Could acc be activated by vcds?
Ben1191
Sorry this isnt for my R so hope its ok, us van owners dont have a forum and when they do nobody is clued up on stuff like this.
I picked up a well specced brand new MAN TGE van a few weeks ago, i selected a comfort plus package which if picked in europe comes with adaptive cruise, but unfortunately doesnt in the uk, however i beleive i have the cameras and radar on the van for it, and even when i start the van up it brings up an adaptive cruise symbol but then disapears once it cant find it.
Do you think vcds may be able to activate it, is that even a thing? Not entirely sure how vcds works.
Ben: Hi
It's going to be impossible to be precise about your "van" because all we know about it is that it's a "van"!! However, if the "van" was built on a MQB platform (as is the Golf mk7) - here's what could happen:
Assuming that the car has the requisite physical equipment installed, the first task would be to make an auto-scan of the vehicle with VCDS. This tells you the starting position for coding purposes.
You would then need to investigate the long-code strings in the control modules. For MQB cars, the specific modules would be @ address: hex01 (Engine), hex03 (ABS), hex09 (Gateway), hex17 (Instrument cluster), hex5F (Infotainment), hexA5 (front facing camera) and finally hex13 (front radar).
So, if you aren't familiar with the term  "long-code" - this is a feature that every module has; it's basically a number that's attached to the module and VCDS reports this number in hexadecimal (hex) nomenclature.  As you may be aware, hex numbers can be translated into binary numbers in which each digit is expressed as either one, or zero. These one/zero states are like a string of software switches which are either ON, or OFF. Each of these software switches has a specific purpose related to the  various available options on the car (like ACC)
This is a long winded way of explaining that the long-code value tells the control module what peripherals are installed in the car and therefore what  functions to operate (and which function to not-operate). On your van, it sounds like some of the software switches for ACC are enabled at the factory, but some are not.
So, the first task is to look at the long-code strings that are reported by the auto-scan report related to the ACC function and to ascertain which software switches have not been enabled at the factory. Fortunately, VCDS helps in this task by describing  the function of lots (but not all)  of the software switches in their "Long Code Helper" screens - so this is where you should start the investigation!
The general long-code instructions for enabling ACC for MQB platform cars (not necessarily your "van") are as follows (note-some of these software switches will already be set in your "van" from the factory):
  • 01 – Engine
    – for manual gearbox, tick ACC – PR-8T5
    – for DSG gearbox, set ACC with Front Assist (PR-8T3, PR-8T8)
  • 03 – ABS (coding for 29 bit) you ned to edit bit 24:
    – for manual gearbox, set: 14 (or 16)
    – for manual gearbox and Lane Assist, set F4
    – for DSG gearbox, set F8
  • 09 – Gateway
    –  Add 13 – Auto Dist. Reg on the installation list
    – Under Adaptation change steering wheel type to ACC
  • 17 – Instrument
    – On the cluster set all the ticks for Front Assist and Distance Regulation
  • 5F – Radio
    – Set all the ticks for Front Assist, ACC and PreCrash
  • A5 – Front Camera
    – Set presence of ACC
  • 13 – Radar
After this, it's then a matter of reviewing what (if any) errors appear and possibly changing the values of adaptation channels in various modules. Adaptation channels are a different feature of control modules - once a software switch in long-code is turned-on to enable a particular function, adaptation channels then tell the module how to operate that function.
Herein endeth the introductory VCDS lesson!!
Hey don,
Thanks for taking the time to explain it properly, so ill have to grab a vcds and find out i guess. The vans exactly the same as the crafter but idk what its built on, it uses the same screen and steering wheel as my golf so a fair bit of its familiar, except the auto box which is an 8 speed zf rather than dsg.(crafter also uses zf)
  • 3 months later...
Hey Ben,
Sorry to bump an older thread... But, were you able to get ACC to work simply by following this coding? I have a Jetta GLI with front assist and I am hoping it is as easy as a few coding changes through VCDS to get ACC to work. As well as the wheel buttons of course. If you could let me know,
Thanks!
