DEKA1967 Posted August 11, 2018 Report Share Posted August 11, 2018 Not sure if this is in the right section but here goes Turned the light switch from auto to off back to auto & now have above indication on the dashHave checked for blown bulbs but all are okMain beam & rear lights are on when the car is running and trying to turn the lights off by the switch does nothing apart from still able to turn the fog light onAny help would be appreciated Car is 2015 R Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
dv52 Posted August 12, 2018 Report Share Posted August 12, 2018 decca: do you have access to a diagnostic cable - perhaps some one near-by has one (like VCDS, or ODB11). It would help to get a more definitive error message. At face value, purely a guess - sounds like a faulty light switch - but a cable would confirm my hunch - or not Don Quote Link to comment Share on other sites More sharing options...
DEKA1967 Posted August 12, 2018 Author Report Share Posted August 12, 2018 decca: do you have access to a diagnostic cable - perhaps some one near-by has one (like VCDS, or ODB11). It would help to get a more definitive error message. At face value, purely a guess - sounds like a faulty light switch - but a cable would confirm my hunch - or not DonYeah that's what I thought going to take it along to the garage tomorrow to see if they can diagnose it better Thanks for the reply DEKASent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
DEKA1967 Posted September 6, 2018 Author Report Share Posted September 6, 2018 Well ended up taking the car to my local VW Stealership Fault was wiring behind the dash was shorting out which was causing the headlight on off switch to burn out All fixed nowBut my wallet is £430 lighterSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Charles M Posted September 6, 2018 Report Share Posted September 6, 2018 Dodgy wiring harness loom to me is a manufacturing fault. How old is your car? Had it with a 5 series once when I was in the middle of France. Shorting out and blew 5 of my cylinders while I limped home (the garage was a little surprised that I actually made it!). Got a good will payment, not that I was particularly happy with that - 7hink it was a £1600 bill rather than £2500 or somewhat similar. Quote Link to comment Share on other sites More sharing options...
DEKA1967 Posted September 6, 2018 Author Report Share Posted September 6, 2018 Dodgy wiring harness loom to me is a manufacturing fault. How old is your car? Had it with a 5 series once when I was in the middle of France. Shorting out and blew 5 of my cylinders while I limped home (the garage was a little surprised that I actually made it!). Got a good will payment, not that I was particularly happy with that - 7hink it was a £1600 bill rather than £2500 or somewhat similar. Car is a 2015 model Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
bogdan1106 Posted June 1, 2019 Report Share Posted June 1, 2019 Hello ! I have the same problem, all the bulbs are ok. . I made a test and i don't have errors. When I am connect with BCM, the error disappear. So what can i do? My car is Octavia 3, 2013... Thank you so much! Quote Link to comment Share on other sites More sharing options...
desi Posted February 15, 2020 Report Share Posted February 15, 2020 Hi bogdan1106.. you or anyone else in this thread have any luck with this yet? Thanks Quote Link to comment Share on other sites More sharing options...
bogdan1106 Posted February 17, 2020 Report Share Posted February 17, 2020 not yet. I'm struggle with this.. Quote Link to comment Share on other sites More sharing options...
dv52 Posted February 20, 2020 Report Share Posted February 20, 2020 ^^^^ have you checked the wiring harness at the rear of the rotary light switch )(it's called "LDS)? It's real easy to remove the LDS - see video link below Look for faulty wiring, bent pins etc Quote Link to comment Share on other sites More sharing options...
bogdan1106 Posted February 20, 2020 Report Share Posted February 20, 2020 Every thing is ok.Also, I have checked with vcds and it's working.. I think it's a problem with the BCM. Quote Link to comment Share on other sites More sharing options...
bogdan1106 Posted February 5, 2021 Report Share Posted February 5, 2021 Hello. I have fixed this strange problem. I have changed the BCM and now everything it's ok NRW 1 Quote Link to comment Share on other sites More sharing options...
Shanealdo Posted March 23, 2023 Report Share Posted March 23, 2023 Hi recently a fault warning light came up on my mark 7 golf. First I noticed the auto handbrake light wasn't on. Then where my main car light stitch beside steering wheel is no matter if I move it my lights are constantly on. Noticed today then one of my spot lights isn't on now either but I got no warning for that. Anyone ever come across this? Help would be greatly appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
dv52 Posted March 24, 2023 Report Share Posted March 24, 2023 Shane: Hi. hmm.... we really need a lot more information to understand this problem. Do you happen to own a diagnostic device - like OBDeleven, or VCDS? If so, it would be extremely helpful if you posted-up a SCAN report - this will tell us how this car is equipped and it will show how the car's self diagnostic facility has analyzed this fault. Your car is a very complex computerized piece of metal! Without a diagnostic device - it's going to be very difficult to progress this matter, alas Don Quote Link to comment Share on other sites More sharing options...
