Umaar Posted May 29, 2018 Report Share Posted May 29, 2018 I have a mk 7.5 R Estate and wanted to activate the front tear drop for the wipers. I found instructions saying to do it in 09 Cent Electronics and activate in the adaptations after putting in the security code. So I have changed Traenenwischen Front Status to active but its still not working. Anyone had any luck on activating on a mk7.5? Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb Part No SW: 5Q0 937 086 BL HW: 5Q0 937 086 BG Component: BCM PQ37BOSCH 034 0245 Revision: -------- Serial number: 8658040118004I Shop #: WSC 00028 028 00067 ASAM Dataset: EV_BodyContrModul1UDSBosc 018001 ROD: EV_BCMCONTI.rod VCID: 05424D3C8467616C14-8050 Control Unit For Wiper Motor: Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB Component: WWS 171213 042 0551 Serial number: 171221071634 Coding: 0E4DDD Rain Light Recognition Sensor: Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB Component: RLHS 047 0105 Serial number: S5Y18M01D19H04M40S35 Coding: 00A8DD Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Portia12 Posted May 29, 2018 Report Share Posted May 29, 2018 What's tear drop ?! Quote Link to comment Share on other sites More sharing options...
Umaar Posted May 29, 2018 Author Report Share Posted May 29, 2018 What's tear drop ?!It’s a delayed after wipe of the windscreen after using the windscreen washer. It helps to get rid of any drops of water still on the windscreen. Sent from my iPhone using Tapatalk Modena 1 Quote Link to comment Share on other sites More sharing options...
Portia12 Posted May 29, 2018 Report Share Posted May 29, 2018 1 minute ago, Umaar said: It’s a delayed after wipe of the windscreen after using the windscreen washer. It helps to get rid of any drops of water still on the windscreen. Sent from my iPhone using Tapatalk Every day's a school day.... Modena 1 Quote Link to comment Share on other sites More sharing options...
Umaar Posted August 16, 2018 Author Report Share Posted August 16, 2018 Anyone worked this out yet?Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
8YARWY Posted August 17, 2018 Report Share Posted August 17, 2018 Try going into the Longcoding there used to be a bit you can uncheck/check to enable/disable it. Quote Link to comment Share on other sites More sharing options...
Umaar Posted August 17, 2018 Author Report Share Posted August 17, 2018 Try going into the Longcoding there used to be a bit you can uncheck/check to enable/disable it. I’ve tried that method and also the adaptations way and doesn’t seem to work. The mk7 seems to work through adaptations but not the 7.5Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Callum 86 Posted September 3, 2018 Report Share Posted September 3, 2018 Clever little mod Quote Link to comment Share on other sites More sharing options...
Umaar Posted September 3, 2018 Author Report Share Posted September 3, 2018 Clever little mod You got it working on mk7.5?Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
