Faults help
Ynot247
So I’ve recently just received my obd11 pro package, first thing I did was scan the car. It’s came up with 6 faults.
one is remote key which I’ve searched and should be fixed but replacing key battery. 1 is my right rear bass speaker which shows up in 2 sections, I’m sure that’s just a lose connection I need fixing. Those ones I dnt have a problem with as they aren’t anything serious.
the other 2 I’m not sure about and looking for a little advice on what they mean and maybe how to fix.
first one is showing up on light control left and right - supply voltage - voltage too low - fault code U101100. The lights work fine and the battery was showing up fine to with engine off and running.
second one is showing up in central electrics - anti theft alarm system sensor - implausible signal - fault code B133029. Any information on both these would be really helpful thanks.
also can anyone tell me how the priority rating works, the faults are priority 4 and 5. Is 1 = low priority and 10 = high priority??
@Ynot247: Hi.
OK, you are an OBD11 new-bee - so maybe a few suggestions to enable the forum to better understand this problem?  To do this, a full, unedited SCAN report would help!
First, the screenshots in your post are a good start - but there's lots of helpful fault data missing (this is not intended as criticism - it's just a fact!).  So, maybe do the following:
  1. Start by activating Freeze-frame data against your OBD11 account - read THIS
  2. Next create a SCAN report for the car by doing the following:
    1. Ignition-ON, engine-OFF
    2. Fire-up OBD11 Software - plug the dongle into the car's OBD port and connect to the iPhone
    3. After OBD11 has fully connected - press the big Tap to scan button in the Home screen below
      XlaA6GS.png?1
    4. Wait for the process to com
To digitize the SCAN report so that you can post-up a copy in a new post - do this:
  1. Back on the Home screen above, select Garage/Vehicle (lower left side of screen)
  2. If you have registered more than ONE vehicle against your account - select the correct car.
  3. Scroll-down the list of options and select History.
  4. Follow the screenshots below
    OLdpB2w.png?1
  5. On the second screenshot, select Full scan and de-select ALL other options
  6. After you receive the email that you sent to yourself from the last screenshot - attach a copy of the SCAN file to a new forum post as an attachment (don't dump the SCAN contents directly into  your post)
44 minutes ago, dv52 said:
@Ynot247: Hi.
      XlaA6GS.png?1
    OLdpB2w.png?1
Thanks for the help Don. I’ll do this in the morning 👏🏻
13 hours ago, dv52 said:
@Ynot247: Hi.
      XlaA6GS.png?1
    OLdpB2w.png?1
Don I’ve got the scan from yesterday in my email but not sure how to attach like you said, as when I do try it says file it not supported. It allows me to allows the images of it if that’s ok to do( not sure as you said dnt dump the contents directly)
15 hours ago, dv52 said:
@Ynot247: Hi.
      XlaA6GS.png?1
    OLdpB2w.png?1
I think this is the best I can do Don, hope this is ok.
OBDeleven_Log-1.thumb.jpg.43cdc17e189ace1547474ca2a24f85ae.jpgOBDeleven_Log-2.thumb.jpg.05c57542ae68147e26109f467fe9c713.jpgOBDeleven_Log-3.thumb.jpg.d0b05893fc52826cc8279efc9f3c735a.jpgOBDeleven_Log-4.thumb.jpg.94fa39ba699c99e9e91fab5f348ea628.jpgOBDeleven_Log-5.thumb.jpg.5ba55895fd97b5e1b7d2b37ba5b411b5.jpgOBDeleven_Log-6.thumb.jpg.ec30211de82597853a51efe91f22da77.jpg
Tony: I suspect that I owe you an apology!!! I pulled the instructions in my reply from my "usual" response to like questions on the OBD11 forum. However, in doing so, I failed to remember that this forum is .......... well, to put it tactfully, not so well endowed when accepting attachment file-formats.
The way that you can attach .TXT files to this forum is to upload the file to an external hosting site (like dropbox etc) and then include a URL link to the document here. Yes, it's a tad clumsy in the 21st century  - but this forum has other advantages, which I won't expound!!!
OK - well done for finding a work-around to the forum limitation!! I've been doing this stuff for many years and I've learned how to read outside the words in a forum post. Your ability to find a solution to the attachment problem and your dedication in pasting together multiple sections of the SCAN into screenshots speaks volumes about your personal attributes!! I suspect that these traits will be an excellent support for your diagnostic endeavors!!
But, enough of the hagiography (look it up) - let's examine your data.
First, l assume that you have read and understood the meaning of the freeze-frame elements as explained in my OBD11 link above.
For the B133029 error (which is the subject of this tread), the freeze frame data can be summarized as follows:
  1. fault status = intermittent
  2. Malfunction frequency counter =1.
  3. Error date-stamp = 2025 -03-21
  4. SCAN date  = 2025-03-30.
  5. Priority=4 (High numbers mean not important)
The 5 x points above read together as a type of poetic meter ( a form of Iambic pentameter, if you want 😜) means that in the intervening 9 days between the date that this error was first registered in fault memory and the date of the SCAN, the error has not reoccurred in a subsequent driving-cycle (think about a "driving cycle" as a reasonable short drive)
This is how the Anti-Theft system is wired (don't worry about "Audi A3 8V" - your car shares the same MQB platform DNA, so it's the same):
J519 in my diagram= central electrics module in OBD11 speak (as identified in your SCAN) and "LIN" is a single wire, low-speed communication protocol. I provide the wiring diagram for information only and because I want to introduce you to these diagrams as a useful aid to provide context for SCAN error information.
So, what's the way forward - I can hear you thinking? Well, my hunch is that there is probably not sufficient information to do anything! I suspect that the B133029 error is likely a glitch at this time. I suggest that you simply clear ALL errors on this car and keep watch for any recurrence.
But, enough of the hagiography (look it up) - let's look at your data.
Read together as a type of poetic meter ( a form of Iambic pentameter, if you want 😜) , the information above means that in the intervening 9 days between the date that this error was first registered in fault memory and the date of the SCAN, the error has not reoccurred in a subsequent driving-cycle (think about a "driving cycle" as a reasonable short drive)
Thanks Don I’ll keep in mind for future about how to post a txt file. Really appreciate the in depth reply and an insight to the faults that have shown.
I will clear the faults tomorrow and keep an eye on it, car is running great and I dnt have any problems was just interested if any of these faults were major issues.
I’ve got a lot to learn on obd11 but so far managed to add the lock chirp, take off soundaktor and disabled the stop/start.
Going to read up on a few more things before trying to do anymore.
once again Don thanks again for your help 👏🏻👏🏻
