Pebbles1070 Posted September 18, 2018 Report Share Posted September 18, 2018 Hi folks New to Golf R but previous 3 cars have been Golf GTI 35 editionehite, Golf R32 white and Golf R32 Black - I now have s Golf R in silver and each and every time I reverse the gear knob pops up but doesn’t jump out of gear but you can see and hear the gear knob pop up. Anyone have any history with this issue or anyone have any knowledge of where to start. Specialist dealer has had it over the weekend and tightened gear linkage?? I think they said but it’s still popping each and every reverse? Thanks in advance for any pointers. Apart from this I’m loving the purrr of my new baby girl (my car is always a girl I am sexist like that) Quote Link to comment Share on other sites More sharing options...
gazlaa72 Posted September 18, 2018 Report Share Posted September 18, 2018 Hello there I have exactly the same issue when selecting reverse as been like this for a while now and no idea why its happening but at least someone else is experiencing it like me as i didn't know whether to post this a while back but didn't know how to put it? I take it you have a manual like myself and not DSG and also a 2015 model? Quote Link to comment Share on other sites More sharing options...
Pebbles1070 Posted September 18, 2018 Author Report Share Posted September 18, 2018 Hi Gazlaa72 Yes manual would touch DSG and yip 2015. It’s nit an issue but I’m worried it is an issue longer term like could this be causing extra wear and tear in something else and I land up with hefty bill for something it’s being doing since I picked it up. Dealer been fab I must admit painter bumper as I spotted light peeling if the lacquer and tightened it adjusted the gear linkage but that’s not helped the issue at all 😕 Quote Link to comment Share on other sites More sharing options...
gregozedobe Posted September 19, 2018 Report Share Posted September 19, 2018 I wonder if the engine/gearbox is moving in the mounts ? I'm thinking that when you are driving forward the torque is twisting the engine/gearbox in one direction, then when you start moving in reverse the force is going in the opposite direction, and as the gear lever is connected to the gearbox by cables this movement at the gearbox is being transmitted to the gear lever. To test if my theory is correct select reverse, drive backwards for a few feet, then push the clutch in, stop, select neutral, select reverse again then drive backwards for another few feet. If the gear lever doesn't pop up the second time in reverse then my theory seems to hold true. In that case, unless your engine & gearbox mounts are failing then you don't have a problem. Quote Link to comment Share on other sites More sharing options...
Pebbles1070 Posted September 19, 2018 Author Report Share Posted September 19, 2018 Ok Gregozedobe i will try this when I reach my work car park (may look I can’t park but worth trying anything) many thanks 👍🏼 Fingers crossed your theory holds true. I will advise back as any person has the same issues. Quote Link to comment Share on other sites More sharing options...
Pebbles1070 Posted September 19, 2018 Author Report Share Posted September 19, 2018 This theory unfortunately doesn’t fit the bill - since the gear linkage has been tightened on Monday it pops as soon as it’s shifted into reverse I don’t even have to move I tried neutral/reverse several times and not moving even an inch but each and every time I go into reverse it pops Quote Link to comment Share on other sites More sharing options...
gregozedobe Posted September 19, 2018 Report Share Posted September 19, 2018 Oh well, scratch that theory (but it was worth trying as it cost you nothing). Time for some more questions: Does it feel like it is engaging reverse properly, or perhaps only partially engaging and then when you first start to let the clutch out it is fully engaging and moving the gear lever ? If it is this, my first suspect is that the cables that go into the gearbox need adjusting (same place as where they can become loose). A gearbox specialist may do this better than a regular maintenance workshop. Do you ever have problems selecting reverse ? I do with my (manual) Octavia, and I have to select 2nd, then I can select reverse. Is your clutch fully disengaging ? One symptom is the friction point is quite low to the floor, another symptom is rough (or even slightly crunching) when going from 1st to 2nd, more noticeable when the gearbox is cold. Any other issues with changing gears, even if it just feels different for some gears cf with others. Quote Link to comment Share on other sites More sharing options...
Hicksyyyy Posted September 19, 2018 Report Share Posted September 19, 2018 I am in the same boat with this issue. my mk5 gearbox had no issue but I've even had it at the lights about to pull away and it's clipped reverse ! it was normal conditions and it wasn't forced into place as I'm a conscious gear changer as it is Sent from my SM-G935F using Tapatalk Quote Link to comment Share on other sites More sharing options...
GGSL Posted September 20, 2018 Report Share Posted September 20, 2018 17 hours ago, Hicksyyyy said: I am in the same boat with this issue. my mk5 gearbox had no issue but I've even had it at the lights about to pull away and it's clipped reverse ! it was normal conditions and it wasn't forced into place as I'm a conscious gear changer as it is Sent from my SM-G935F using Tapatalk I've had this a few times as well. Seems to only happen when the cars cold and cannot replicate it at all, no idea whether it's just overly sensitive and I've been tired or something, but seeing other people report the same suggests to me that it's an issue with the car. Quote Link to comment Share on other sites More sharing options...
Pebbles1070 Posted September 20, 2018 Author Report Share Posted September 20, 2018 There is no apparent logical reasoning I can find for the “pop up” but getting it booked into dealer again to have a look - they claimed it didn’t happen with them at all but happens every reverse with myself and hubby cold engine or hot. Just totally baffling. Quote Link to comment Share on other sites More sharing options...
gregozedobe Posted September 20, 2018 Report Share Posted September 20, 2018 1 hour ago, Pebbles1070 said: There is no apparent logical reasoning I can find for the “pop up” but getting it booked into dealer again to have a look - they claimed it didn’t happen with them at all but happens every reverse with myself and hubby cold engine or hot. Just totally baffling. Should be easy to demonstrate then Quote Link to comment Share on other sites More sharing options...
Bobamylaura Posted October 6, 2018 Report Share Posted October 6, 2018 Had same problem, took it to local VW dealer he reset gear linkage, hasn't happened again Quote Link to comment Share on other sites More sharing options...
