switch off rear DRL's mk7
sal1m
@sal1m: Hi.
hmm........ "a 2015 mk7 GTD with the facelift mk7.5 rear lights" almost certainly means that this car is non-OEM - which is not good when remotely trying to understand how the tail-lights are coded!!
Regardless of the retrofitted equipment - how was this car factory built (meaning did this car have incandescent, or LED tail-lights when it left the dealer showroom)? The answer to this question determines how any wires are in the cable-loom from the 09 module and the tail-light connectors. This also determines if a cross wiring harness was used to drive the mk7.5 rear-lights - which ultimately tells us whether wholesale changes were made to module coding!!
The final additional piece of information needed is what flavor diagnostic cable do you use?
  • 2 months later...
On 17/05/2024 at 23:05, dv52 said:
@sal1m: Hi.
all 2015 mk7 gtd comes with the led dot lights , vcds was used
Rear Mk7 lights have to be coded to be on all the time  - Scandinavian rear lights
If they are on after the Mk7.5 light have been fitted (which have to be coded to work) they will almost certainly have been 'played with'
As such you will need a 'local' VCDS expert to scan the car to find out exactly what has been done.
Basically you need a local version of @dv52 to look at your car!
hmm........ OK, for obvious reasons based in the main on the fact that I live on an isolated island which is located slightly North of Antarctica, I was not aware of VW's marketing practices on an island in the Northern Hemisphere - but thanks for the information!
Please understand that the BCM on this car has in excess of 1,200 adaptation channels and it has 665 x "Leuchte" channels to control the 35 x external lamps. Plus, each of the separate lamps ("led dot lights") in the tail lights has 19 x channels that can be programmed in multiple ways.
So, as @TheBlondeFella advises, this problem won't be solved without the provision of specific data from the car.
Since you using VCDS, please make a BCM admap (i.e. an adaptation channel map) and post-up a copy as an attachment, so we can see how the module is currently coded.
all sorted with the following :
Select the 09-Cent. Elect. module
Select Security Access - 16
Enter the magic number 31347
Select Adaptation - 10
Enter ENG116593 into the search box
If you have a pre MY16 model Golf, select IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht
if you have a post MY16 model Golf, select ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht
Change the setting to Not active
Select Doit!!  and exit VCDS software
@sal1m:hmm...........your fix instructions look remarkably like words I've seen somewhere else!!!
Given that there is no attribution in your post, I assume that the fix was your personal discovery. If so, well done!!
If not, I will assume that your post is intended as the sincerest form of flattery (ain't the electric internet a wonderful thing?)!!
