GZOLA25 Posted May 24, 2021 Report Share Posted May 24, 2021 Hi, I used OBDeleven pro for the first time yesterday, however it seems 1 one click app is causing an infotament issue. I have only installed 5 but wanted to reverse them. Whats the best way to do this. I have the history which I think might help. Quote Link to comment Share on other sites More sharing options...
Chris7.5R Posted May 24, 2021 Report Share Posted May 24, 2021 The best answer, which you won't want to hear, is NEVER use the bloody apps. As you now see, they can dump you in deep s@@t if anything goes wrong, or they are not absolutely correct for your specific car. The only safe-ish way to use OBDeleven is to find out exactly what coding is needed and then do it the 'hard' way, by coding and adaptations, with the Pro version. Sorry to be raining on your parade. It's not actually very difficult or unsafe to code explicit values, provided you only use changes that have been well documented by others. So my suggestion is to upgrade to the Pro version and then go thorough the History, writing down all the changes you can see. After that you should be able to explicitly undo everything, then you can try re-applying changes one at a time with careful testing. If any app offers an UNDO option, avoid it like the Covid virus. Very important: document in writing each and every change that you make in future, so your own History will be a reliable guide to what you've done and how to change it. GZOLA25 and Booth11 1 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted May 24, 2021 Report Share Posted May 24, 2021 ^^^ This. Buy the Pro activation code and take the action stated above. Using the apps to make changes leaves you with little control. Coding is not difficult and there is a wealth of coding advice on here and on the OBDeleven pro boards https://forum.obdeleven.com/board/18/golf and always someone that can help out of you need assistance with it. GZOLA25 1 Quote Link to comment Share on other sites More sharing options...
GZOLA25 Posted May 24, 2021 Author Report Share Posted May 24, 2021 4 hours ago, Chris7.5R said: The best answer, which you won't want to hear, is NEVER use the bloody apps. As you now see, they can dump you in deep s@@t if anything goes wrong, or they are not absolutely correct for your specific car. The only safe-ish way to use OBDeleven is to find out exactly what coding is needed and then do it the 'hard' way, by coding and adaptations, with the Pro version. Sorry to be raining on your parade. It's not actually very difficult or unsafe to code explicit values, provided you only use changes that have been well documented by others. So my suggestion is to upgrade to the Pro version and then go thorough the History, writing down all the changes you can see. After that you should be able to explicitly undo everything, then you can try re-applying changes one at a time with careful testing. If any app offers an UNDO option, avoid it like the Covid virus. Very important: document in writing each and every change that you make in future, so your own History will be a reliable guide to what you've done and how to change it. 3 hours ago, Booth11 said: ^^^ This. Buy the Pro activation code and take the action stated above. Using the apps to make changes leaves you with little control. Coding is not difficult and there is a wealth of coding advice on here and on the OBDeleven pro boards https://forum.obdeleven.com/board/18/golf and always someone that can help out of you need assistance with it. Hi there, thanks for the reply. I have the PRO version, I just didn't know it made such a difference. I have only made 5 changes which are still in my history. Multimedia theme, Virtual cockpit style, dashboard, rear parking assist tone and 10 ambient colors. I can still drive the car, Just no infotament system. I'm such a dick lol.... I will start reading how to change these values. there was another value in my history that I didnt do and I think it might be the main issue. Long coding (56)radio both old and new values are the same!!! it says VW diagnostic mode. Thanks again for all the info. Quote Link to comment Share on other sites More sharing options...
GZOLA25 Posted May 24, 2021 Author Report Share Posted May 24, 2021 4 hours ago, Chris7.5R said: The best answer, which you won't want to hear, is NEVER use the bloody apps. As you now see, they can dump you in deep s@@t if anything goes wrong, or they are not absolutely correct for your specific car. The only safe-ish way to use OBDeleven is to find out exactly what coding is needed and then do it the 'hard' way, by coding and adaptations, with the Pro version. Sorry to be raining on your parade. It's not actually very difficult or unsafe to code explicit values, provided you only use changes that have been well documented by others. So my suggestion is to upgrade to the Pro version and then go thorough the History, writing down all the changes you can see. After that you should be able to explicitly undo everything, then you can try re-applying changes one at a time with careful testing. If any app offers an UNDO option, avoid it like the Covid virus. Very important: document in writing each and every change that you make in future, so your own History will be a reliable guide to what you've done and how to change it. I have Written the changes I did in the reply to Booth. Thanks BTW for this brilliant reply, I have the PRO version so I think I better get reading and finding out how I change these 5 values back lol. I'm sure its the multimedia theme that messed it up. All I get is the lovely VW and R logo, touch not working. Thanks again Quote Link to comment Share on other sites More sharing options...
Booth11 Posted May 24, 2021 Report Share Posted May 24, 2021 36 minutes ago, GZOLA25 said: Hi there, thanks for the reply. I have the PRO version, I just didn't know it made such a difference. I have only made 5 changes which are still in my history. Multimedia theme, Virtual cockpit style, dashboard, rear parking assist tone and 10 ambient colors. I can still drive the car, Just no infotament system. I'm such a dick lol.... I will start reading how to change these values. there was another value in my history that I didnt do and I think it might be the main issue. Long coding (56)radio both old and new values are the same!!! it says VW diagnostic mode. Thanks again for all the info. If you get really stuck there is one person who is the authority on OBDeleven who is also a member of this forum that may be able to help you. His name is Don and his username is dv52 so you could always ask him or give him a mention in this thread, he’s helped many a person out. GZOLA25 1 Quote Link to comment Share on other sites More sharing options...
GZOLA25 Posted May 24, 2021 Author Report Share Posted May 24, 2021 11 minutes ago, Booth11 said: If you get really stuck there is one person who is the authority on OBDeleven who is also a member of this forum that may be able to help you. His name is Don and his username is dv52 so you could always ask him or give him a mention in this thread, he’s helped many a person out. Thanks again. Yeah, luckily I just went back into the car abs reverted the multimedia theme back from sport to standard. That brought everything back. My car didn't like it. I've learnt my lesson...... Coding from now on and asking. 😊🤘🤘🤘. Logo gone.... Hello Multimedia Player again 😂😂😂. Cheers Booth11 1 Quote Link to comment Share on other sites More sharing options...
Chris7.5R Posted May 24, 2021 Report Share Posted May 24, 2021 11 minutes ago, GZOLA25 said: Thanks again. Yeah, luckily I just went back into the car abs reverted the multimedia theme back from sport to standard. That brought everything back. My car didn't like it. I've learnt my lesson...... Coding from now on and asking. 😊🤘🤘🤘. Logo gone.... Hello Multimedia Player again 😂😂😂. Cheers 👍 Just one more point: don't get carried away with changing everything. Do one at a time and test it thoroughly before moving on. Any doubts about an updated value, stop and cancel it. As always, ask for help! GZOLA25 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted May 24, 2021 Report Share Posted May 24, 2021 Glad it’s all sorted. Phew! 😅 GZOLA25 1 Quote Link to comment Share on other sites More sharing options...
