Mk7 golf estate indicators
marklaxton993
Hi all I have changed my rear indicators bulbs for sweeping led strips which work great, I have brought white and yellow led strips which I want to fit in reversing lights dual purpose indicators and reverse lights in one led strip,does anyone no if You can program reverse lights to do 2 functions
(Leds have separate wires to operate yellow and white lights )https://cloud.tapatalk.com/s/5ef5f14eb0d98/20200626_094612.mp4
Sent from my SM-G986B using Tapatalk
  • Replies 5
If the LEDs have separate wires for white and yellow surely you just need to wire them to the reversing light harness (white) and indicator harness (yellow) each side.
I can’t see why any programming should be necessary.
The difficult problem is getting to the wiring and getting it to the hatch.
mark: It ain't difficult to get reversing lights to also become turn signals. You just need to add the Blicken rechts/links Hellphase/Dunkelphase commands into the Leutche-sets.
But on your car this will just make the white lights illuminate for both the two functions. It won't make the white lights be reversing lights and the yellow lights be turn-signals
11 hours ago, marklaxton993 said:
Can you send me the instructions to the setting for one reversing light side please so it flashes at the same time as the indicator
I certainly can - see below::
Left-side Reverse light
Leuchte28RFL LC11-Lichtfunktion B 28 >  Blinken links Hellphase
Leuchte28RFL LC11-Lichtfunktion C 28 > Blinken links Dunkelphase
Leuchte28RFL LC11-Dimming Direction CD 28 > minimize
Right-side Reverse light
Leuchte29RFL RA64-Lichtfunktion B 29 > Blinken rechts Hellphase
Leuchte29RFL RA64-Lichtfunktion C 29 > Blinken rechts Dunkelphase
Leuchte29RFL RA64-Dimming Direction CD 29 > minimize
You pick which side reversing light you want to flash (or, both sides)!
But, as I have already said - these changes will/should  simply make the reversing lights (white LEDs) flash - the tweak won't illuminate the yellow LEDs, which need to be connected to the turn-signal lamp wires.
