how to code
MKMike
This may seem a basic question but I can't find it explained anywhere.  When looking at coding instructions (not the apps) on the forum (and other forums) they eem to fall into two categories:
those that take you to a menu, with clear instructions down the screen where you select the option you want and change eg 'activate' to 'deactivate' or '10' to '5'.
those that require changes to Bits and Bytes.
It's the latter I don't understand, and everyone who posts instructions for a particular modification seems to assume a certain level of understanding. And nowhere (that I can find) is there a basic introduction to explain how it works........
  • Replies 8
Posted Images
Thanks harbourmasta
Those links demonstrate my problem perfectly. eg:
Windows: Roll Up/Down with Key
Description: Roll down down your windows with your key remote when you unlock the doors
Check bit 5 of byte 3 in Central Electronics Long Coding Helper
Option: If you want to be able to do this when the car is turned on, check bit 7 of byte 3
Option: Enable your lock switch on the door to roll all windows up/down without a key present, check bits 3, 4, and 7 of byte 3
No explanation of what or where "bit 5" is or how to change!
What are you trying to code? I've done a few YouTube videos on coding with walkthroughs. Can always knock one together if you're struggling with anything
Found similar instructions here:
https://www.stemei.de/pages/coding/vw-golf-7/umfeldbeleuchtung-immer-aktiv.php
The following coding applies:
  1. Select STG 52 (Beifahr Türelektr..)
  2. STG long coding -> function 07
  3. byte 01
  4. Disable Bit 5
  5. Select STG 42 (driver Türelektr.)
  6. STG long coding -> function 07
  7. byte 01
  8. Disable Bit 5
But equally confusing!
