Keyless Entry
mdian
Got to watch this clip, painfully funny acting, especially like the bit when he explains how easy it is to open then has to try twice haha
On this topic, what are the general opinions of the system, wouldn't live without it, or novelty not worth the £355 asking price?
What is the range on these, say from driveway to house is only a few metres!
  • Replies 64
  • Created
  • Last Reply
Top Posters In This Topic
Below Soap Quality Acting :haha: Interesting though , the comment about If the passenger has the Key ,
driver drops him/her off the car still runs when the key is gone ,noticed this the other day ,left the engine
running Key in pocket ,and walked 10 feet to a rubbish bin ,expected it to cut out ,It didn't .
So I assume without a Key in the car you could switch off and lock it ,and then call a Taxi :grin: .
On the whole I like it ,after living with it a few months ,you only need to put a finger Inside the door handle
to open it ,and the same(outside) to lock it . However if you grab the whole handle you can confuse it ,as the two sensors
are activated one after the other ,It's just technique ,never have a problem now . :smiley:
Seems a bit of a faff to be honest. I thought you could just walk away and it would lock itself. Can you still use the old fashioned keyfob method to lock and unlock?
It would be better if they could make it voice activated...
Bloody hell !!!! Eye Scanner next :smiley: . If you are so Inclined the beauty of it is , Walk to car , finger
inside door handle unlocking followed by hand in fluid movement to pull handle ,as you sit down the
steering lock releases ,as you are putting your belt on , foot on brake ,press starter button ,Bingo .
Keys still in pocket with Engine Running ,roll onto left Buttock to break wind ,and the key shaft springs
out in your pocket and sticks in your Leg :haha::haha: ..
To Stop just press starter button , engine stops , parking brake goes on automatically ,get out of the
smell close door , touch indent on outside of door handle ,car locks (steering lock has gone on as well)
Big Clunk LED Indicators flash LOCKED :wink::wink:
PS yes key still works as normal for lock/unlock .
Not sure if anyone answered this, what if your keys are only a few metres away inside the house; will the car open? That is always my concern, plus knowing for sure it is locked without being able to check!
Does anyone know if the 7R comes with a push button start anyway, or is that a specific requirement of the Keyless system? (I know some cars use both, turn ignition on then press start button!)
Can you confirm if it locks if you walk away with the key in pocket?
I'd say the answer is going to be yes neg as Mike posted this above:
"but you can set auto lock in the menu as well in case you forget"
Although hopefully Mike will answer mdian's question on what the range is. If the car is parked on your drive and your keys are in your coat pocket, hung up by the front door, is somebody going to be able to open the car and even start it?
You only get the start/stop ignition button if you order keyless
I'd never had it before until my currant car(didn't spec it dealer order)but it's one of them options for me now I couldn't do without,trouble is I look a right plank now when I try to open my missus car and it won't open,you just forget about ever holding your key or finding to press the button and start the car etc,and in the ford system it lets you know if the keys are not in the car(so you can't turn up to your destination switch your engine off to find out you'd left them somewhere else and your stuck lol.
If it anything like my ex boss's range rover, his keys were always in the front office approx 2-3 metres from the car. His wife would then get in the car and drive down to the shops, half a mile away, get out, do her shopping, then realise she doesn't have keys, and be stranded at the shops with the RR. They never learnt happened at least once a week, very amusing but a bit of a security risk
