, 2017 Author Report Share Posted December 14, 2017 10 hours ago, slider09 said: It’s an easy DIY, I did mine a couple of months ago. Sent from my iPhone using Tapatalk Slider, where did you get all your bits please mate? Quote Link to comment Share on other sites More sharing options...
skip72 Posted January 10, 2018 Report Share Posted January 10, 2018 On 12/12/2017 at 11:13, m3anmachin3 said: Are you aware of any guides with a walk-through video tutorial and links for the parts, by any chance? i found this yesterday whilst researching the same topic as I'm sure mine is not performing as it should http://forums.vwvortex.com/showthread.php?8908177-MK7-Haldex-Fluid-Change-DIY Quote Link to comment Share on other sites More sharing options...
m3anmachin3 Posted January 10, 2018 Author Report Share Posted January 10, 2018 2 hours ago, skip72 said: i found this yesterday whilst researching the same topic as I'm sure mine is not performing as it should http://forums.vwvortex.com/showthread.php?8908177-MK7-Haldex-Fluid-Change-DIY Thank you mate, this is the guide I used I've done mine now and it has improved albeit not a lot, but then my filter wasn't as clogged after 35k miles as some other members. Quote Link to comment Share on other sites More sharing options...
R-Estate Posted January 10, 2018 Report Share Posted January 10, 2018 Thank you mate, this is the guide I used I've done mine now and it has improved albeit not a lot, but then my filter wasn't as clogged after 35k miles as some other members.Did you buy/use new plugs? Quote Link to comment Share on other sites More sharing options...
m3anmachin3 Posted January 10, 2018 Author Report Share Posted January 10, 2018 7 minutes ago, R-Estate said: Did you buy/use new plugs? Nope I used the same old plugs. I drove home after servicing and checked under the car having parked for about 10 mins and saw no leaks. All I used was:- 1. Syringe and hose 2. Haldex fluid 3. jug to catch the old fluid 4. T30 Torx to remove the two bolts on the filter housing 8mm hex for drain plug key and 5mm hex key for fill plug Nothing extra Quote Link to comment Share on other sites More sharing options...
R-Estate Posted January 10, 2018 Report Share Posted January 10, 2018 Nope I used the same old plugs. I drove home after servicing and checked under the car having parked for about 10 mins and saw no leaks. All I used was:- 1. Syringe and hose 2. Haldex fluid 3. jug to catch the old fluid 4. T30 Torx to remove the two bolts on the filter housing 8mm hex for drain plug key and 5mm hex key for fill plug Nothing extraPerfect, that’s all I have too, just need to find the time..... Quote Link to comment Share on other sites More sharing options...
m3anmachin3 Posted January 10, 2018 Author Report Share Posted January 10, 2018 Good luck! Quote Link to comment Share on other sites More sharing options...
skip72 Posted January 16, 2018 Report Share Posted January 16, 2018 On 10/01/2018 at 07:15, skip72 said: i found this yesterday whilst researching the same topic as I'm sure mine is not performing as it should http://forums.vwvortex.com/showthread.php?8908177-MK7-Haldex-Fluid-Change-DIY so as predicted the local VW dealer has confirmed my Haldex is no longer working. I have a manual 2014 r with 30,000 miles. frustrating or what. They've just quoted me £460 for a repair kit. What the hell is the in the repair kit, gold? I asked the question several times about the specifics of the failure but I seem to be met with blank faces. Needless to say the price is too high in my opinion, especially when I'm told that VW have issued a service bulletin on this. As the car is now out of warranty I'm no longer going to darken the doors of VW, I'll be going back to the VW / Audi specialist I used to use. rant almost over as this is quite possibly the least robust car I've ever owned. which is a shame because when everything works, wow what a car. Quote Link to comment Share on other sites More sharing options...
