Warmachine34 Posted May 9, 2018 Report Share Posted May 9, 2018 Hi folks, in the last couple of days, a warning light indicating that my ACC ( active criuse control) is not functioning has appeared on my dashboard. Thr first day it happened, I turned the car off and gave the box at the front of the car a clean and it went off with no issues. It however came on again this evening and turning the engine off seemed to reset it as again the light disappeared with the ACC functioning fine after both occasions. When the light comes on, the car does not let you engage the ACC as when you try it comes up with “Error ACC” My car is a 14 plate R. Anyone else had similar issues please? sorry for the long post Quote Link to comment Share on other sites More sharing options...
DerekLauMusic Posted May 9, 2018 Report Share Posted May 9, 2018 Hi folks, in the last couple of days, a warning light indicating that my ACC ( active criuse control) is not functioning has appeared on my dashboard. Thr first day it happened, I turned the car off and gave the box at the front of the car a clean and it went off with no issues. It however came on again this evening and turning the engine off seemed to reset it as again the light disappeared with the ACC functioning fine after both occasions. When the light comes on, the car does not let you engage the ACC as when you try it comes up with “Error ACC” My car is a 14 plate R. Anyone else had similar issues please? sorry for the long post Has the car had a knock on the front bumper? Has the car had tracking done? Has the car had a steering rack replacement? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Warmachine34 Posted May 9, 2018 Author Report Share Posted May 9, 2018 Hi none of the above. Can’t say I remember hearing a stone hitting the front at any point ta Quote Link to comment Share on other sites More sharing options...
75Type2 Posted May 9, 2018 Report Share Posted May 9, 2018 Worth getting the car scanned as there are engine faults such as the cam actuator that can lead to the car giving ACC fault. I believe@Marshy had this problem. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Warmachine34 Posted May 9, 2018 Author Report Share Posted May 9, 2018 Cheers bud. I’ll look at taking it in to VW but the issue would be the fault staying on long enough to show the dearler Quote Link to comment Share on other sites More sharing options...
