MKMike Posted October 23, 2018 Report Share Posted October 23, 2018 This may seem a basic question but I can't find it explained anywhere. When looking at coding instructions (not the apps) on the forum (and other forums) they eem to fall into two categories: those that take you to a menu, with clear instructions down the screen where you select the option you want and change eg 'activate' to 'deactivate' or '10' to '5'. those that require changes to Bits and Bytes. It's the latter I don't understand, and everyone who posts instructions for a particular modification seems to assume a certain level of understanding. And nowhere (that I can find) is there a basic introduction to explain how it works........ Quote Link to comment Share on other sites More sharing options...
harbourmasta Posted October 24, 2018 Report Share Posted October 24, 2018 Hi, While i currently dont have an OBD Eleven ( i will at some point soon-ish) i found these from the OBDEleven forum, they might be helpful to you. All VAG carswww.vcdscoding.com/ - no longer available www.stemei.de/pages/coding.phpde.vcds.wikia.com/wiki/Hauptseitewww.audienthusiasts.com/www.automd.com/tsb/audi_m/www.automd.com/tsb/volkswagen_m/www.automd.com/recall/audi_m/www.automd.com/recall/volkswagen_m/www.volkspage.net/technik/ssp/index4_eng.phpwww.nikutronics.eu/home/info/v-a-g-obdwww.gerritspeek.nl/vag-com_aanpassingen.htmlonedrive.live.com/view.aspx?resid=3AE6945C79E4C9E!17729&app=OneNote&authkey=!AMn8y885S2R-6Xg Golf MK Vwww.vaglinks.com/Docs/VW/MKV/DPham00.info_VW_MKV_VAGCOM_Tweaks_And_Info.pdf Golf MK VIwww.golfmk6.com/forums/showthread.php?t=36478 Passat B7www.myturbodiesel.com/wiki/nms-vw-passat-tdi-diy-and-faq-index/ Audi A6 4Fwww.a6-wiki.de/index.php/Codierungen_mit_VCDSh2338967.stratoserver.net/index.php/Thread/72-Codierliste-f%C3%BCr-Audi-A6-4F/www.atomickhome.de/VCDS-Tipps.pdf Octavia 5Ewww.skoda-buben.de/index.php/Thread/471-Skoda-Octavia-III-5E-VCDS-Codierungen/www.briskoda.net/forums/topic/299424-octavia-iii-vcds-adaptations-tried-and-tested/#entry3568822 Tiguanwww.tiguanforum.net/index.php/Thread/1278-CODIERUNGSLISTE-F%C3%9CR-DEN-VW-TIGUAN-I-VON-2007-2015-N5/ Audi A4 B7nickscarblog.com/cars/must-have-vag-com-mods-for-b6-and-b7-audis Read more: http://forum.obdeleven.com/thread/235/links-programming-guides#ixzz5UpslK9fQ Quote Link to comment Share on other sites More sharing options...
harbourmasta Posted October 24, 2018 Report Share Posted October 24, 2018 A few other stuff, https://docs.google.com/document/d/151DX1D0BEs76UfUpJbBAVJ8OhuhEoRPrmxFsUrKiVm0/pub http://obdeleven.proboards.com/thread/1318 Cheers Quote Link to comment Share on other sites More sharing options...
MKMike Posted October 24, 2018 Author Report Share Posted October 24, 2018 Thanks harbourmasta Those links demonstrate my problem perfectly. eg: Windows: Roll Up/Down with KeyDescription: Roll down down your windows with your key remote when you unlock the doors Check bit 5 of byte 3 in Central Electronics Long Coding Helper Option: If you want to be able to do this when the car is turned on, check bit 7 of byte 3 Option: Enable your lock switch on the door to roll all windows up/down without a key present, check bits 3, 4, and 7 of byte 3 No explanation of what or where "bit 5" is or how to change! Quote Link to comment Share on other sites More sharing options...
MKMike Posted October 24, 2018 Author Report Share Posted October 24, 2018 This one lookslike it might help (maybe!) if only I could get it translated into English.....: http://obdeleven.proboards.com/thread/1318 Quote Link to comment Share on other sites More sharing options...
JJB Posted October 24, 2018 Report Share Posted October 24, 2018 17 hours ago, MKMike said: This may seem a basic question but I can't find it explained anywhere. When looking at coding instructions (not the apps) on the forum (and other forums) they eem to fall into two categories: those that take you to a menu, with clear instructions down the screen where you select the option you want and change eg 'activate' to 'deactivate' or '10' to '5'. those that require changes to Bits and Bytes. It's the latter I don't understand, and everyone who posts instructions for a particular modification seems to assume a certain level of understanding. And nowhere (that I can find) is there a basic introduction to explain how it works........ What are you trying to code? I've done a few YouTube videos on coding with walkthroughs. Can always knock one together if you're struggling with anything Quote Link to comment Share on other sites More sharing options...
MKMike Posted October 26, 2018 Author Report Share Posted October 26, 2018 (edited) Edited October 26, 2018 by MKMike Quote Link to comment Share on other sites More sharing options...
MKMike Posted October 26, 2018 Author Report Share Posted October 26, 2018 Mind you not even sure this would be the same for a golf, but it demonstrates the issue I have with some instructions........ Quote Link to comment Share on other sites More sharing options...
MKMike Posted October 26, 2018 Author Report Share Posted October 26, 2018 Found similar instructions here: https://www.stemei.de/pages/coding/vw-golf-7/umfeldbeleuchtung-immer-aktiv.php The following coding applies: Select STG 52 (Beifahr Türelektr..) STG long coding -> function 07 byte 01 Disable Bit 5 Select STG 42 (driver Türelektr.) STG long coding -> function 07 byte 01 Disable Bit 5 But equally confusing! Quote Link to comment Share on other sites More sharing options...
