EcosseGolfR Posted January 6, 2022 Report Share Posted January 6, 2022 Anyone running Racingline RP700 Front/Rear Brake Pads on their mk7.5 R? Are there any decrease in brake dust or increase in brake noise? Any significant pro's / con's over stock? I'm away to order replacement Vagbremtech J-Hooked disks, so was wondering about pads, i'm currently using Pagid on the rears and stock in the fronts. Brake dust is bad on both. TIA Quote Link to comment Share on other sites More sharing options...
Stobsie Posted January 8, 2022 Report Share Posted January 8, 2022 On 06/01/2022 at 11:45, EcosseGolfR said: Anyone running Racingline RP700 Front/Rear Brake Pads on their mk7.5 R? Are there any decrease in brake dust or increase in brake noise? Any significant pro's / con's over stock? I'm away to order replacement Vagbremtech J-Hooked disks, so was wondering about pads, i'm currently using Pagid on the rears and stock in the fronts. Brake dust is bad on both. TIA I’m sure @marshy ran these for a short period. EcosseGolfR and marshy 2 Quote Link to comment Share on other sites More sharing options...
marshy Posted January 8, 2022 Report Share Posted January 8, 2022 I’m sure [mention=20585]marshy[/mention] ran these for a short period. Yeah I ran them for about 5kDust level was about the same as the original pads.Found the braking a noticeable improvement over original pads with no additional noise or squeal.Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
EcosseGolfR Posted January 8, 2022 Author Report Share Posted January 8, 2022 Excellent thanks lads, @marshy any reason why you only ran them for 5k miles? Was that when you changed to the TTS setup? Quote Link to comment Share on other sites More sharing options...
marshy Posted January 8, 2022 Report Share Posted January 8, 2022 Excellent thanks lads, [mention=20585]marshy[/mention] any reason why you only ran them for 5k miles? Was that when you changed to the TTS setup?Yes I upgraded the front but ran the rears the whole time.When I sold the car it went with the Racingline pads fitted all round.Sent from my iPhone using Tapatalk EcosseGolfR 1 Quote Link to comment Share on other sites More sharing options...
